My Pure evoke mio radio is not working, it will not switch on.
A few days ago, i went to switch on my radio and it was stuck on standby , it would not do anything. I unplugged it from the socket, and took out the battery pack and then put it back in to see if this would help. Since then 'nothing' tried a different transformer to check it and still nothing. My radio is 5 years old, nothing untoward has happened to it, please help if you can.
    Top Expert:
  • Computers & ... Master
  • 22,788 Answers
The driver/switch components fail after a few years. Probably a single transistor latch but which one is the question. Try contacting Pure for advice, they may have a repairer local to you.
Posted on Nov 15, 2014
  • 324 Answers
SOURCE: Laptop will not power on at all.
Don't know what you have for a laptop, so will have to give you a generic process, here. Power down. Remove hard drive, remove cd reader and/or floppy drive. Remove memory cards. Replace only 1 memory card in the main slot (probably marked as slot 1). Try to power it back up and let us know what happens.
Thanks!
Ron-
Posted on Nov 09, 2007
tat4u
  • 520 Answers
SOURCE: IBM R40 - 2897...not resonding
disconnect any power remove battery .remove mem and check the mem slots for dust and debris replace mem.remove hd check connections(hd pins)check connecter for dust.refit ;make sure properly housed.reboot,enter bios.reset to default.save settings and exit.pc should now restart.any indications of fault maybe mentioned at startup if not window should boot
Posted on Mar 04, 2008
SOURCE: Philips Freevents X56 laptop won't switch on!
Take it back to the shop. The Sale Of Goods Act says that goods have to last for a "reasonable" time. It is not reasonable for a laptop to break after 18 months.
See http://www.berr.gov.uk/consumers/fact-sheets/page38311.html
or search for "Sale Of Goods Act".
It is possible, however, that the power button is broken. Try getting some compressed air to blow out any gunk from underneath it. If the laptop supports it, remove the keyboard any make sure you don't have biscuit crumbs under the key.
Posted on Jul 31, 2008
SOURCE: year old advent netbook 4211b will not turn on,
When you press power button press F1 or F2 or "del" key if you can see bios screen then you not need to refix RAM memory or reset bios.
IF you can see bios screen then lake sure harddisk is detected and SATA is disable then save settings and exit.
Also when you power up press F8 key if you able to see safe mode and other menu then you have change screen resolution enter in enable vga mode.
Then open control panel and display then change scree resolution to 1024*768.
Then apply and ok.
But if you can't see bios screen or nothing in dispaly then you have to refix RAM memory .
Check in back side there is 1 plate open it then refix RAM memory.
If still not get display then open back cover of laptop then find motherbord on it then pull cmos cell for 10 minutes so all settings go to defaults then again refix cmos cell then check.
Let me know if you need more assistance.
Thanks.
Posted on Oct 08, 2009
  • 2567 Answers
SOURCE: Acer Aspire 5738Z won't hold charge
Sorry. It seems that your battery is dead.
If your laptop is working fine on AC power only (with the battery disconnected), then your battery will need to be replaced.
Posted on Jun 16, 2010
Pure evoke-2s dab radio stuck on getting time how do i fix it?
here is the manual; for your item
http://www.thiecom.de/ftp/pure/evoke2/user_guide_-_393kb_pdf.pdf
try performing the system reset and autotune as it may be picking up time only from a time server once it has a good connection to digital transmitters, hence if not good connection will not get time and remain in that state, check that your arial connection is good also
Mar 21, 2017 | Pure Audio Players & Recorders
How do I correct a faulty volume on a pure evoke 2 DAB radio
Most likely the audio amplifier chip needs replacing.Other wise you could try spraying "CRC 2-26" into the volume control assembly.
Sep 28, 2014 | Radio Communications
Pure Evoke Mio Portable wont pick up all stations
check manufactures spec and try a factiry reset
Sep 02, 2014 | GPS
Pure Siesta DAB Radio has died
Replace all 8 100uf capacitors on the circuit. Worked for me.
RRM
Sep 11, 2012 | Pure Digital Pure FMDAB Radio
Pure DAB radio not coming on when turned on. Just showing setting clock on display?
On all PURE products you have the option of being able to return the product to its original factory settings. As well as being useful for fully re-tuning the radio, a reset effectively 're-boots' the product's operating system which removes any user settings such as presets and timer/alarm settings. A reset can often resolve any anomalies found.
tip.gif Note: You will need to re-enter your network security information after performing a factory reset. Make sure you have your network security key to hand before performing a reset or you will not be able to re-connect your radio to the internet.
Instructions for EVOKE Flow/AVANTI Flow/ Oasis Flow/ ONE Flow: Make sure your radio is switched on. Press and hold the 'Options' button down for two or three seconds and confirm the reset when prompted.
Instructions for Sensia: Make sure your radio is switched on. Tap 'Settings', tap 'Update' and tap 'Factory Reset'. Confirm the reset when prompted.
Instructions for Siesta Flow: Make sure your radio is switched on. Press and hold the 'Options' button down for three or four seconds and confirm by pressing the 'YES' button when prompted.
Dec 29, 2010 | Audio Players & Recorders
MY PURE 3 dab RADIO stopped working overnight - it was working perfectly saturday night but was completly dead sunday morning. It has a battery pack attached and i have also tried using another PURE mains...
I have purchased 2 Pure Radios (Mio &Evoke Flow) and have had the eact same problem you mention. It is definately a bug with the radio.
I have had the Mio replaced twice and the Evoke Flow once. 6 months later I had the same problem and took it back and got a credit. I would not trust this brand any longer...
Nov 03, 2010 | Audio Players & Recorders
My Pure Evoke 2 Dab radio has stopped working, it has power but can't get sound stations or anything ...what do i do?
I've got the same problem, from working perfectly to suddenly nothing. "No stations available". Please let me know if you get an answer.
Sep 02, 2010 | Audio Players & Recorders
Pure Evoke 3 circuit
yep, just download a manual (free) from Pure.com.
Feb 18, 2010 | Audio Players & Recorders
No sound from Evoke-1 DAB radio.
I've seen a few (Pure & other brands) like this.No communications between the micro and the dab module . could be either thats at fault.. Doubt it would be an economic fix. sorry.
Nov 07, 2009 | Audio Players & Recorders
Computers & Internet Logo
135 people viewed this question
David Payne
David Payne
