Question about Garden
Change an upper v belt on cox jackaroo ride on
I want to know how to change the upper v belt (clutch to engine)on my cox ride on. I can change the deck belt, but cannot work out how to get the belt onto the top pulley.
  • 1,169 Answers
Not to find any online IPL that I can access from here in the USA so I have no idea of how the drive belt is routed.
If it has an electric PTO clutch then you need to remove it so you can drop the engine pulley down to get belt off and on as the upper belt retainers will prevent you doing so if not done. If just a double stack pulley you will probably still need remove the retaining bolt so you drop the pulley as above.
Posted on Nov 15, 2014
  • 10865 Answers
SOURCE: Installing mower belt
The pulley at a wierd angle is the tension pulley. You may get the manual on line for free if you are lucky but not all mower manufacturers are that generous. What kind of mower do u have?
Posted on Mar 31, 2009
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 376 Answers
SOURCE: need to find illustration of mower deck drive belt
Posted on Jun 01, 2009
mowerman1857
  • 389 Answers
SOURCE: i am looking for a manual for a murray 12 hp 30 ride on mower
If you can find the model number sticker on the back of the tractor, somewhere around or under the seat (it will be formatted like this 123456x7y) then go to www.murray.com ,put in your model number it should come up and you can download and print and/or save it. If you can't find the model number, there isn't much else available for help.
Posted on Sep 28, 2009
  • 146 Answers
SOURCE: Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
Posted on May 28, 2010
Testimonial: "Thank you for your help. The belt is snapping clean. You are correct in your assessment to what the problem might be. We checked all the above and did not correct problem. We put three washers on top of small idler pulley to bring it down and better align routing. Bought heavier belt at auto parts. Believe the bolt head was touching belt where it routed throught to larger idler pulley."
Removing clutch cone from cox stockman ride on mower
Old question, but maybe this will help others:
Here is the answer for all Cox Stockman machines fitted with a single large bolt through clutch cone. Below it you'll find a VERY GOOD REASON WHY YOU SHOULD NOT DO IT!!!
1. Disconnect the negative (-) lead from the battery.
2. Loosen the four bolts that secure the engine and slide engine backwards.
3. Remove the 'R Clip' on the link rod at the front of the clutch carrier, then disconnect the link rod.
4. Loosen all four grub screws on the drive plates and slide them as far out as you can.
5. Raise the rear of the machine and secure with axle stands or some other method that will leave you with a SAFE WORKPLACE!
6. Remove the 9/16" locknut on the clutch pivot bolt (under the rear of the machine), then unscrew the pivot bolt. Do not try to drive it out with a punch, as it is screwed into the adjusting plate.
7. When bolt is removed, slide the rear of the carrier across to one side and the front of the carrier to the other side ( to clear the bracket at the front of the carrier) and work the whole assembly forward enough to clear the rear chassis rail. Then drop it down and remove the assembly from the machine.
To replace the cone, lock the large bolt head into a vice, then use a 2 or three pronged lock bar to unscrew the pulley from the bottom of the bolt. Then, fit a new cone onto the bolt and reverse teh entire process.
Now, here's why you should NOT DO THIS AT HOME!!!!!!!!!!!!!!!!!!!!!!!
If you don't read this part, I absolutely guarantee that it will end up costing you far more money than if you'd sent the machine to a Cox Service agent ( I am one).
About the only thing on any Cox machine that requires specialist knowledge and tooling to correctly repair, is the drive cone clutch system. Removing and replacing the drive cone itself is the easiest part of the process and I have seen it done by plenty of people. I've also spent plenty of time then fitting another new cone to their machine, because the one they put on is now stuffed. The drive cone is just one part of an assembly and if the entire job is not done correctly the FIRST TIME, the new cone can be destroyed in a very short time. And the only way to do the entire job correctly is to have the special tools and knowledge. No if's, no but's and no maybe's!
Oct 21, 2014 | Garden
Trying to change the drive belt on a GTX 2446 Troy Bilt garden lawn mower rider can't get the pulley upper plate of the motor
You must remove the electric PTO clutch in order to remove the motion drive belt. Also it probably require you remove the bolts holding transmission if your going and secondary drive so can it off and on.
Aug 09, 2014 | Garden
My jackaroo 3.5 petrol has just started struggling to climb the hill on the way home. Even though the engine revs are normal, the powere isn't getting to the wheels. I have it serviced, changed the pl
Could be your automatic gearbox clutches worn out! Time for a second-hand exchange gearbox, or a rebuild of the clutch section of the gearbox.
Apr 01, 2014 | 2003 Holden Jackaroo
2010 electra glide ultra classic, squeaking noise from primary side only when riding. Could clutch or, belt be the problem. Clutch engages smoothly with no acceleration problems. Especially noticeable on...
You need to determine whether the squeaking is being made by the engine, the primary, the drive, or the frame. While riding, pull in the clutch, does the squeaking stop or change in any manner? Is the noise there when the engine is running but standing still? Pull the clutch lever in and release, does the squeak change or stop.
If I had to say what I think it is, I'd say it's probably the rear drive belt is not tracking correctly due to the alignment of the rear wheel. Look at the rear wheel adjusters. They should be exactly the same on either side of the swingarm. Also, the belt must be tight. If not, a loose belt will make a squeaking noise.
Good Luck
Steve
Dec 26, 2010 | Harley Davidson FLHTCUI Electra Glide...
Mower deck clutch cable removal (model 917.28722). Detail provided in manual does not seem to match product. Need to remove this in order to remove deck and replace belt. Belt has squealed since new.
You should not need to remove the deck or the clutch cable just to change the belt.
  • ensure mower clutch lever is in the off position
  • lift the front of the tractor approx 24 or more inches.
  • lower the mower deck as far as it will go
  • locate & remove the cotter pin from the right (discharge) side mower lift arm where it attaches to the rear of the mower
  • release the lift arm from the mower deck to allow it to drop (it will hang from the other 3 points)
You should now have plenty of clearance to change the belt. Remove the belt from the engine pulley first and replace the new belt on the engine pulley last that will make it easier to change the belt.
If this is helpful please vote yes, Thank You!!
Aug 28, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
I have a victa corvette cox made ride on mower
Being cox made I'd go looking for cox manuals for the same era. Victa just rebadged others mowers.
Nov 18, 2009 | Garden
I want to change the transmission belt on a Cub Cadet LT 1045. Everything looks pretty straight forward except the engine pulley. It looks like engine has to be unbolted and lifted high enough to get the...
You can carefully bend back the guides on frame, push in the clutch pedel and secure it with a piece of rope or a bungee cord. (this allows slack in the belt to remove it.
If you wanted to loosen the motor which is time comsuming, you would need an impact wrench to loosen bolt on pto
Nov 15, 2009 | Garden
I RECENTLY CHANGE THE DRIVE BELT ON MY 46 INCH
Recheck your installation, make sure you have it routed correctly and it is good and tight when in gear and the clutch/brake released. Check this with the engine OFF and the spark plug wire disconnected
Sep 18, 2009 | Garden
I have a Craftsman 18hp Kohler engine. What is
there is no clutch drive belt needs replacing cost of drive belt $20.00
Sep 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
81 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
