Question about Freezers
WIRING ON THERMOSTAT
MODEL NO 326 SERIAL NO 8605/1197
Wiring diagram model T-24-GC true serial 1-252491
Request the wiring diagram directly from True.
Feb 22, 2017 | True Freezers
Kelvinator freezer model kfu09m2aw2 won't get cold. could thermostat be bad
Yes it is. Just rotate it clock wise and vice versa and see it will work in case No then check the gas
Sep 25, 2014 | Kelvinator Freezers
Freezer serial # 845440256 age?
Replacement thermostats depends on whether the fridge is a double door or single door model. You can buy this part from your appliance parts store/supplier.
Feb 20, 2014 | Kelvinator Freezers
Having wiring problem freezer works but fans dont come on aod defrost timer dont kick in need a wiring diagram the serial number is . 88202021 and model number is . gf2ssd for a nor lake reach in...
I have a generic wiring diagram that I use on all my installs that works very well. It is basically the same for most all commercial walk in freezers. Send me a email address and I'll scan and forward what I have.
Oct 10, 2010 | Nor-Lake Freezers
I need to replace my thermostat on my ge chest freezer model #fcm7sudww, I lost the wiring diagram and I need help to rewire. Thanks
Wiring diagram of the chest freezer turned into chest fridge. The junction box is not required if all connections are made inside the fridge service compartment. Active (A) connection passes via latching relay terminals
inside the thermostat.
Additional information can find HERE.
Hope helps; tell us news.
Aug 05, 2010 | General Electric Chest Freezer FCM5SU
I would like to have a wiring diagram for a model 6125 freezer
http://www.delfield.com/docs/uploaded/del/manuals/archive/dm6000.pdf
Start with this web site. It has Delfield old manuals. Page 6 has wiring diagrams.
Hope this gets it for you.
Oct 20, 2009 | Delfield Freezer 6125XL-S
How can I get the wiring schematic diagram for a two door stand up traulsen freezer model # GLT 2-32 NUT, Thanks Erick.
call traulsen at 1-800-825-8220. Get tech support and give them the model and serial numbers. They will send you a diagram. Nothing on their web site.
Oct 02, 2009 | Traulsen 46 cu. ft. / 1303 liter...
Unable to adjust temperature with control dial
YOU WILL most likely need a new thermostat for the unit. What evere tripped the breaker apparently welded the contacts on the thermostat. take the model number and the serial number and the thermostat you have here's the part and the model number for you 21 # 216788100 Control-temperature please be sure to rate this soilution after your done. Have a happy new year>
Jan 01, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
WIRING DIAGRAM FOR MODEL 6125-S SERIAL 87-T[DIE]
here's a service and installation manual online click here it has a wiring diagram. good luck
Jan 03, 2008 | Delfield Freezer 6125XL-S
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
