Question about Cell Phones
Activate com ports
Can not connect to bluetooth
How do i connect the bluetooth?
depending on your device usually there will be a bluetooth connection on the device which plugs into a usb port on your computer
you will have to make both your computer and the device enable bluetooth connection(make it discoverable) you might need to download some bluetooth drivers or software to activate your blutooth device
http://download.cnet.com/%7Bvalue=http://www.download.com/bluetooth-driver-ver-5/3000-2110_4-149801.html
to suit multiple usb devices
ยท Operating system: Windows 95/98/2000/XP/2003/NT/XP 32-bit/AMD 64-bit/2003 32-bit/AMD 64-bit
hope this helps
Aug 24, 2011 | ASUS Computers & Internet
Hello...i am using sony ericsson k550 i had a trouble in that i cant send any files through bluetooth my bluetooth is not working pls any one tell how to solve this prob
Make sure your phone and the other Bluetooth device are charged, switched on and within range of each other. Make sure Bluetooth wireless technology is turned on, and that the devices are set to be visible for other Bluetooth devices. Check that the two devices are paired, and have found each other. If there are still problems, you'll have to reset the connection and pair the two devices again.
In some Bluetooth installations, you must activate a COM port manually in your computer. This is done differently for different brands and models of Bluetooth devices. Please see the manufacturer's product documentation.
If a COM port is not activated
1. In many cases, you can right-click on your phone icon in the window where all found Bluetooth devices are shown, and select a 'COM port activation' item in the menu. Make a note of the COM port number of the activated port.
2. Open Sony Ericsson PC Suite and click Tools/Phone Monitor Options.../Com Ports. Enable the COM port you activated in step 1.
3. Keep the Bluetooth wireless technology turned on in your phone, restart the computer and try to connect again.
Feb 08, 2011 | Sony Ericsson K550i Cellular Phone
Internet setting on samsung E1410
Hi there ,
It is possible to connect this phone (E1410) to the PC for Internet facility. You just need a bluetooth device.
I have successfully done it on my Airtel sim card using MO (Mobile Office) package.
Follow these steps-
1. Don't call the Airtel Customer Care to activate Mobile Office Setting. Because they will tell you that your handset does not support automatic MO setting.
2. In your phone go to browser and go to Browser Settings
3. Create a New Profile with the Name- Mobile Office
4. Home Page- http://www.google.com
5. Set the Proxy as- 202.56.231.117
6. Set the Port as- 9201
7. Bearer- GPRS
8. Go to Advanced Settings and type the APN- airtelgprs.com
9. Log in ID and password no need.
10. Recharge your your phone with any GPRS (Mobile Office) packages Rs.22 (200MB)/ Rs. 98 (2GB-30 Days validity).
12. From your mobile dial *567*11# (This is must)
13. Now your MO is activated. Now turn off your Phone, Remove the Sim card and turn on again.
Please cancel the mCheque msg. if it appears after restarting your phone.
14. In your PC -Install the Bluetooth Driver.
15. Right click on the Internet Explorer-Properties-Connections
16. Select the Bluetooth DUN Connection
17. Click on Settings
18. Set the proxy-202.56.231.117 ;port as-9201
19. Click -OK, Apply - OK.
20. Now go to control pannel and double click on Phone and Modem options.
21. Click on Modems tab.
22. Select Bluetooth DUN Modem
23. Click on Properties
24. Click on Advanced Tab
25. In the Extra Initialization Command box paste the following command line-
AT+CGDCONT=1,"ip","airtelgprs.com","",0,0
26. Click OK, then Apply-OK.
27. In your phone turn on the Bluetooth
28. Insert your Bluetooth Device in Your PC and connect Your phone through the Bluetooth software
29. Click- Bluetooth Dial up Networking Service on your Bluetooth Software
30. The dialing number is *99#
31. Remember the connection may not done for the first time. So you may need to try more and more. Because the Airtel lines are always busy. Sometimes you may need to unplug your Bluetooth device and
exit your BlueSoleil from the Quick Lunch bar and Restart the Procedure. Remember this is the only procedure
for Airtel (MO) users. Try and Try and if it is connected the open any browser (I prefer- Mozilla Firefox) and open- www.google.com. Remember in some cases, it shows a false connection and the website will not open.
In such cases, Disconnect your Dial Up connection and Re-connect it. If any message apper in you phone, then exit it.
32. To check Mobile Office Package balance and validity dial- *123*10#
32. Remember I am sending this information to the internet via Connecting my E1410 mobile to my PC using Bluetooth device.
33. If you are successful, please say a little word-"Thanks
Sep 26, 2010 | Samsung Lands Phones
I cannot activate my bluetooth in my pc. please tell me steps to install and activate my pc bluetooth
Is this a laptop with built in bluetooth reciever? because if it is not, you will have to buy a bluetooth usb dongle for your pc and install it in order for your phone or other bluetooth device to communicate with your pc. A desktop pc does not have a bluetooth reciever built into unless otherwise stated by the manufacturer. 99% of all desktop systems do not come with bluetooth recievers.
you can find reasonable bluetooth usb dongles here:
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=bluetooth+dongle&x=0&y=0
Once you have one, it's usually as easy as just pluggin it into an open usb slot on the back or front.
USB is a rectangular shaped port on your computer, there are usually atleast 4 ports on the bakc and 2 on the front, the front ports can be hidden under a plastic panel, or at a 45 degree angle downwards toward the desk as is in some dell models.
Jun 17, 2010 | Microsoft Windows XP Professional for PC
When i ture my bluetooth something popup that you must set bd address please help me
The address isn’t something that can be set, that’s a MAC address - it’s the unique identifier for the bluetooth chip on the phone (all network cards have them).
I would hazard a guess that either your bluetooth stack on the phone is goosed or the chipset itself.
OR
Try this:
Turn the Bluetooth Off, disconnect it from the PC, turn it on, re-connect it to the PC.
Go Start -> (All) Programs -> QPST -> QPST Configuration.
Click on the PORTS tab.
Bluetooth Address:
Since you upgraded the phone, you already have the usb drivers.
Now, launch the QPST configurator.
Click on "add new port"
Type the port number your phone is using now. (you put it COM5, COM10, etc, its just one example) -----------------If you already added your port in QPST then skip this.
Now, launch the NV editor, maximize the window.
on connect, select the com port, and press connect server.
press the file button and select upload all from mobile
Then, press the search button, and type "447"
Move the file to the "selected" window.
Once you double click it, in another window you will see loads of firlds with 0
Change the to 1, all of them.
also, change the string value to "true"
Now, you press the "file" button and press "download selected & active to mobile"
Disconnect the server, close the program, unplug the phone, and restart the phone.
Now, try to enable the bluetooth.
Remember, once you do the 6th image step, you go to connection and select disconnect server.
All fixed!
Good Luck & Thanks,
Shiv.
Aug 20, 2009 | LG Shine KE970 Cellular Phone
Not able to connect to BT Homehub wireless Toshiba Satellite Pro
  1. Click the Start button getcontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=signed1, click Control Panel, and then double-click Bluetooth Devices.
  2. Click the device that you want to change, and then click Properties.
  3. Do any of the following:
    • To change the name of the device, click the General tab, type a new name, and then click OK.
    • To enable a service, click the Services tab, select the check box next to the service, and then click OK.
    • To disable a service, click the Services tab, clear the check box next to the service, and then click OK.
    • To make your computer discoverable to Bluetooth enabled devices, in the Bluetooth Devices dialog box, click the Options tab, and then select the Allow Bluetooth devices to find this computer check box.
    • To make Bluetooth enabled devices discoverable to your computer, in the Bluetooth Devices dialog box, click the Options tab, and then select the Allow Bluetooth devices to connect to this computer check box.
    • To be notified when a Bluetooth enabled device wants to connect to your computer, in the Bluetooth Devices dialog box, click the Options tab, and then select the Alert me when a new Bluetooth device wants to connect check box.
    Warning
    • To help protect your computer, only make your computer discoverable when you want a Bluetooth enabled device to find your computer.
Some computer programs require a COM port (also called a serial port) to communicate with a Bluetooth enabled device. For example:
  • A program that synchronizes contacts with a mobile phone
  • A program that extracts Global Positioning System (GPS) coordinates from a GPS receiver
When you use the Add Bluetooth Device Wizard to add a Bluetooth enabled device to your computer, you create an incoming COM port, which permits your device to connect to a program on your computer, and an outgoing COM port, which permits a program on your computer to connect to your device. Usually, you only need to use one of these COM ports.
To decide which COM port to use, you can check the information that came with the program or your Bluetooth enabled device, or go to the manufacturer’s website.
If you're still not sure which COM port to use, try each COM port, one at a time, and use the one that successfully allows the program and your device to communicate.
Mar 31, 2009 | Toshiba Satellite Pro L300 Notebook
Setting bluetooth on a Epson stylus SX600FW
the bluetooth dongle for your printer is sold separately. call epson store to get one.
Jan 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Active Sync. on an MDA Vario 3
i had this problem, everytime i refreshed the mda the pc showed that the phone was connecting then once the mda vario had stopped the connection was lost, what i did notive was that the com port for active sync showed up on my pc as com port 4? which isnt a choice on the mda as there is only 2 ports available com 6 and com 7, what i did was to add new serail services to the pc until i was given com 6 as a choice,(because by default the pc starts off as com 4 then com 5 etc, so goto the bluetooth configuration then click on client apps and keep adding new service until you get com 6 then try and sync via activesync on your phone, if that doesnt work make sure that you have added new bluetooth device which gives you options of what services you would like the phone to use with the pc, click activesync then configure it to connect on com 6 voila that should work fine iv just updated mine to netframework 2.0 and can now run all the apps i want, any problems email me on iwannatoken@hotmail.co.uk il be happy to assist any way i can as i was stuck on this problem for ages and ages until i finally solved it hope you succeed.
Mark
Aug 31, 2008 | T-Mobile MDA
I thought I had Bluetooth in my computer...
Yes, you can use bluetooth mobile devices. COM 3 os the port that the bluetooth uses to connect to a device. You can think of it like a wireless modem. You can also configure other COM ports for communication with bluetooth devices using the connection wizard. I would suggest not to do this unless you know what you doing. From my experiences with bluetooth devices they can b a little touchy, and you have to careful you don't want to pick a port that another program is already using. ConfigFree is capable of configuring this bluetooth connection, but there are also other programs out there that you can use as well.
Nov 07, 2007 | Toshiba Satellite A105 Notebook
Imate jam PC synch
dear abid, connecting the i-mate to computer using bluetooth is a good and a fast way and give you the an option to connect more than one device, you can connect through bluetooth with this procesure : step one: set up a bluetooth COM port : 1- Open the Bluetooth Devices Control Panel. On the Options tab, select Turn discovery on and Allow Bluetooth devices to connect to this computer. 2- On the COM Ports tab, click Add. 3- Select Incoming (device initiates the connection) and click OK. 4- Note the number of the COM port that was added. The COM port number must be no higher than 20. 5- Click OK to close the Bluetooth Devices Control Panel. step two: 1- In ActiveSync on the PC, on the File menu, click Connection Settings. 2- Select Allow connections to one of the following. 3- Choose the COM Port with the number you noted in Step 1 Set up a Bluetooth COM port. 4- Click OK. Step 3 Start Bluetooth sync from your device: In ActiveSync on the device, tap Menu, then tap Connect via Bluetooth. that's all... and i am waiting for your replay
Jul 27, 2007 | i-mate JAM Pocket PC
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
