Tv says no signal lost all channels , tv does not go through broad band so no bow
tv says no signal lost all channels , tv does not go through broad band so no bow
  • 937 Answers
Not a lot of detail in your question so start with the basics - do you have good connections to the TV and outlet. Is the signal confirmed good at the outlet? Is the TV set for the correct input? Beyond that it could be the tuner card in the TV. Confirm the easy stuff first before looking into the internal TV parts.
Posted on Nov 15, 2014
Testimonial: "tv was absolutely fine until I switched it off thought maybe I pressed a wrong button , I cannot seem to get the channels back , only saying no signal"
3 Suggested Answers
jdvillanueva
  • 2098 Answers
SOURCE: Panasonic TH37PX500 HD TV - we have broad "static
Hi cewilso,
Make sure that you have a good connection from your cable box. If the static lines didn't appear in Video mode then the problem is in the reception. Hook up properly the cable connection and ensure a good source of signal from your cable provider.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Feb 19, 2011
ekcnoel
  • 998 Answers
SOURCE: TX26LXD80 When switched on there
There is a problem with your t-con board it is the one that transfer image and get the signal from the logic board if this is faulty or not receiving signal to logic board it will produce gray and white screen try to check the 5volts dc supply and the 12volts supply if you are familiar with the electronic components and have proper equipment you can do it by your self but if not you can contact a technician to do it for you and save you from stress because this problem must be done in actual testing of the unit to check the real source of the trouble. Good day and best regards.
Posted on Aug 01, 2011
Magnavox converter box. How can I tell if the box is the problem or the TV? I have no picture, but it isn't the picture tube.
I assume that you are attempting to use the Magnavox converter box to convert digital TV signals received by your antenna system into analog signals for use on an older analog (non-digital) TV set. If that is the case then your first step at troubleshooting the problem should be to view the Magnavox installation instructions to ensure that the converter, antenna, and TV are all properly connected.
http://transition.fcc.gov/cgb/consumerfacts/setup-converterbox.pdf
Feb 23, 2015 | Audio Players & Recorders
Lost over half of the cable channels. How do I get them back?
set in air band, you want catv or cable band.
Aug 27, 2012 | Orion1934 19" TV
Have lost all my tv channels (only radio left). Signal strength is poor. What do I do?
Check and replace your aerial if needed.
If your aerial is OK along with the downlead/coax lead, check the TV by substitution and if it is the TV, repair/replace the Band IV/V tuner unit.
Hope that helps.
Nov 23, 2010 | Philips 32PF5531D 32 in. LCD Television
When i do a connection test on my ps3 it recognizes the ip address but it keeps saying this is a dns error
This is the problem with the ps3's broadband access.If it is the broad band problem the broad band may not be able to give much signal strength to over come the error or it can also occur because of a system failure or a crash
Jan 27, 2010 | Sony Playstation 3 (PS3) Console
Connection failed
First check your broad band's signal status by opening a DOS command by choosing run in the start up menu. type cmd and then type ipconfig. Next exit and open control panel, choose internet connection then click. Disable first broadband connection and plug out broad band's power supply. After that reconnect altogether and open a web.
Jun 23, 2009 | Dell Dimension 3000 PC Desktop
I get no stations on my tv
Use an Antenna that Provides Good Reception of All Channels
  • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
  • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
  • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
  • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
  • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
  • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at www.fcc.gov/mb/engineering/maps.
Check Your Connections
  • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
  • Ensure that your components are plugged in and have their power turned on.
  • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
  • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
  • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
  • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
  • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
  • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
  • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
  • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
  • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
  • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
  • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
  • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
  • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
  • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as www.antennaweb.org provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
Hope it may helps:
Regards:
VOTIT
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
I can not prongram my Real Digital RD2200 LCD TV
If you are using a cable box you will put you TV on chan 3-or 4 and use the box as your tuner. if you don't have a cable box it may be that the cable is at fault. The auto scan looks for any channel signal and will delete unused channels and lock in the received ones. If no channels are there only the strong ones will lock. The tuner in your TV works in bands or groups of channels and if it was a bad tuner the set would still find all the channels in the low / mid or high bands.
Jul 03, 2008 | Televison & Video
Cable channels 5 and 6
not sure on this model , but check your menu and see under the setup menu if it has a band select option or tuning band. sometimes the autoprogram may pick up the wrong band. Make sure it is set correctly. I had this where it would just make some certain channels bad.
Nov 01, 2007 | Zenith A25B33W 25" TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
