I have the bizhub 501 model the toner motor is not working
HOW DO I CLEAR C3806 ERROR CODE ON BIZHUB 501? PLEASE FORWARD ALL DIAGNOSIS CODE
Fusing main temperature low sensing.
clean TH1-Thermistor.
Power ON machine by pressing Utility Button.
and hold for 15 to 20 seconds.
Touch TROUBLERESET once appear.
now restart machine from main Power which is under Toner Door
Dec 21, 2016 | Konica Minolta Bizhub 501 Copier
Code irror 2702
If you wish to get some details; check the site linked here. Pull up older posts.....
http://electro-medical.blogspot.com/
Apr 26, 2016 | Konica Minolta BizHub 360 361 420 421 500...
I have one photocopier bizhub 501 and have error code 2801/03..Can you help me? thnx
Take the toner bottle out. Then you will need to remove several cover to gain access to the sensor way in the back of the where the toner bottle goes and clean that sensor. might even need replacing.
Aug 25, 2015 | Konica Minolta Bizhub 501 Copier
Hi. i have bizhub 350. my problem is the toner hopper is not spinning/rotating. hv already changed the developer,the toner replenishing box and the drum assy, whole unit. what seems to be my problem here....
Sir, the toner bottle motor assy. needs to be replaced. will take quite a bit of work to get to, recommended a service tech qualified on Biz hub 350. This series is well known for the toner bottle assy. fault as is the di3510 series prior to the Bizhub 200/300 series.
Mar 25, 2015 | Minolta bizhub 350 Black and White Copier
Develop ineo 501, machine stopped, showing " have the fusing unit replaced soon, contact the service representative" -no error code. There is also "license management error occurs" but this promt was way...
that unit is manufactured my konica minolta. it is a Konica Minolta Bizhub 501 and will use the same fuser even though the image units, toners, and transfer belt have to be chipped for the ineo. There is a picofuse in the fusing harness that blows as soon as it is installed and that starts the fuser life counter. the counter is reset when a new fuser (or new fuse, if the fuser is still good) is installed. You will need to replace the fuser for the message to go away.
Jan 05, 2015 | Office Equipment & Supplies
Find release for Bizhub 501 drawer
Sir, draw release is in the back power off the machine and stick a thin screw driver in the hole(Located behind the big draw) to release the large capacity draw!
Nov 03, 2014 | Konica Minolta Bizhub 501 Copier
C2801 konica minolta bizhub 501
TCR output abnormality. What is the status of your consumables (drum and developer)? You might need to replace the developer. Also, you should check if the toner bottle is turning; you should see it turning while the front cover door is open and the machine operates; if it is not turning, it is possible that the toner bottle was inserted wrong (by force).
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 15, 2014 | Konica Minolta bizhub Office Equipment &...
My konica minolta bizhub is showing toner finish even after replacing a new toner
Sir/Mam
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KNUB on the side of the bottle is damage put a new one in. That KNUB is what the toner motor uses to turn the bottle, if it damaged you get a code. If that does not work, you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad.
Feb 05, 2014 | Konica Minolta bizhub 180 All-In-One...
Konica bizhub 501 take code c2806
actually code c28xx have 7 variant. for example, c2801, c2802, c2803 (error 3,4,5,6) and c2804. if follow the code code c28xx is TCR output abnormality.
ok, first you clean T/S block, do servicing and cleaning all parts.
second, if still same, do toner auto supply.
third, trouble reset. off your machine first, press and hold utility/counter and on machine, until trouble reset appear. press it and off/on again. ^^,
Oct 05, 2013 | Konica Minolta Bizhub 501 Copier
How do I replace staples in bizhub 501
Open doors where toner is located.
Deep in the left cavity, you should find a brown unit in which the staple cartridge is located.
Carefully slide the unit towards you and when it reaches the edge, you can gently lift the blue handle and remove the empty cartridge.
Press each side and the spring will lift allowing you to remove the empty white cardboard staple holder. The arrows are to point away from the blue handle.
replace-staples-in-bizhub-501-ycf3eytmg1avdtjejiecbwdh-5-0.jpg replace-staples-in-bizhub-501-ycf3eytmg1avdtjejiecbwdh-5-1.jpg replace-staples-in-bizhub-501-ycf3eytmg1avdtjejiecbwdh-5-3.jpg replace-staples-in-bizhub-501-ycf3eytmg1avdtjejiecbwdh-5-6.jpg replace-staples-in-bizhub-501-ycf3eytmg1avdtjejiecbwdh-5-10.jpg
Feb 20, 2013 | Konica Minolta Office Equipment & Supplies
29 people viewed this question
jasbo
jasbo
