Question about Vacuums
Can vinegar be use to decalcify steam vents ?
  • 2,210 Answers
Whats wrong with what the manufacturer advises? Is it too expensive? Can you use kettle de-scaler? Its only limescale after all. Ask your local stockist, he may know a trick or two.
Posted on Nov 15, 2014
How to get steam out Clogged h20 mop
Put vinegar in it and let it sit for several hours. Then turn it on to heat the vinegar. It should start to sputter and you may see some material ejected. This is good. Now dump out the vinegar and fill with water, make steam and let it push out any more material that caused the clog. You may have to do this several times in order to get the vinegar smell out.
Jun 28, 2014 | H2o TR220002 Steam Cleaner
May I use vinegar to de calcify my Rowenta commerical steamer?
Hi clbarnes2346,
Welcome to fixya!
The cleaning instructions recommend using a solution of 1/3rd white vinegar and 2/3rds water to decalcify. This should be done once a year or every 100 hours. Run for 3 minutes then empty water. Unplug and let cool down. Then rinse and repeat with fresh water.
For best operating, distilled water is the best to use if you have hard water.
Thanks for visiting with us. I'd appreciate your vote when you accept this solution.
Thanks,
Handie Andie
Aug 21, 2011 | Vacuums
My grey & purple steam mop is getting very little steam at the head. is there a way to clean it without damaging the product? or is there another solution for low steam?
Mixing white vinegar with water about a cup of vinegar and a cup of water ratio and let it steam through the mop. This is also good for steam irons and other appliances such as coffee/tea makers. The acetic acid in the vinegar will dissolve the calcium build up that blocks the steam ports and will not hurt plastic or floors. If you object to the vinegar smell, then mix a little lemon juice with the last cup of water and this rids you of the vinegar smell. I use the white vinegar to mop the wooden floors in the house.
Apr 17, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I was getting ready to iron a pair of pants that were polyesterrayon and 4% spandex. I thought I had my Rowenta iron turned down low enough but when I placed the iron on the pants they melted. Well...
First, UNPLUG THE IRON. DO THIS PART COLD. Clean the soleplate with scotch brite and WD-40. Next, you will have to remove the WD-40 residue from the soleplate with something like windex. Make sure you get around the steam holes.
Next-Plug it in and fill it with 50-50 mix of water and white vinegar. Set it for steam and let it run through. Refill it with plain water and steam it out again, until there is NO VINEGAR SMELL. This will clean the deposits out of the tank and steam vents.
Jul 04, 2010 | Vacuums
Can you use vinegar in the shark steam mop
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Yes, a bit off vinegar should not be a problem, but it may cause other problems...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
heatman101
Feb 01, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My purple Shark floor steamer is not steaming properly. What can I do? How about vinegar cleaning it?
Vinegar will not hurt it...
The heating element may have died or there is an obstruction...
heatman101
Jan 10, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam blaster jr. makes steam but has no pressure
yes no vinegar please. Try a product called scale clean or tablets for de-scaling coffee machines. Available from coffee machine retailers
Sep 19, 2009 | Euro-Pro Shark SC-505 Handheld Steam...
Can you disperse a water and vinegar mixture with the steam buggy, without causing damage to any part of the unit? can you disperse a water and bleach mixture with the steam buggy, without causing damage...
If you do this the vinegar will likely disperse hard water scale as it cleans the inside of the element. While it shouldn't stain anything it will likely cause sputtering as it breaks down the scale. If your goal is to clean and disinfect a surface that is vinegar friendly, I would consider taking the extra step of spraying the surface with a spray bottle with the vinegar. Bleach in steam might puff back at you in a cloud and burn your eyes and skin so be VERY cautious on the bleach.
Sep 16, 2009 | Tristar SB Steam Buggy Vacuum
My Europro shark steam mop won't steam, light on but no steam.
Hard water deposits. I ran some white vinegar through mine, like a coffee maker, and it worked for a while, but clogged again. So I unplugged it, let it cool and turned it over in the bathtub and squirted a small amount of Lime-Away into the hole where the steam comes out. Let it soak for 5- 10 minutes and it is working like is is brand new.
Sep 15, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam doesn't come out anymore when I pull the trigger. I think the water in the tank is getting hot, but when I pull the trigger, only a little water comes out. No steam
Try putting some white vinegar in the tank to dissolve any hard water deposits. You should use only distilled water in this machine. Don't try to clean anything with the vinegar in it, but take it outside to run the vinegar through.
Aug 15, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
