Question about Alcatel Cell Phones
<!-- from fixya rte -->Stop from cutting on and off - Alcatel Cell Phones
    Top Expert:
  • Alcatel Master
  • 25,285 Answers
Battery contact?
Posted on Nov 15, 2014
Why did it suddenly stop cutting?
Please provide the model of your machine.
Ok, it's a serger. Wondered why a sewing machine would be cutting unless it had the cut-n-sew accessory.
Most likely the blades are damaged or malfunctioning. Is the blade still moving when it is stitching? Is it just chomping away at the fabric but not cutting? If so, either or both blades need to be replaced. Consult your owner's manual. Usually only one blade can be installed without any technical knowledge. You can probably order the replacement blade and install it yourself. However, the other usually needs to be replaced by a knowledgeable technician because it requires some precision.
Has the blade stopped moving at all? If so, how long has it been since a thorough cleaning and oiling? Take it for service.
Mar 25, 2016 | Elna Sewing Machines
I have a 2010 John Deere 777 Riding Lawn Mower that stop cutting all of a sudden as I was mowing this morning. Do you have any idea why?
Cutting or running? Big difference..if stopped cutting most likely your belts came off the pulley or broke...have to take a look..Stopped running need more info...good luck..
Aug 25, 2015 | John Deere Garden
Why will a cub cadet lawn mower cut grass a few mi. then stop cutting?
Sounds like the electric PTO clutch is bad and needs to be replaced.The straps within the clutch brake causing it to get out of position and the clutch keeps disengaging. You can buy the clutches on line cheaper but they don't last as long.
Apr 22, 2015 | Cub Cadet Garden
My riding mower stops moving forward after 30 minutes of cutting it starts right up the blades engage properly and cuts great it will just stop moving
Check under the seat under the battery box there you should find the drive pulleys for the rear end the belt could be worn out and turned inside out causing it to slip or stop pulling once it heats up mine was installed inside out from Lowes when I purchased the mower causing me to replace the belt hope this helps
Sep 16, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Ryobi rbs3080 motor stops when using
Try to install new blades. I've used 201 Haltbar blades in cutting pine before. Please get the right TPI too. But you may want to check the belt if it's slipping and try a slower feed rate.
Feb 27, 2013 | Ryobi Saws
My mazda soho 1.4i cuts out when you stop at the stop street or robot and she doesn't rev up?
Check out the related help links with solutions to troubleshoot the problem.
Click the link below:----
1990 Toyota 4Runner: Engine cuts off when reaches 2000 RPM?
http://whatisbyme.blogspot.in/2012/05/1990-toyota-4runner-engine-cuts-off.html
Volvo 760 engine cuts off frequently while driving? http://schematicsdiagram.blogspot.in/2012/02/volvo-760-engine-cuts-off-frequently.html
Car starts and cuts off immediately? http://repairhelpcenter.blogspot.com/2012/01/car-starts-and-cuts-off-immediately.html
Engine cuts out at 3000 RPM? http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
While stop engine idles like cylinder missing? http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
These details will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
Ryobi ets 1825 table saw cuts out
Sounds as it is overheating. When have you last changed your blade. Also cut slower may help if your blades are dull or if the thickness of what you are cutting is too thick. Don't use an extension cord neither. Hope this helps.
Nov 10, 2012 | Audio Players & Recorders
I have dewalt 18 v circular saw i cut vinyl lattice once and used it on a 2x4 but it wouldnt cut it, started to cut then just stopped. is blade dull already? new saw.
a couple things to look at. Did the saw stop operating or was the blade not wanting to cut. Remove the battery and CAREFULLY feel the blade for dull or broken segments. If the blalde stopped check to make sure not a loose bolt holding it on. Did you reverse the blade for cutting the vinyl. Let me know more information and I will try and help
Feb 02, 2012 | Dewalt 18 V Cordless Circular Saw Model...
Engin cut off
when a crysler battery gets weak the idle air control will be searching where to posistion itself because of low volts put a battery in it!
Jan 20, 2009 | 1995 Dodge Caravan
Cell Phones Logo
Top Alcatel Cell Phones Experts
Gene
D. E. Hev
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
