My 42 inch hisense is making a static sound from the front or back when low or high how to make it stop
  • 3 Answers
Hi there, move it away from where its standing to another corner, you probably have some electric interference from the wall.
Posted on Nov 15, 2014
  • Latesha Nov 16, 2014
    Thanks for the response.
    So far the noise stopped on its on.
4 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: My 42" phillips will all
It can be the unstable power supply, bad sound processor or power amplifirers problem, you will have to open it up and check the inside starting at the DC outputs of the power supply module first, you may have to replace the main board since it contains, the video processor, tuner, audio, T-CON driver.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Oct 02, 2010
gopakumarg43
  • 75581 Answers
SOURCE: I have a hisense 42 inch plasma and it comes on
Check its main power switching regulator boare. Replace it as card basis.
Posted on May 23, 2012
dduncan774
  • 760 Answers
SOURCE: My hisense 50 inch lcd tv has picture but no sound.
If you still have back light, then the T-con is probably defective. If you don't have back light, then you either have a bad power board/inverter or a defective panel
Posted on Mar 20, 2013
I have a new 50 inch 4k hisense tv that makes a buzzing static sound all the time. I tried adjusting sound settings but not having any luck.
If it is new I would definitely insist on having the matter investigated and repaired under warranty. It should not be doing that!
Aug 28, 2015 | Hisense Televison & Video
Regular hisense TV 42 inch remote stopped working need to change input buttons on bottom help
Hi
Anonymous, It is the remote hand set which goes bad. Please have the hand set checked for defective crystal oscillator, old batteries, and failed IR LED. There may be some internal damage due to falling also.
Jun 13, 2015 | Hisense Televison & Video
How do I fix the sound on my 42 inch tv
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Sep 24, 2014 | Hisense 42A320 42-inch 1080p 60Hz LED HDTV
My Hisense 32" inch tv has started making a popping sound and is static and it turns off then turns on and load then "pop" it off and it does it again then turns on stays on for about 10 mins with no sound...
Sounds like you have a bad power supply board. Either replace the TV or get it fixed (probably not worth spending too much on considering how cheap new 32" TVs are now).
Nov 29, 2013 | Televison & Video
Mar 20, 2013 | Hisense Televison & Video
My 29 inch crt has sound but no picture
Sounds like a high voltage power supply problem. With the TV on, check to see if CRT has a static charge on face of screen by placing back side of hand in front of it and feel for static charge. Also you could hold a piece of tissue paper in front of the screen to see if static electricity from the CRT attracts it. If no static charge is present, the problem is more than likely in the high voltage power supply. Unless it is something simple, like a loose connection, it would probably be cheaper to replace the TV. Do not probe around in the HV power supply while the TV is on--it could prove deadly.
Dave W.
Sep 14, 2012 | Samsung CW29M64NS 29" TV
HSL4229HDIP 42 inch LCD intermittent lip sync problem
Hi
Try Buying a aerial with a booster, u can purchase a inline booster at dicksmith or most large electrical stores.
kinds regards Kyle
u can reach me at
kyle-stelzer@hotmail.com
Apr 20, 2009 | Hisense Televison & Video
Plasma tv makes loud static noise screen goes blank and shuts off
Take the back off and try to isolate where the sound is coming from.
Nov 24, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
VIEWSONIC VPW425 42' PLASMA SOUND FADES ALL THE WAY OFF
I have a brand new Panasonic 42" tv, once in a while the sound fades out and then fades back in right away. I have it hooked up to a high def cable box with high def cable.
Jan 16, 2009 | ViewSonic VPW425 42 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
