Hi I'm having an issue with a Sony TV model KDF-E42A10 when I push power button it makes this buzzing sound and it sounds like a fan noise then turns off by itself and it has no picture the screen displays black screen I took out projection lamp but I can't tell if its no good how can I tell.
    New Friend:
Hi Sandra, I'm not 100 % but pretty sure it is the lamp. Does your power light flash at all or say anything on the screen when the screen is black?
Posted on Nov 15, 2014
    Master:
  • 409 Answers
Is it 3 sets of 2 buzzes about 15 seconds apart ?
---This is a bad bulb or an improperly installed replacement
or a continuous buzzing ?
----This is a Power Supply Unit going-bad or failed. The louder it gets the harder it is working....eventually it will fail. Ensure there is proper ventilation around your TV.
5 Suggested Answers
  • 1694 Answers
SOURCE: No picture or sound after replacing lamp
Possible bad color wheel...
Pull the lamp out & look inside where the lamp sends the light-
does the color wheel look defective? If so,replace it.
Or, the lamp ballast may be bad.After that,usually replace
complete engine.
Posted on Oct 19, 2007
  • 179 Answers
SOURCE: HL-r6167w wont start up (HELP)
it sound like the color wheel is bad
Posted on Nov 29, 2007
  • 395 Answers
SOURCE: Sony Grand WEGA KDF-60XS955 60 in. Rear Projection popped and turned off
the reason your lamp blew so quickly is the the lamp fan has become cloged with dust. this is a known problem by sony and I have done 15 or so of the up grades needed. first look at the lamp door is it discolored and warped. if so have a tech order the up grade kit which includes a new door, siraco fan, thermal fuse, and lamp. the return fan may also be needed. also some service menu changes need to be made with the fan voltages of fan 1 and fan2.
Posted on Feb 22, 2008
Slinteriors
  • 8617 Answers
SOURCE: RCA Scenium HDLP61W151yx1
its the color wheel.
Posted on Jun 28, 2008
HI, My Sony KDF-E42A10 TV, power on then goes off blinks red 4 times and have checked the 2 fans that can be seen and are working until it powers off. Any ideas?
there are three fans . the one u cant see is above the lamp housing. u need to pull all the plastic
housing of to access to clean.
Apr 01, 2011 | Sony KDF-E42A10 42 in. LCD Television
My Sony KDF-E42A10 turns on and then after a min the picture and sound will go away and the light "Power/Standby" will flash green. after a little bit the TV sound and video will come back on for a...
It is symptom of weak lamp that reaches at end of its working life, replace lamp in tv to fix the issue.
Lamp replacement procedure is easy and written in user manual.
Thanks.
Aug 31, 2010 | Sony KDF-E42A10 42 in. LCD Television
Tv was moved from fl to al. When the tv was unpacked and connected the power button on the tv was pushed. It sounded as if tv powered up.. Heard two clicks and the tv turned off. Help?
Unplug the tv about an hour,replug it back in,to let tv reset itself.The tv should work again.Not,take out the back cover,check all connections,see if any loses connections.
Jul 13, 2010 | Sony KDF-E42A10 42 in. LCD Television
Set was on and made a loud pop noise and the picture went off. the red light was flashing and no picture. then it made a strange buzzing type of sound a few times. turned off for a couple mins and then...
It sounds like your screen inverter has just gone >bang< unfortunately.
Most screens inside use 2 main circuit boards, and you are most likely going to have to change one of them.
It's possible also for it to have been just the backlight bulb making the loud pop noise too. The inverter may have given out too much power and blown the bulb (a lot like you hear when a house bulb goes bang).
If you can't actually hear any TV sounds (normal sounds like music, voices etc. when they should be there), then it means the problem is more serious, and would need a specialist repair place to check out the electrical circuit inside.
Mar 30, 2010 | Sony KDF-E42A10 42 in. LCD Television
Sony 50A10 LCD tv. Turned on tv this morning and
Yeah the fans continue to rotate for at least 2 minutes past shut off time.
Nov 16, 2009 | Sony KDF-E42A10 42 in. LCD Television
Sony KDF-E42A10 rear projection TV. Won't turn on.
Start by changing the lamp. If you got 5 years out of the old one, count your blessings, most folks only get three. The lamp is designed to be replaced by the consumer. Ebay will carry a replacement for you or you can get it directly from rivervalleyelectronics.net. They've got good prices. The lamp door is on the back. Its really easy, give it a shot.
Sep 07, 2009 | Sony KDF-E42A10 42 in. LCD Television
Black Screen with sound
Take a look at your lamp in your tv. Your owners manual will tell you how to change it.
May 23, 2009 | Sony KDF-E42A10 42 in. LCD Television
Sony KDF-E42A10 42
I replaced the bulb recently on my tv and did not push the bulb all the way in. I had the same issue you are having now, and I was able to get it to work when I realized it had not been installed properly. Make sure you push the bulb in all the way then push down on it so it sets in nice and snug. Sounds like someone replaced the bulb and installed it wrong like I did the first time. Good luck.
Feb 17, 2009 | Sony KDF-E42A10 42 in. LCD Television
Sony LCD KDF-E42A10 Television
Please count flashes on Sony KDF-E42A10 tv and let me know.
Its error signal and shows problem with particular area in your tv.
Sep 29, 2008 | Sony KDF-E42A10 42 in. LCD Television
Sony Bravia LCD T.V.
It is most likely a fan (there are 2 to 3 of them in the set) that is making the noise. I doubt seriously that the lamp is causing a buzzing noise. The only other buzzing sound can come from the ballast wich powers the lamp.
Nov 28, 2007 | Televison & Video
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
