Lands Phones Logo
C
CHAD LAZAGA Posted on Nov 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Panasonic kx-tc1450b handset no link to the base. how to register my handset to the base?
Panasonic handset no link to the base,, how to register?
No_ky
Level 2:
  • Expert 59 Answers
  • Posted on Nov 15, 2014
No_ky
Expert
Level 2:
Answers
59
Questions
0
Helped
26227
Points
197
Google the manual (PDF) If no luck-repair by replace RF unit from old donor :) or better buy new phone.
How do I get my older Panasonic hand set phone to ring on an incoming call?
The KX-TGA401C handset works with the KX-TG401x, KX-TG403X and KX-TG651x phone systems among others. If you have the appropriate base, see the suggestions below.
Does your handset read Ringer Off? Try setting the ringer volume. With the phone system in standby (no calls in or out for any handset), press Menu. Navigate using the Up/Down arrows to Initial Settings. Press Menu/OK. Navigate to Ringer Settings and press OK. Press OK again to enter the Ringer Volume sub-menu. Use the Up/Down arrows to set the ringer volume and press OK to save. Press Off to exit the menu system.
The other possibility is that the handset is not registered to the base. Note: only 6 handsets can be registered to the base. If you previously registered 6 handsets, you need to deregister some of them.
To register the handset, hold the handset near the base since you will need to press buttons on both. Press Menu on the handset and navigate to and enter Initial Settings. Navigate to Registration and press OK. Navigate to HS Registration and press OK. On the base, press and hold the Locator button for 5 seconds and the registration tone sounds. Press OK on the handset you are trying to register. If all the registered handsets start ringing, you triggered the Locate handset function. Press the Locator button again. Then do the press and hold step again. Only press OK on the handset when you hear the registration tone.
You can find the manual for the KX-TG4011 here: https://shop.panasonic.com/support-only/KX-TG4011N.html . The direct link to the manual is https://ftp.panasonic.com/telephone/om/kx-tg4011_mul_om.pdf . See page 21 for the directions to set the ringer volume.
I hope this helps.
(You can't register a handset to an incompatible base. The communication protocols don't work.)
How do I install my Panasonic KXTGA401 phone?
The KX-TGA401 is a handset for specific Panasonic cordless telephone systems. Connecting the handset requires registering (pairing) it with the base and if the base can support another handset. First make sure that the base is plugged into an active phone line (land line) and that the power adapter is plugged in and working properly. Charge the handset before attempting the registration process.
Then make sure that the phone system is in standby (no calls). Press and hold the Locator button on the base for about 5 seconds (wait until the tone sounds). If all of the handsets that are already registered ring, press and release the Locator button and then press and hold it again. Once you hear the registration tone (some models), place the new handset in the charger on the base. Wait for the long beep and the registered symbol to appear.
If the not registered symbol appears, try registering by using the handset menu. Press Menu # 1 3 0 (the key below 9 and individual number keys) on the handset. Press and hold the locator button until you hear the registration tone as above. Then press Select and Save on the handset within 90 seconds of hearing the registration tone. Wait for the handset and base to complete the registration process. You'll hear a long beep.
The first registration method is given in the manual for the handset, http://help.panasonic.ca/viewing/ALL/KX-TGA401/OI/TGA401_PNQX2390ZA/TGA401_PNQX2390ZA.pdf. The second is from the page 31 of the manual for the KX-TG653x (KX-TG6531 base) system, ftp://ftp.panasonic.com/telephone/om/kx-tg6511_mul_om.pdf . The KX-TGA401 handset works with other bases as well. You may want to check the manual for your phone system in case there are differences. Other compatible phone systems are the KX-TG401x, KX-TG403x, and KX-TG651x.
I hope this helps.
(I make sure that the land line is active by checking for dial tone with an old corded phone.)
1helpful
Can I get replacement phones (3) for Panasonic KX-TG6843B 6.0 3-Handset Cordless Telephone? This phone blocks up to 250 calls. If I keep the base, will I keep my blocked numbers.
The stored block numbers should be saved. The database is in the base's memory. Since the KX-TG6843 base can support a total of 6 KX-TGA680S handsets, you can purchase and register 3 new handsets. If needed, you can de-register the old ones from any working handset and then add even more. See page 35 of the manual, ftp://ftp.panasonic.com/telephone/om/kx-tg6841_mul_om.pdf . Additional handsets are available from Panasonic, http://shop.panasonic.com/support-only/KX-TG6843B.html , Scroll down to the Accessories section and expand it. Amazon.com also has the handsets: https://www.amazon.com/Panasonic-KX-TGA680S-DECT-Accessory-Handset/dp/B00BS4D2CU .
I hope this helps.
2answers
How can i register my hanset. it says error.
Please use the below link to assist you with handset registration.
http://service.us.panasonic.com/OPERMANPDF/KXTG5621S.PDF#page=35
Manual for Panasonic Handset KX-TGA560B
For the KX-TG5672, you should press and hold the Intercom button until the charge indicator flashes. Then press the button to assign the handset # 1, 2 or 3 (keypad 1, 2 or 3). Then press OK on the handset and wait for the handset to beep. These steps must be done within a minute from when the charge indicator flashes. It's best to have the base and the handset close together when you register the handset.
Panasonic has the manual for the TX-TGA560 available here: http://service.us.panasonic.com/OPERMANPDF/KXTGA560-MULTI.PDF . (This manual covers both the KX-TGA560B and KX-TGA560M.) The manual for the KX-TG5672 is available here: http://service.us.panasonic.com/OPERMANPDF/KXTG5671S.pdf .
If you still have a problem, try removing the battery from the handset and disconnecting the power cord from the base (from the wall and the base itself). Wait a few minutes and then reconnect the power cord and the battery for the handset. (Make sure that the base has power and the adapter is warm.) Then try registering again.
I hope this helps.
8helpful
My phone display's No link to base. Reconnect main bas AC adapter. It is plugged in what now?
I had this problem, and I fixed it by re-registering the phone to the base. Here are the directions for how to do that from the manual:
Registering a handset to the
base unit
The supplied handset and base unit are
pre-registered. If for some reason the
unit, re-register the handset.
1 Handset:
{MENU}
2 {V}/{^}: "Initial setting"
{OK}
3 {V}/{^}: "Registration"
{OK}
4 {V}/{^}: "HS registration"
{OK}
5 Base unit:
- KX-TG4011 series:
Press and hold {LOCATOR} for
about 5 seconds. (No registration
tone)
- KX-TG4021/KX-TG4071 series:
about 5 seconds until the
If all registered handsets start
ringing, press the same button to
stop. Then repeat this step.
The next step must be completed
within 90 seconds.
6 Handset:
Press {OK}, then wait until a long
beep sounds.
Note:
While registering, "Base in
registering mode" is displayed on
all registered handsets.
When you purchase an additional
handset, refer to the additional
handset's installation manual for
registration.
See http://service.us.panasonic.com/OPERMANPDF/KXTG4011-MUL.PDF (page 22)
1helpful
I have a panasonic cordless phone, model kx-tga820. for some reason both handsets now say that it is busy when i push the talk button. Our other phones are ok. Why?
If you get busy tone in your Panasonic KX-TGA820 cordless phone, it may be due to any one of the following reasons:
1)The called handset is in use.
2)The handset you are calling is too far from the base unit.
Check whether the base unit is not so far from the handset
3)There is no handset registered to the base unit matching the extension number you entered.
Try to re-register the handset to the base unit again, To know details regarding registering and re-registering, please refer page 38 of the manual, which you can download from the link given below
4)Other units are in use and the system is busy. Try again later.
Try to check whether the other units are not using your base unit
You can download manual for your phone from the following link for reference
http://service.us.panasonic.com/OPERMANPDF/KXTG8231.PDF
Please rate this solution
Rnj VINODKUMAR
TOO FAR FROM BASE
Hi! This may cure your problem!
Re-registering the handset
If “No link to base. Move closer
to base, try again.
” is displayed
even when the handset is near the base
unit, you may need to re-register the
handset to the base unit.
Important:
LMake sure the base unit is not being
used.
LHave the handset and base unit near
each other when re-registering the
handset.
LKX-TG5422 and KX-TG5423 only:
Confirm the extension number of the
handset which has lost its link to the
base by placing the handset on the base
unit or charger.
If you accidentally assign another
handset’s extension number to it, the
other extension will stop functioning.
1 Handset:
Press {MENU}.
2 Scroll to “Initial setting” by
pressing {V} or {^}, then press {>}.
3 Scroll to “Registration” by pressing
4 KX-TG5421 base unit:
Press and hold {HANDSET
LOCATOR
} until the CHARGE
indicator flashes.
KX-TG5422 base unit:
Press and hold the handset locator
button that corresponds to the handset
you want to re-register ({HANDSET
LOCATOR
1} or {HANDSET
LOCATOR
2}) until the CHARGE
indicator flashes.
Below is a link that will take you to the instruction manual for your phone.
http://www.phone-manuals.com/panasonic/KX-TG5422M.shtml
Hope this helps! Hal
26helpful
6answers
DeRegistering a Damaged Cordless Phone???!!!!
I have a Panasonic KX-TG6700 base unit and KX-TGA670B handsets. We had a similar problem where we were no longer able to deregister the handset using the handset itself. We wanted to be able to use that slot that the broken phone was still occupyng. The solution that we found in the manual online was to hold down the intercom button for 3 seconds until the "in use" light turned on. Then press and hold the number of the extension you want to deregister until it beeps. At this point the base unit has freed that extension.
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
