Question about Korg Ga40 Guitar Bass Tuner W Batteries
How to tune 12 string acoustic with ga40 - Korg Ga40 Guitar Bass Tuner W Batteries
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 57 Answers
Unfortunately, the manual on
http://www.korg.com/us/products/tuners/ga_40/
indicates that 12 string is not supported.
The owners manual can be downloaded at
http://i.korg.com/uploads/Support/GA40_EFG1_633661472559800000.pdf
The YouTube tutorial is at
https://www.youtube.com/watch?v=Of4CRajvq0E
with a 12 string, you can often tune the octave until the tuner sees the matching note. It won't see the correct string number, but an A note is an A note, whether or not it's an octave higher.
Hope that this helps.
Posted on Nov 27, 2014
What are some basic instruction for learn a acoustic guitar properly?
If you are gonna play acoustic guitar for first time then you have to choose different guitar.You should choose easy free string because it will help you to get tuned easily and there is matter with shaped of guitar.See here for first acoustic guitar epic guide line http://www.musicskanner.com/best-acoustic-guitars-2016-epic-guide/
Oct 30, 2016 | Music
How change strings gibson guitar?
One of the best was to keeping your guitar in tune, is to also string it correctly and use new strings . Make sure the first winding of a new string around the tuner post goes over the exposed tip of the new string. The rest of the windings go under the exposed tip of the string. This will keep the string clamped firmly in place. Use 4-5 turns around the post for unwound strings, 2-3 for wound strings, in a downward spiral towards the bottom of the post as shown in the photo.-Tom, 30yr player.
Apr 15, 2016 | Gibson Les Paul Studio Electric Guitar
I tune my guitars at 400 using a clip on tuner,which I believe is concert pitch I've recently bought a 5 string blue grass banjo .I set tuner to c mode to tune banjo is this correct
Actually, concert pitch is A=440 rather than A=400. Normally a 5 string banjo is tuned G (octave) D G B D though many variations exist.
Feb 20, 2015 | Ovation Music
How to tune 12 string guitar with ga40
Just use as if you are doing a 6 string ( instructions in the pack ) only play one string in each group at a time. The thinner string in a pair should be exactly one octave higher than the thicker string. Strings of the same thickness are in unison ( sound the same pitch )
Nov 15, 2014 | Korg Ga40 Guitar Bass Tuner W Batteries
How do you know what guage ernie ball strings are it just says regular slinky 2146?
Usually the guage of the strings is defined by the first string. In other words, light strings are usually 11s. 12s are heavier and 13s are heavier still. The string set that you list is a 12 which is a medium grade. The medium grade is also called regular as opposed to lights (11s) or heavy (13).
Hope this helps,
Dan
Jul 09, 2011 | Ernie Ball 2146 Acoustic Regular Slinky...
The D string on my new J-45 standard sounds unmusical , as if there are no rich overtones . I can tune the string with my electronic tuner but it never sounds musical. I think it has Gibson Premium...
Hi. Your guitar may not be intonated properly. You might want to try to level and balance the height and strings all throughout the neck. The level at the rear half (close to the soundhole) can be slightly higher than the front half (near the headstock). This can be done be adjusting the truss rod, nut and/or saddle.
Note: You may want to get a guitar luthier to do the trussrod, nut and saddle adjustments as these are very delicate procedures.
May 13, 2011 | Gibson Guitar Gibson SAG MB11 Masterbuilt...
I've got Takamine JJ 325 My problem is backround noise - What can i do ?
Acoustic guitars pickup noise almost like a microphone. You have to prevent the sound from reaching the guitar or get a solid body guitar.
Apr 11, 2011 | Takamine JJ325SRC-12 John Jorgenson...
Is he tuner supposed to light up green when the string is correctly tuned?
Before turning the unit on, press and hold down the calib/batt switch to check the condition of the battery on the battery meter.
Then either plug in your electric guitar to the input side of the AG-6 or if tuning an acoustic guitar without electronics placing the AG-6 near the front of the guitar should work. You will not need to press a button to select which string you are about to tune. The AG-6 will detect it and the corresponding light will turn on when it is tuned within range.
Turn on the AG-6 and start by striking the low E (thickest) string while open. This is the number 6 string or 6E. Slowly turn the guitars low E tuning key untill the red LED below the 6E marking on the AG-6 lights up. Continue stricking the open string and turning the key untill the needle centers on zero and the 6E light remains on.
Repeat this for the open A string untill the 5A light turns on and the needle centers on zero.
Repeat for the remaining four strings, 4D 3G 2B and 1E, being careful not to over tighten and break them.
Tip: It may be a good idea once the low E string is tuned, to tune the rest manually, especially new strings or strings way out of tune. Then tune again using the AG-6 tuner.
If installing fresh strings you will probably need to stretch each string and re-tune, possibly several times, before they hold their tuning.
Feb 19, 2011 | Fender AG6 Automatic Guitar Tuner
Need tuning button for a 1958 Giannini Craviola 12 string steel guitar and a new pick guard
Two websites that you can get almost any part you might need:
Warmoth
AllParts
If you don't want to wait for shipping, your local music store can have them ordered, but they'll most likely be ordering from one of these two sites.
Hope that helps!
Feb 10, 2011 | Giannini GWSCRA12-EL Brazil Series Steel...
Korg Ga40 Guitar Bass Tuner W Batteries Logo
119 people viewed this question
Top Korg Music Experts
Vito Vacirca Jr.
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Korg Music Expert? Answer questions, earn points and help others
