Question about Brookstone HDMI Pocket Projector
Repair Volume Control
Touch sensitive Volume Control to raise volume is not working
Volume control ultra sensitive. A touch can cut off a channel or cause a 'fuzzy' sound. How can I fix it?
Your pot is dirty. Pull the plug on amp and take the volume control and go from full low to full high back and forth about a hundred times.
Plug unit back in and turn on - it should be working better now. If you have electronic cleaner you can also squirt some of that stuff into the pot.
Sep 09, 2015 | Audio Players & Recorders
How can I reset the volume control? All of a sudden, I can barely hear with the volume set at max.
You do not mention the type of Motorola radio so this answer will be general. You may have a problem with your volume potentiometer, Receive (Rx) sensitivity, or a speaker problem.
The volume pot on a 2-way radio is a common failure item, and will after repeated use possibly fail, or get dead spots. Try backing off your volume to 75% and see if it is louder at this setting. If so, you have a bad volume pot.
Rx sensitivity can be caused by various internal problems with the radio,and some models are more prone to this than others. Operating your radio at full volume most of the time can bring this issue to the forefront. (Tip: Try running your radios at 80-90% volume vs. full volume to alleviate this problem.) If this is your issue, your effected radios are in need of repair. Most repair facilities (including ours) can correct Rx sensitivity in most models during a repair.
Speaker problems: If you work in an environment where dirt, debris or metal shavings can get inside the speaker, your speaker may fail over time. Or if you run your radio at full volume the majority of the time it can cause your speaker to fail.
Best regards.
Oct 13, 2014 | Motorola Walkie Talkies 2-Way Radio
03 Escape radio volume raises by itself. What could be the problem ?
Assuming your truck has cruise control, this has been a common thing with these vehicles. The radio's volume is designed to increase if the vehicle's Body Control Module sensed that:
-you rolled a window down
-you accelerated
Ford's recommended repair is to reprogram the BCM. Runs about $90-120 at most dealers.
May 08, 2014 | 2003 Ford Escape
Sound gets muted on its own,volume goes up & down automatically
As far as I know, it has a sensitive volume control, so sometimes the user touch that area by accident.
Feb 20, 2014 | HEWLETT-PACKARD Pavilion DV2046TU Laptop...
The volume control on my casio px-120 does not work. I can hear the speakers crackle when I try to adjust the volume but the music stays the same.
ok your volume control has bit/dust in it you need to strip it down as best you can and spray wd-40 into the control this will release all the grit in the control knob (trim pot) and should work fine then..
Jun 18, 2010 | Casio Portable Keyboard Touch Sensitive...
Describe your Touch-sensitive controls for volume
Try reinstalling the software that controls the audio. You can find it on the Dell Website.
Jun 03, 2010 | HP Elitebook 8530p Notebook
The touch-sensitive volume control on my EliteBook 2530p is impossible to control. There is a major delay between when you move your finger and when the volume changes, and volume jumps from minimum to...
Hello there!
I dont think it should be working like that, although you could read some forums about that type of laptop and see other people experiences. Try to clear sensors from dust just a bit, to fast a motion. Also do you use any drivers for that software under xp? there should be drivers for that hardware.
Sincerely
Aleksandar Adzic
Apr 16, 2010 | HP EliteBook 2530p Notebook
Samsung Pixon touch screen frozen
The issue of touc screen freezing in he M880 is mostly due to fault in the contact. The screen contact is just below the volumen control buttons on the right. I inserted a fingre nain where the volume control is and pulled up the screena wee bit. near the volume up botton, I then inserted the tip of a tooth pick. It worked and the touch sensitivity is just as new :)
Sep 09, 2009 | Samsung M8800 Pixon - Unlocked QuadBand...
Unable to change the volume using the "touch sensitive" pads
This problem has something to do with electrical grounding. I found a solution from cagamba of Brazil deeper in this site. With one hand, touch the audio outlet at the back of the computer and with the other the JBL volume touch control. It has worked for me.
Jul 24, 2009 | JBL CREATUREIIWHITE Computer Speakers
Shortage?
There is a ribbon cable between the laptop & the screen. It sounds like you have a short in that cable. If you're not good with tedius electronic repairs, it would be best to have a shop repair it.
Mar 25, 2009 | Gateway Computers & Internet
Brookstone HDMI Pocket Projector Logo
67 people viewed this question
Top Brookstone Office Equipment & Supplies Experts
Tom Chichester
Are you a Brookstone Office Equipment and Supply Expert? Answer questions, earn points and help others
