How to disable the toner level sensor of a Aficio SP4100n
2 Suggested Answers
acoy
  • 102 Answers
SOURCE: How much the price of
the price is £330.96 (Exc VAT). you can dial this number for inquiries 0800 389 1304. here a link of this product click here
Posted on Apr 11, 2011
Why Ricoh aficio 2016 asking for toner when toner is full
please check that the toner unit is not choke with toner,
again, check if the toner motor is rotating,
also check if the buttom of the toner unit is designed to fit the toner motor.
finally check the td sensor .
this may be the major cuase of this problem.
good luck.
Jul 16, 2014 | Ricoh Aficio 2016 Black and White Copier
Ricoh aficio 1035 copier gives error code 390
TD sensor defective
TD sensor not connected or disconnected damage
Poor connection between the TD sensor and IO board
IO board defective
Toner supply defective
* Insufficient toner in developing unit
Apr 16, 2014 | Ricoh Aficio 1035 Copier
0F54H Fatal Error
Witam,
An error occurs on the toner level sensor for each color:
0F52H Toner level sensor /Y malfunction
0F53H Toner level sensor /M malfunction
0F54H Toner level sensor /C malfunction
0F55H Toner level sensor /K malfunction
Relevant electrical parts:
Toner level sensor/Y (PS13)
Toner level sensor/M (PS14)
Toner level sensor/C (PS15)
Toner level sensor/K (PS16)
Printer control board (PRCB)
Step Action:
1 Check the connector between each sensor- PRCB PJ21 for proper connection and correct as necessary.
2 Replace the toner level sensor of the corresponding color.
3 Change PRCB.
Feb 11, 2014 | Konica Minolta Magicolor 3730 Dn Color...
How much the price of one (1) unit Copier model Aficio SP4100N
Apr 11, 2011 | Computers & Internet
My copier mita dc 1860 did not control toner level, print is not clear
first clean the sensor in devloper unit and Replace Devloper to proper copy and check rotate toner tank or not
Jan 17, 2011 | Ricoh Aficio 1035 Copier
How repair error sc 590 in ricoh aficio 550
SC590: Toner collection motor error
-Definition- [B]
The toner collection motor sensor output does not change for 3 seconds while
the toner collection motor is on.
- Possible causes -
· Toner collection motor defective
· Too much load on the drive mechanism
· Poor toner collection motor connector connection
· IOB defective
· Toner collection motor sensor defective
Sep 06, 2010 | Ricoh Aficio 1224C Black and White Copier
Add toner ricoh aficio 2045
Toner supply is controlled with readings from TD sensor on the developing unit and the I.D sensor above the drum by default.
These are low cost parts and easy to change.
(The TD sensor on this model have been known to fluctuate back and forth by a fair margin so is a good place to start).
You could also try stripping down and cleaning out the toner hopper.
Check the four mylars are present and the grabber is opening wide enough to grab the toner bottle nozzle successfully.
Check the toner hopper exit slider is opening fully when the PCU is inserted.
I had one of these 'add toner' faults today and it was the toner hopper all clogged up inside.
The side bit where the toner drops down had hardened clumps of toner stuck around the side entrance mylar and the exit hole.
Check also the toner motor. I have seen these fail. Run simulation output check for toner motor. I would remove the toner supply unit and hold the motor when you run this simulation. Sometimes the motor turns but does not have enough torgue to turn the toner supply unit.
Mar 05, 2010 | Ricoh Aficio 2035 Copier
How to replace waste toner bottle for Ricoh Aficio w3600
1. Lift the original feed unit.
2. Lift the upper unit.
3. Right upper cover
4. Right cover [
5. Loosen the leaf spring and lift it.
6. Toner overflow sensor
7. Toner collection bottle
Once you have it out jsut dump it out (carefully) remove the sensor on the bottle and wipe clean reinstall the sensor re install the bottle and you should be good to go
Jan 21, 2010 | Ricoh CL3000E Laser Printer
Aficio SP4100N
Check the brown conveyor-belt inside the fusing unit. Maybe it has holes inside.
Dec 16, 2008 | Ricoh Aficio AP3800C Laser Printer
k24674
jasbo
jasbo
