Half way through a wash its stops on stain and flashes it will not carry on washing u have to turn it off then put it onto rinse .whats wrong please ?
  • 2,210 Answers
You need a local appliance engineer who knows your make of machine. My guess is the main programmer has a problem.
Posted on Nov 15, 2014
  • 183 Answers
SOURCE: machine stops and goes to end half way through a cycle
Check the filter is not blocked it sounds as if it cannot drain in the time allowd at end of wash cycle. Regards Advisor
Posted on Sep 01, 2007
  • 209 Answers
SOURCE: Hotpoint Aquarius WF100 Fabric Cond not rinsing thru & PreWash lite flashing
this sounds like cold water supply not getting to the machine, test the supply from the house is working, is the machine buzzing slightly when it should be filling, if so the fault is the house supply to the washer, if the supply to the washer is fine, check the cold water solenoid for open circuit, thats about all it could be, if it worked fine before, if i have helped rate me please
Posted on Sep 18, 2007
  • 209 Answers
SOURCE: HOTPOINT AQUARIUS WF250 1500 SPIN
check the cold water supply, either from the mains pipe, there is no water getting into the machine, if water is there up to the machine check the solenoid for circuit, to do this unplug from electric, remove lid, and test the two wires on relevant solenoid, no circuit means faulty solenoid, (test with the 2 wires removed from solenoid) take care note position of wires to put back properly answer above based on info given
Posted on Sep 27, 2007
SOURCE: Indesit 1000 cycle starts but then lights flash
Check the filter which is under the white panel at the front of the machine(the filter is in the lower right hand corner). Unscrew the filter and remove it. Mine was blocked with loads of grease/limescale. I cleared it out and the machine is as good as new again. I cleared the system with half a packet of soda crystals put into the main drum (on its own without any washing in!) and did a wash at 90degrees. Its as good as new now. Good luck. CK
Posted on Jun 13, 2008
SOURCE: Washing machine problem
my w830 is doing exactly the same thing.
I am usually pretty good at fixing these sort of things so if/when I solve it I will post back here.
I think it is a motor fault - most likely the motor brushes are worn out.
Posted on Aug 07, 2008
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
Hi, my Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer, won't rinse and I have to manually turn dial to spin, any ideas please?
Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 26, 2013 | Beko Washing Machines
Hi i recently moved into an apartment which has a CDA CL993 washing machine.It seemed to work fine at the start but now i realise that i have to switch on the functions manually to get the machine do its...
its probably the control board - timer it comes off from the back u have to pull the cover off pay attention to the way it comes off n put back o nthe same way these knobs are timers too and they go bad !!!
Apr 08, 2011 | CDA Washing Machines
Hi David here.My washing machine carries out the cycle till it gets to rinse and goes no further.Tried putting it onto spin and drian but it tries to carry on but stops.,
You will need to see the voltages to the sections , the spin, the drain and then confirm if the voltage stops from the program controller or the motor by itself.
If program controller stops action , check all inputs, check thedoor switch, check the connections, check the board.
If not the error canbe the board itself.
Sep 29, 2010 | Bosch Washing Machines
Grease stains on dark clothing
this may due to softener,put spray and wash on stains and let it set all day,stop using softener use HE detergent and oxy clean powder wih soap in dispencer,also you may want to sanitize washer before you wash shirt also use the stain setting and extra rinse.thanks
Jul 29, 2010 | Kenmore Washing Machines
Indest wil103 has 3 flashing lights the power one and to green ones stain remover and extra rinse and want spin what is wrong please help
If the machin isnt able to evac the water, it wont spin. It will indicate error with 2 flashing lights + lock led. Check pump, drain hose.
Jul 26, 2009 | Indesit W 123 Front Load Washer
May 21, 2008 | Indesit W 123 Front Load Washer
Machine stops and goes to end half way through a cycle
Jan 17, 2007 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
