Question about Cell Phones
Lock pass word of - Cell Phones
    Genius:
  • Cell Phones Master
  • 1,373 Answers
Hi whether you forget the phone security lock password then can you please specify the model of your phone if it belongs to older nokia model then you can easily reset your phone using default codes like 0000 or 1234 if this codes didn't help to reset your phone then visit sites like Unlocking4Free.com here they are generating master reset code for some older Nokia and alcatel mobile models at free of cost .You can use it and reset your phone then assign new security password for your phone ...
Posted on Nov 16, 2014
Remove pass code
Do you want remove network lock pass code for your iphone? Yes means you can visit this site Mobileunlocksolutions.com here you can get the remote unlocking service and remove your mobile network lock pass code easily.
Aug 17, 2014 | Apple iPhone Smartphone
Remove password fram screen
If would like to remove a pass code from an apple device, you would login and head over to settings. Next click on general > pass code or pass code lock I can't remember which one > now click disable pass code or remove pass code and you will be proceeded to put in your pass code. Now if you've done correctly try to lock and unlock your phone. I hope this helps;)
Apr 21, 2014 | Apple Iphone A1387
V-chip block passcode
Hello
You must have its original remote control handset to unlock your Mitsubishi tv.
After you set the lock, you must use your pass code
to view a locked program, view the locked TV, view
a locked channel, cancel the lock, or enter the Lock
menus.
If you forget your pass code, you can view the locked
TV without entering your pass code. When you are
prompted for your pass code, press the number 9 and
QV keys on the TV remote control at the same time. This
process temporarily unlocks the TV.
When entering the Lock menu, this process deletes
your old pass code and prompts you to enter a new
pass code.
• You can either enter a new pass code to open the
Lock menu and make changes or press EXIT to close
the menu.
• If any of the locks are turned on and you exit the
menus when prompted for a new code, the old
code and all lock settings are retained.
• If all locks are turned off and you exit the menus
when prompted for a new code, then the previous
code is erased.
OK.
Mar 17, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Lock on drivers side will not open
the most common problem is lock solenoid (inside door) needs to be replaced. Before replacing try re-syncing locks. To do this, you need to lock all doors from passenger side, unlock from pass side, re-lock from pass side - then try drivers lock.
Feb 24, 2011 | 2003 BMW Z4
Channels lock
prompted for your pass code, press the number 9 and QV
buttons on the TV remote control at the same time. This
When entering the Parental Lock menu, this process
deletes your old pass code and prompts you to enter a
new pass code. Press EXIT to exit the menu.
Jul 05, 2010 | Mitsubishi WD-65731 65" HDTV
SGH-a437 phone locked
is the Sim locked or is the phone locked??
Sep 21, 2009 | Cell Phones
1997 buick skylark theft system .
Hi....
Is common to see this problem with the theft system on chevys.
On your case I can figure out that the Computer is lossing the Pass code.
But this is due to a Bad pass lock sensor . The pass lock sensor is integrated in the Ignition lock cylinder.
The car will start After about 15 minutes. with the key In On position.
Because is about the time that the computer take to learn the Pass lock code. Exactly 11 min.
I recomend get the ignition lock cylinder checked for any inconssistence on the hardware.
The key some times bent. Or the small wires around the Lock cylinder damaged.
If everything is OK.. You will need to replace the Ignition lock cylinder , Before any control module...
Ok.. I hope this help on your problem.
Thank you for use fixya...
Jan 12, 2009 | 1997 Buick Skylark
Pass door lock
Pull the door panel and verify that the link rod for the door lock is connected to the door lock/unlock actuator, if it is cycle the locks, if nothing happens replace the lock actuator.
Aug 02, 2008 | 2003 BMW 5 Series
Cell Phones Logo
41 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
