Question about Hardware & Accessories
Have a Onsen a/c H09-et it was working fine until one day timer light started flashing and now it doesn't at all. Plz help
DIYSundeep
SOURCE: plz help
remove the SD Card and the batteries. Wait for half an hour and then insert two new batteries. Do not put the SD card in as yet. (Waiting for half an hour or more allows the camera to reset itself).
Now try switching on and good luck.
Posted on Jan 11, 2008
  • 408 Answers
SOURCE: My mouse doesnt work?? plz help
Have you tried uninstalling the drivers and reinstalling them.  Update with the new drivers found at
http://www.dynexproducts.com/pc-568-10-dynex-wireless-optical-mouse.aspx
Posted on Mar 04, 2009
  • 239 Answers
SOURCE: Mitsubishi 52" WD52725 flashing green timer light
your projector bulb went out. you need to call the manufacturer and order a new bulb. they cost 300 to 400 dollars a piece I believe your tv only has one bulb and they are really easy to install.
hope this helped
please rate well.
Posted on Mar 06, 2009
kirkx
  • 2019 Answers
SOURCE: 2005 mazda six. car working fine one day next day
When ever a batter this new goes bad, it is either because it is not being charged, because there is something wrong with the charging system, or there is a constant drain even when the key is off.
To check the latter, with everything off, you remove a battery cable and see if the is any glow from a test light between the post and the cable. If there is, then you have something on that should not be, all the time. Then you pull fuses and disconnect things until it goes off.
To check if the charging system is not working, the easiest way it is to borrow a battery to get it started, (don't jump start a car if you can avoid it, because you can ruin an alternator when it starts, because it will kill itself trying to charge up that bad battery.) With the lights on, rev up the engine. They should get slightly brighter. Of with a volt meter, see it go from 12.5 to 13.5 volts, or so. If it does not go up, then your battery is all that was powering the car, and it won't last long like that.
Posted on Jan 20, 2010
hvac1960
  • 2133 Answers
SOURCE: I have an Onsen split
How many time flashing? It depends on error code. Reply
Posted on Jan 20, 2011
When I turn the power button on the timer light flashes. How do I make the CD work?
Sounds like you need to turn the timer off, or leave it running until the timer finishes. Do you have the make and model? If not supply make and model.
Aug 04, 2015 | Audio Players & Recorders
Wickes 7 day digital timer. I can set the time and date, but how do I set the timer?
1) Copy following link to identify timer and download manual:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html#451
2) Don't forget to press reset button before starting to clear memory traces.
Each program must have ON and OFF time.
After setting current time, and pressing SET button, it appears you press the A+ button until 1 and ON show on display ... this is program1 ON.
Then it appears you press SET button and days of week will flash for Program1 ON. Cycle through choice of day(s) you want for program1 ON.
3) Add comment and say what you find, for further interactive help Jan 2013
Jan 20, 2013 | Hardware & Accessories
Onsen split air conditioner showing code E5 what is wrong?
I have an Onsen split system air conditioner but i cant turn it on today for some reason. The timer light is flashing 4 times.Its look like error 4.Any suggestion?
Oct 10, 2011 | Heating & Cooling
I have GE Model #15089 digital timer. I want to reset time to come on to 7:30 pm and turn off at 10:30 pm. It was previously coming on at 6:00 pm and off at 10:30 pm and working fine but when I tried...
The problem with answering questions where somebody cannot program a timer, or programming stopped working, is that expert doesn't know if timer is defective, or needs to be reset, or timer has conflicting programming, or if person has mis-read the instruction manual, or if wrong button sequence is being used, or if internal battery has gone bad, or if circuit has interference or loose wiring, or if light bulb burned out, and however expert guesses, the person asking question is unhappy because the timer still doesn't work and/or the manual still doesn't make sense.
I work with timers every day and suggest the following steps to get started:
Reset timer and try setting program again.
Write out steps in manual at point where timer doesn't seem to work.
Double-check that you are pushing correct buttons all the way down.
Make sure same days of operation are selected for ON and for OFF. For example if ON is set for all days, and OFF is set for Tuesday, then timer will not work as expected.
Reset timer and make sure there are no conflicting or overlapping programs, or timer will not work as expected.
Test outlet with cheap circuit analyzer from home center, try timer on different outlet, try timer on different Load, check that Load works when plugged into outlet without the timer.
Save some headaches listed above, and buy another 15089 at Home Depot and return defective one in new package.
http://waterheatertimer.org/GE-timers-and-manuals.html#15079
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 25, 2011 | Hardware & Accessories
I have model 0155671 but it doesnt look like the model online mine has four buttons across set time plus minus next riw is rnd ctd bottom is manual i dont understand when it says select 12 or 24...
A) 12-24 hour choice >> just use the 24 hour display.
That gives you day and night hours
I don't know why these companies offer 12hr-24hr option on timers.
B) Military time vs Regular time (military time does not use am and pm)
1 1am
2 2am
7 7am
11 11am
12 12noon
13 1pm
14 2pm
20 8pm
23 11pm
24 12midnight
C) Utilitec 0155671 is same as Woods 59377
Before Woods made 59377, they made 49566 (which is also called TD1101 and TD1300)
I think you have Woods 49566
Manual for Woods 49566:
http://waterheatertimer.org/pdf/Woods-49556-TD1300.pdf
Add a comment at any time.
D) How to program timer.
Plug timer in until rechargeable battery is charged and display shows.
Unplug timer to program
1) Set current time.
Hold in reset button for two seconds to clear memory
Press and hold TIME button to select 24 hours so there is no problem. Release Time button.
Press and hold SET button.
MO is flashing, and represents MOnday. TU for TUesday. WE TH FI SA SU
Continue holding down SET button, and press ? ? until current day displays.
Release SET button.
Press and hold SET button again, and Hours will flash
Continue holding down SET button, and press ? ? until current hour displays.
Release SET button.
Press and hold SET button again, and Minutes will flash
Continue holding down SET button, and press ? ? until current minute displays.
Release SET button.
Press SET button again and current time and day will display.
2) Program review:
Set up to 20 on-off programs.
You can select individual days, or groups of days, or all days of the week
For example MO-SU is all days of the week
For each ON time, you also must set OFF time.
So program1 ON is set, then program1 OFF is set
Each ON is set for day, hour and minute
Each OFF is set for day, hour and minute (select same days for OFF and that you chose for ON)
For example if you want timer to turn ON all days MO-SU, make sure OFF time is also set for all days MO-SU.
3) Program the timer:
ON
Press arrow? until display shows PROG 1 ON
This is program1 ON.
Press SET button, but do not hold set button down as you did when setting current time.
The days for program1 ON will be flashing on display.
Press ? ? to select day, or groups of days that you want for program1 ON.
Press SET button again, and program1 ON hour will start flashing
Press ? ? to select hour that you want for program1 ON.
Press SET button again, and program1 ON minute will start flashing
Press ? ? to select minute that you want for program1 ON.
program1 ON is set, next you will set program1 OFF
OFF
Press arrow? until display shows PROG 1 OFF
This is program1 OFF.
The days for program1 OFF will be flashing on display.
Press ? ? to select day, or groups of days that you want for program1 OFF.
Press SET button again, and program1 OFF hour will start flashing
Press ? ? to select hour that you want for program1 OFF.
Press SET button again, and program1 OFF minute will start flashing
Press ? ? to select minute that you want for program1 OFF.
program1 ON and OFF are set, next you will set program2 ON by repeating steps above.
If you do not want to set more programs, that is fine.
Timer lets you set up to 20 programs.
Finish programming: when program ON-OFFs are set, press TIME button and current time displays.
4) Last step:
Push manual override button until AUTO is displayed. This will let timer turn lights on and off.
Plug lamp into timer.
Lamp must be turned ON.
Plug timer into wall.
Dec 05, 2010 | Hardware & Accessories
How to program #49556 te158wta my add: gd659@cgocable.ca
Woods 49556 / TD1300 manual
Set current time.
Release SET button.
Release SET button.
Release SET button.
Programing overview:
Program the timer:
Set ON
Press SET button, but do not press and hold set button as you did when setting current time.
program1 ON is set, next you must set program1 OFF
OFF
Last step:
Dec 04, 2010 | Woods Hardware & Accessories
Timer is set properly, but, the daytime lights never switch off
The timer doesn't know what time it is until you set current time.
The yellow outlets are controlled for 12 hours, and you can determine when those hours occur when setting current time.
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
If you want timer to control one lamp with both day and night schedules, you have to adjust current time setting so lamp schedule falls within a 12 hour period. If that schedule doesn't fit, then buy a second timer.
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
Aug 07, 2009 | Coralife Zilla Aqualight Power Center
Hardware & Accessories Logo
47 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
