Question about Garden
The blade on my Flymo 360 glidemaster has the ends of the blade bent slightly do I fit them facing up or down ?
    Problem Solver:
  • 13 Answers
If you look at the blade,it should say "grass side" on one side. Mount it so you can see the words.
Posted on Nov 15, 2014
2 Suggested Answers
  • 391 Answers
SOURCE: Blades keep spinning out on Flymo
Replace the disc.
Posted on Aug 28, 2009
How do i change a blade for a zona mini hack saw?
Hello there.
The TENSION in the frame holds these blades in their slot.
What you do is
1) turn the saw upside down so the blade is pointing upwards.
2) Hold the handle of the saw tight against your tummy or if you have strong arms just your hands So the saw faces away from you.
3) Put the far end of the frame against a hard surface like a wall or bench.
4) Push the handle against the force and you will see the FRAME bend very slightly, this will allow you to push the blade out of its slot.
Engage new blade at the handle end then do the reverse of the above to allow the other end of the blade to go in the slot .
DONE !!!
Sep 21, 2014 | Zona Blade: 36-656 Mini Hack Saw Blades...
HOW DO YOU CHANGE THE DRIVE BELT ON A FLYMO 360
Your question is in the video game consoles categories???
If you actually have a Flymo 360 lawnmower you will find a link below to the users manual. However I looked at the manual and it appears to be direct drive ie. no belt. http://www.flymo.com/ddoc/flyo/flyo2012_gben/flyo2012_gben__a505284803.pdf
Aug 16, 2014 | Video Game Consoles & Games
Why is my flymo 360 eg not collecting the grass
If you have changed blades or have low lift blades this will be the problem. For good grass collection you should have high lift blades
Apr 30, 2014 | Garden
My flymo 350 turbo compact isint cutting can i adjust the blade height ?
You can put spacers under the blade, a twin pack of spacers are available from Flymo part no. 513811081., from memory you are allowed to fit three spacers.
Aug 10, 2012 | Garden
How do I perform a ball chest fly?
You'll need to lay on your back, shoulder blades on top of the exercise ball, back extended, knees flexed at 90 degree angles and hold dumbbells out to each side of your body. Then roll the dumbbells in and up and slowly lower them down after a short pause maintaining your elbows just slightly bent.
Aug 02, 2012 | Exercise & Fitness
Where is the cutting adjustmant for blade on flymo glidemaster 340
The adjustment is done by putting spacers under the blade, you can put up to 3 spacers in, the part no. for the spacer is 513811001
May 05, 2011 | Garden
My flymo 300 compact is getting very load and is vibrating,concerned about useing it,do you know what the problem can be?and can i fix it?
It could be that you have hit the blade with something hard that has of set the blade or the spindle the blad e is on that would explain the wobble if spindle is bent then you have to serouisely think about buying a new machine
Jul 01, 2010 | Garden
I have a t801 mixer with a bent planetary shaft.
Remove the whole planetary from the bottom... There should be a large nut on the main shaft...remove it ....whole assembly drops down...careful...don't drop it......At the top of the bent shaft you should see some center punches holding a thin nut in place.....drill them slightly so you can loosen the nut. There are some studs that hold the lower bushings in place...remove them with a straight blade that fits the screw snug. You can have a new shaft made out of stress proof steel shafting from a competent machine shop........MONSTROSPIZZA.COM
Jan 29, 2010 | Hobart Food Mixers
Can the blade height be adjusted on the flymo 300 compact?
the blade shape can not be changed they are heat treated and if bent they will break, the only way to change the blade height is by changing the blade adapter.
Apr 05, 2009 | Garden
Flymo micro lite - cutting height of blade
you twist the plate holding the blades and it will lift off, then you turn the blade plate upside down and replace making sure you align the notches and then twist to lock into place. hope this helps
Oct 16, 2008 | Garden
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
