Question about Savy Soda iSpreadsheet Free
I am making a an invoice for an agent in Savy iSpreadsheet Free, but after adding a formula as in excell it either says invalid or the whole program crashes on my iPad mini. How to fix this please?
I am making a an invoice for an agent in Savy iSpreadsheet Free, but after adding a formula as in excell it either says invalid or the whole program crashes on my iPad mini. I made rows with (A)date, (B)name guest, (C) total pax, (D) amount rooms,(E)nights, (G)cost in Rupiah. Formula in G2=SUM ((C2*50000+D2*250000+C2*50000+F2*50000)*E2) what is going on or goes wrong?
How to Set Up the Environment in Windows Excel 2013 to Write a Macro?
go google and type in -- user manual for excel--- there are some site that cover the whole manual all 900 odd pages and some sites that deal with specific areas
some are pdf versions so you can down load the section that you want rather then the whole publication
another google search is --libra office cal-search--- which is a free excel user manual, and I found to be better than microsoft excel and it uses the same terms and formula and the whole publication is free
again you can read the publication until you come to the chapter on macro and print out the pages that you want free
worth the read if you are a microsoft person
Oct 20, 2016 | Microsoft Excel Computers & Internet
Add information to grayed columns
any greyed out area is a non accessible are
either the spread sheet your are using is not advanced enough or that area is read only requiring an administrator's authority to access it
suspect that it is read only and is not for editing
if you go google and type in -- user manual for excel spread sheet-- there is a pdf version ( around 900 pages ) which has everything you need to know for excel spreadsheets
a good publication if you spend lots of time in excel as it misses nothing
May 11, 2017 | Savy Soda iSpreadsheet Free
What is the function of Microsoft excel?
Ok - if your question is "What is Excel" - then the answer is that it is a spreadsheet program that allows you the ability to compute data (usually numbers) for example, pulling together a list of hours worked by employees and adding them up automatically. It also can be used to develop sophisticated computational models and I have used it to develop professional services proposal sizing tools using formulas and functions ... which is a good segwey into my other answer.
If your question is "what is a function or formula in Excel" - then the answer is a function or formula in Excel is a collection of mathematical, text, statistical, etc. preprogrammed tools that allows you to manipulate the data you have in your spreadsheet e.g. a SUM() function that adds a series of numbers, and AVERAGE() funtion that computes the average of a series of numbers, etc.
Hope that helps!
Rgds
David
Oct 01, 2010 | Microsoft Office Excel 2007 Upgrade:...
I want the all excel formulas
You will never find a fully comprehensive list anywhere because there are literally hundreds in the basic Excel application and thousands that can be added in as you go via macros. More are being added every time a new version of Office comes out.
But, the easiest way however to get a basic list of functions if your not printing is to hit the function button and simply scroll down the list. The syntax (an example of the method by which you should be formatting the formula) and a definition will list in the bottom of the dialog as you select each function.
That said, you are better solving individual problems as you learn Excel then trying to memorize all the functions themselves. Many, such as mathematical operations are common sense anyway.
Jun 19, 2009 | Microsoft Computers & Internet
Excel
Step1. Start Microsoft Excelmag-glass_10x10.gif and open the file you want to change. Step2. Double-click on the cell where you want the total to appear. Step3. Press the = key on the keyboard. This tells Excel that you are entering a formula into the cell. Step4. Enter the formula, then press Enter. Follow the steps below for an example. Step5. Enter an opening parenthesis character: (. Step6. Enter a cell name. For example: =(E2. Step7. Press the + key. Step8. Enter another cell name and a closing parenthesis character: ). For example: =(E2+E3). Step9. Enter a minus sign and a third cell name. For example: =(E2+E3)-E4. Step10. Press the Enter key to accept the formula. The cell will display the sum of the first two cells minus the third cell. $('.Article .Steps .Image').each(function(i,e){ e = $(e); e.find('img').error(function(){ $(this).unbind(); e.remove(); }); });
Tips & Warnings
  • Formulas are just equations. Instead of adding or subtracting numbers you are adding and subtracting the contents of a cell.
  • Excel includes a number of predefined functions to use as well. You can combine the predefined functions into your own formula. (See "How to Use Provided Excel Formulas.")
I hope it helps!!!
Dec 03, 2008 | Microsoft Office Professional 2007 Full...
Circular reference working how to open excel file
Clicking cancel will invalidate the formulae, circular references refer to the dependant and precedent cells using each other.
Track/ Audit depending on your Excel version to show which formulae is incorrect - or options view, tick show formaulae and remove them.
Nov 20, 2008 | Microsoft Excel for PC
I need Excel's Furmula's
I found some excellent links to excel formulas for you:
This link lists excel formulas by category:
http://www.techonthenet.com/excel/formulas/
This link has some custom formulas for excel that you can download:
http://www.ozgrid.com/VBA/Functions.htm
Sep 20, 2008 | Microsoft Computers & Internet
How many formulas we can use at a time in Excel
That depends on which version of Excel you are using.
Excel 2003 supports up to 65,335 formulas
Excel 2007 has no limit.
you can communicate between the worksheets which are contained by one workbook (one excel-file).
Communicating between files cannot be done with formula's.
Apr 04, 2008 | Microsoft Excel for PC
Savy Soda iSpreadsheet Free Logo
464 people viewed this question
Top Savy Soda Apps Experts
Lesley Cameron
Lesley Cameron
ray gallant
Are you a Savy Soda App Expert? Answer questions, earn points and help others
