Question about Garden
My McCulloch TimberBear just dies in the middle of cutting. It doesn't make any difference if it is under full throttle or not. It will not start back up until it is cooled off. It runs perfe
My McCulloch TimberBear just dies in the middle of cutting. It doesn't make any difference if it is under full throttle or not. It will not start back up until it is cooled off. It runs perfect otherwise. Is it electrical or in the carb?
  • 1,169 Answers
Sounds electrical. Ignition coil's electronics can become heat sensitive and fail when heated and work again when cooled off. When it happens pull the spark plug and check to see if it arcing the gap. Bad news if you need a coil; no new ones are available if it is the saw I thinking of.
It can remotely be a fuel vapor lock from overheated fuel from running too lean.
Posted on Nov 15, 2014
  • 373 Answers
SOURCE: Poulan chain saw after carb rebuild.
Is thereadjustment somewhere on the saw
I think there is 2 .
Posted on Feb 03, 2009
  • 25 Answers
SOURCE: my husqvarna 445 starts and runs until full
chanes are the carb needs to be adjusted and the diaphrams in the carb need to be replaced over time they get stiff and hard from old feul, causing it to not pump feul and meter the feul properly
Posted on May 16, 2009
cj2176
  • 520 Answers
SOURCE: the saw wont stay running. I start it with full
Sounds like the carb needs to be rebuilt. Those tiny jets will clog easily and need to be replaced. The diaphragm is also a large part of bogging and dieing. Hope this helps.
Posted on Jun 14, 2009
#1 Taper
  • 1040 Answers
SOURCE: my mcCulloch mini mac 25 starts, runs, and cuts,
It sounds like the fuel cap is clogged. The fuel cap must be able to breathe in order for the carburetor to operate properly.
One way to be sure that it is the fuel cap is: The next time the chainsaw starts to die, loosen the cap for a second or two, it should start running properly again.
Jim
Posted on Jun 21, 2009
blueextc3221
  • 15935 Answers
SOURCE: chainsaw dies out when gas is pressed to full throtle
Carb needs teardown and cleaning. May be a stuck float or clogged jet.
Spraycleaner just wont cut it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Apr 05, 2010
Mcculloch 210 strimmer lost power now wont start for more than afew seconds
remove the muffler and run it the mufflers plug up and restrick the exhaust some mufflers you can open and clean the screen
Sep 14, 2012 | Garden
Runs but quits
Probably gummed up carb. If you don't want to try to rebuild the carb, then try adding a really good carb / fuel injector cleaner to the gas/oil mixture. don't forget to use a very small amount, then run the motor as fast as it will go for short periods of time to try and dissolve the gumming in the jets.
Aug 28, 2012 | McCulloch Garden
I have a McCulloch 14" Mini P52 which belongs to
If this machine has a saftey chainbrake it may well have activated, to de activate grab the front hand guard and pull it fimly back to the top handle of the saw, this will de activate the brake, now try again.
Aug 28, 2011 | McCulloch Garden
Generator starts than shuts down on under voltage
The problem is related to the engine. When a load is put on the generator, the engine's throttle will want to open to maintain RPMs. If your carburetor is misadjusted or gummed/varnished, when the throttle opens, you will get a fuel starvation and the engine will die. If the generator is used regularly and hasn't sat for a while, first check to make sure the spark plug is good since you don't want to make a carb. adjustment using a worn plug. After you adjust the carb. manuallly flick the throttle to ensure that the engine doesn't 'stutter' or die out. If it does, increase the gas in the air/gas mixture and if that doesn't solve it, remove, disassemble and clean the carburetor.
Jun 30, 2011 | Generac Electrical Supplies
How to adjust carby settings after rebuilding. McCulloch Eager Be
Turn both jet needles CW to stops (lightly), then back out each CCW 1-1/2 turns. This is a basic setting that should allow the engine to start and run. Start the engine and allow to warm up, then pull throttle full on. Adjust H needle CW until the engine starts to speed up, but continues to 4-stroke. Proper setting is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for better idle, yet allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Aug 01, 2010 | McCulloch Garden
Chainsaw won't stay running at full throttle
15 years old...
One cause to look in too is a leaking seal around the crank, this is causing a vacuum leak.
Hope this tip helps.
R/
David
Jan 27, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Mcculloch Virginia hedge cutter manual
mcculloch virginia mh542 hedge trimmer, fires 1st time, will only tick over roughly on full choke only then stalls when throttle applied, I have fitted new plug'cleaned air filter and new fuel mix but no change.
Nov 25, 2009 | Garden
2005 450r dies at full throttle
Sounds like dirt in the main jet of the carb. Take the slide out and clean the needle. The pull the float bowl and blow air or carb cleaner through the brass jet in the middle of the barb, where the needle seats.
Jul 01, 2009 | 2005 Honda CRF 450 R
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
