I have an hp 110 mini model 3130 NR. I'M trying to get to the hard drive which mysteriously vanished overnight. To remove Keyboard and access hard drive every manual or video shows screws behind battery. On this model I see no screws. Am I blind? Where are they and how do I get to my hard drive?
    Master:
  • 560 Answers
Go to YouTube and look for videos on your unit.
Posted on Nov 15, 2014
Hp mini 110-3600sa keyboard stop working
motherboard or keyboard problem , go to your manufacturer's support,
Dec 04, 2012 | Computers & Internet
Can i remove another administers pass word ? or delete her sitting in every thing i got this hp mini 110 from my friend and she for got .?
You can manage all users as long as you are the Administrator. There just has to be at least 1. Save password! You would not believe how many people forget and have reformat or buy 3rd party software to fix.
Aug 29, 2012 | HEWLETT-PACKARD Mini Laptop HP 110-1025DX...
My hard drive failed my hp notebook
The hard drive will need to be replaced. Most latops the hard drive is under the keyboard or back cover. A couple screws can be removed to access this. You will need you recovery disk once you replace your hard drive.
Aug 09, 2012 | HEWLETT-PACKARD HP Mini-Notebook...
I can't working with keyboard HP mini 110 RN
Buy a new keyboard and make the substitution
Jun 21, 2012 | HP Mini 110-1037NR Netbook
How to remove the keyboard of a HP Mini 110 3130sv
Removing the Damaged Keyboard
1. Enusre the laptop is fully powered off, unplugged laptop ac adapter from the wall, and the battery taken out.
2. Turn the laptop over. On some models icons indicating which screws are attached to the keyboard for HP Mini 110-3130sv displayed. If not, you may have to "eyeball" it if you can't find a breakdown for your model online.
3. Remove those screws with a T-8 or Phillips screwdriver.
4. Turn the laptop back over and open it up. Check and see if the HP laptop keyboard is tucked under any plastic pieces. If so, find if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
5. Remove the plastic pieces carefully with a toothpick or plastic pick if there is any in the way.
6. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, ribbon cable to the system board at the bottom.
7. Take that same pick and lift the plastic connectors that hold in this data cable in place.
8. Carefully remove the data cable. Now the whole HP Mini 110-3130sv replacement keyboard should be free.
Replacing the keyboard.
1. Take the new keyboard out of the plastic, and slip the data cable back in between the plastic connectors on the system board. Make sure it's all the way in.
2. Use the pick to push the plastic connectors back into place, and make sure it's holding the data cable in.
3. Slip the keyboard itself into place, from bottom to top. Make sure the screw holes or clamps line up at the top.
4. Refasten the keyboard in place at the top.
5. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
6. Turn the laptop over and replace all of the keyboard screws.
7. Finally, put the battery back in and power on the laptop. If all has gone well, the HP Mini 110-3130sv Keyboard should be functioning like brand new.
Sep 01, 2011 | HEWLETT-PACKARD Mini 110-1031NR Netbook
I want to change the harddisk, but I can not get the computer opened in order to so. Any suggestions?
In order to change the hard drive on this laptop you are going to have the remove the battery and the keyboard because the hard drive is directly under the keys. When you remove the battery you will see 3 screws, remove them. Open the screen and flip the laptop over to see, in the battery compartment, the keyboard release access. Insert a flexible tool and press inward to release the keyboard. Flip the laptop over and gently lift up the top part of the keyboard until it releases. You will see you have the hard drive there. Unscrew it, remove the bracket and replace the hard drive. Be careful not to loose any screws and never force a screw back into place.
Jul 06, 2011 | Compaq Mini 110c-1001NR Notebook
I have an HP Mini 110. I have turned off the
Try this: Remove Mini from A/C power; remove battery. Hold power button for 10 seconds; reinstall battery & A/C power. Try starting normally. Your netbook doesn't appear to have an external VGA port, or I would suggest trying to connect to an external monitor. Your monitor back-light may be burned out.
Mar 10, 2010 | HP Pavilion ze2000 Notebook
How to Reset HP Mini 1000 Laptop BIOS?
http://laptoppassword.blogspot.com/2011/06/hp-mini-password-service-compaq-mini.html
Clear Bios Password for HP Mini - Compaq Mini:
HP Mini 1000, HP Mini 110, Compaq Mini 110C, Compaq Mini 110, HP 2230S, HP Mini 1120LA, HP Mini 1151NR, Compaq 700....If you see this screen on boot:Enter CURRENT Password: [_______________]
We can help you Remove Password, right now !!!
You just enter 3 random passwords one by one and see if you get a similar [System Halted] message with 10 chars Error Code. (e.g CNUXXXXXXX, 2MCXXXXXXX....)
Jul 16, 2009 | HP Mini 1000 Netbook
Computers & Internet Logo
David Payne
David Payne
