Question about Home
Wood Burner Flue & stone fireplace building.
I need pictures and information on how to connect and seal the rigid and flexible flue to an inset fire and how to mortar the stones together when building a stone fireplace with large chunks of finely dressed stone.
    Master:
  • 742 Answers
You might want to have a professional take care of that. Wrong move and your going to burn your house down
Posted on Nov 15, 2014
  • David Talboys Nov 15, 2014
    Not very helpful when you live in a part of the world where no 'experts' exist or can be trusted.
I have a free standing wood burning stove Hearth Stone brand Is there a product that one could wrap the chimney flue with to avoid a small child from burning its hand? Thanks
There is a completely double insulated flue pipe available on the market by SELKIRK and more
INSULATED stove pipe DIY CHIMNEY FLUE - YouTube
? 4:06
https://www.youtube.com/watch?v=D6AHJ_XbOCo
Oct 19, 2011 - Uploaded by ROCKNTV1
CHIMNEY FLUE DOUBLE WALL INSULATEDhttp://www.rockntv1.com/2011/10/insulated-stove-pipe-diy .. And see google for vendors
Nov 29, 2015 | Home
What is the max flue temp for a rheem xg50t06py42u0 water heater. High flue temp is distorting the pvc flue.
PVC pip manufacturers DO NOT recommend PVC pipe for flue gases. Some gas appliance manufacturers do, but this is no guarantee of safety. Here is a link to an article you may find informative on the the subject.
Using the fireplace can melt the heating systems PVC vent in another flue...
Nov 02, 2015 | Rheem Water Heaters
I need to build a hearth for my Waterford 106 Wood Burning stove. How big should it be? Especially, what did Waterford recommend when it built this stove?
Anyone heard of a Waterford 103? ' Hearth.com Forums Home
www.hearth.com/talk/threads/anyone-heard-of-a-waterford-103.9653/
Nov 28, 2007 - Hello, I'm new here and I have a stove in my house that arrived with no... Does anyone know anything about this stove? Coal? Wood? Age? Make? ... The 103 was a wood-burning "Fireplace Stove" from the mid-80's. Installing an insert without using 6" flue liner tube because of ...
Sep 23, 2014
Looks like it's officially 24/7 burning time...
Dec 10, 2009
More results from www.hearth.com
Wood Stove Hearth on Pinterest ' Corner Wood Stove ...
https://www.pinterest.com/explore/wood-stove-hearth/
Pinterestfrom My Paradissi ... decorating around a wood stove ' Cosy wood burning stove fireplace: how to decorate around it. love the ... 893 106 ... wood burning stove hearth ideas ' old wood stove on brick hearth by Brian Powell - Stocksy United . .... Corner Wood Stove Surrounds ' How to Build a Hearth for a Wood Burning Stove.Missing: waterford
Oct 21, 2015 | Home
Even if it was a wood burning fireplace from the beginning & was converted to gas ?
Now that's a LOT of additional information. I hesitated to answer your question the way it was worded originally.... IF in fact it is a masonry chimney and originally built to burn wood, you should have a chimney sweep do a thorough inspection of the flue to ensure it is safe to use again. Flue temperatures, while burning wood, EASILY exceed 1200 degrees whereas natural gas flue temps are in the 450 degree range.
It also should have a clay tile liner and not be fabricated of brick only. The unsafe thing of an unlined brick chimney or a chimney with a severely cracked liner has to do with unburned gases condensing within the inner surfaces of the chimney. Some of those gases are moist and will condense on the inner surface and eventually have an unsafe build up that can be ignited by an oversized flame or excessive sparks causing a flue fire. During a flu fire, temperatures exced 2000 degrees and an unlined BRICK flue of that age could have lost some mortar allowing superheated gasses to seep into the crevices. Those superheated gasses then explode when igniged by the flue fire and either do extreme damage to the flue, blow the entire chimney apart or in the worst case scenario burn your house down.
I'm sure you've seen houses burnt and the chimney was left standing....but you have also seen damaged houses with the chimneys blown off the end of the house and laying in rubble toppled out into the yard. The latter visual picture was an example of the end result of the gasses exploding. If the chimney was inside the house instead of on the end of the house, the house would have been burnt also.
There is a lot to be careful about when heating with wood and to start off safely you need to have your chimney inspected and the gas components removed with the gas line capped EXTERNAL of the fireplace.
Dec 08, 2014 | Home
Can't keep the wood burning in stove. How does the buck stove take in air?
To burn properly, it needs proper combustion air and proper draft. Draft is effected by the size and height of the flue the appliance is connected to and by how much combustion air is available. The appliance flue connection should not be reduced to fit a smaller chimney size. That is, an 8" flue should not have an 8 x 6 reducer to vent it into a 6" chimney.
The wood you are burning could contribute to a poorly burning fire. To burn properly, the wood needs to have been "seasoned" for a minimum of 1 year or close to it. Two years is even better. "Green"
or freshly cut wood contains an unbelieveable amount of moisture in it and a tremendous amount of the heat is wasted just "preheating" the wood to the temperature that causes it to release gasses for ignition.
I don't know the style or model of your Buck, but all wood burning appliances should have combustion air dampers of either a sliding design, rotating round design or hinged design with handle at the bottom front of the firebox. I'm sure there are some fancy new designs that have air piped in from outside the structure.
Every wood fired stove, fireplace or furnace has its own idiosyncrasies and its up to the user to determine what's required for making it operate as designed.
Dec 06, 2014 | Buck Stove Home
Can one use unvented gas logs in a superior CF3860 fireplace?I
Little documentation on this fireplace but it appears to be a vented wood-burner(?) If vented, there should be no problem using gas logs. If burning correctly, you may consider cutting back on the flue and intake air, as moisture build-up is the biggest drawback to gas fireplaces. Too much air is just wasting gas.
Dec 03, 2010 | Heating & Cooling
I have just opened up my chimney and took it back to the bare bricks and was giong to install a wood burner but decided to fit a gas stove instead. there was originally a gas fire installed so it has a...
You will need to install a flue liner ( i know its a nuisance) to allow the products of combustion to escape as quickly and as safely as possible.
If you installed a gas appliance without a liner, due to the temperature of the flue gases (lower than solid fuel) the emissions would struggle to exit via the flue terminal.
If you install the appliance following the manufacturers instructions, you cannot go wrong. The other recommendation is get a 'Gas Safe' engineer to carry out the commssioning/testing.(house insurance void if not certified)
I hope this helps.
Jul 07, 2009 | Ovens
How change a Marco Fireplace from wood burning to gas logs
HI best get as gas fitter in to look at this and see if it can be done safer bet
Dec 14, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Home Logo
95 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
