Make speakers and headphones play at same time on onkyo htr-520? want to power niles s1 1230
    Genius:
  • Audio Player... Master
  • 1,054 Answers
You can't. once you plug anything into the headphone jack, the unit will automatically turn the speakers off
Posted on Nov 17, 2014
5 Suggested Answers
  • 120 Answers
SOURCE: center quit working on my onkyo htr 500
You can download the user manual from onkyo website-free.
To be able to get "Stereo" FM, you need to connect the antenna.
Posted on Oct 03, 2008
SOURCE: The receiver thinks there are headphones connected
Onkyo directed me to return the unit to a service center. Apparently this is a known issue and after reading web postings I believe it. There were dozens of similar cases with a variety of Onkyo recievers. I was able to remove the ribon connector from the headphones and discovered it is not a shorted headphone detector. We will see what the service center does. I'm not looking forward to paying for shipping a 66 lb receiver.
Posted on Aug 05, 2009
  • 3 Answers
SOURCE: I have a yamaha htr 5890. I would like to hook up
You are probably connected to the pre-out jacks. These are not amplified. Connect them to the B speaker outputs(screw down connectors). If that won't work (and it should), you can connect to the "Presence" speaker connections(spring loaded connections).
Posted on Aug 10, 2010
gregs_rockin
  • 274 Answers
SOURCE: how to connect Niles #SSVC-6 Speaker Selector to Yamaha RX-V671
Greg, It pretty basic hookup,Just hook it up to your speaker terminal on the reciever or amp.To the input of the (Speaker) Selector.
Posted on Oct 04, 2012
Why is there no sound on my NoKia Lumia 520 windows 8 ?
I ran into this same problem with my Nokia 900. It happened right after I plugged and unplugged a headphone into the headphone jack, so I suspect Nokia ships with a defective headphone jack sensor, because this happened with the second phone after I returned the first one and got a new one. (Note to self, don't plug a headphone into a Nokia phone). I am able to temporarily get around the issue by going to the dialer and calling ##634#, then going to the audio loopback diagnostic and starting the loopback for the phone and choosing loudspeaker. This does not last permanently, so I have never found a solution to the issue, other than using blue tooth or speaker phone.
Jul 28, 2014 | Nokia Lumia 520 Windows Phone Black
Speakers and headphones do not work
Sadly this could indicate that the main power amp has failed. You should try turning it up really loud with some music playing. If you can hear it very faint, then the main amp has failed. If you can hear hum, then the pre-amp might be the cause. The only other cause is that the headphone socket has broken, cutting off both speakers and headphones.
Aug 06, 2013 | Onkyo Audio Players & Recorders
I have an Onkyo TXNR609 home theater receiver hooked up to a 6 speaker surround sound setup in the living room. I also have 2 speaker pairs outside - one on the downstairs patio and one upstairs. I was...
If you haven't done already, then verify that zone 2 works without the selector. If the speakers definitely work and the zone output definitely works then the speaker selector must be the culprit! It's pretty difficult to mess up the wiring with speakers, as even if polarity is reversed, you will still hear something.
Sep 23, 2011 | Niles SSVC2 Two Pair Speaker Selector...
Feb 02, 2010 | Yamaha HTR-5890 Receiver
I have an ONKYO TX-SV717Pro amp. recently I lost
It could be that you lost the power supply to the surround amp IC or the Ic is defective. It should be mounted on a circuit board attached to the heatsink. Look for poor solder connections first. I don't recall the specifics of this model, but the surround amp IC should be easily located.
Update this with your progress and I'll try to locate the service manual in the meantime.
Dan
Oct 22, 2009 | Onkyo M-282 2-Channel Amplifier
Aug 04, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
My last Reciever, I had wireless speakers that worked by plugging into the headphone jack. When the wireless transmiter was plugged into the headphone jack I still had sound coming out of the main...
Your system is designed to interrupt the signal flow once headphones are attached. It can not be changed without internal modifications. There is no control to do this.
Dan
May 12, 2009 | Yamaha HTR-5730 Receiver
HEADPHONE ENGAGED AND NOT PLUGED IN.
When your son pulled out the headphones he must have broke the auto pressure switch right inside of the headphone jack input (its most lickly just bent out of place making a contact that is telling the amp the headphones are still in! you can try to bend the contact back into place...but if it is broken it will need replaced (a cheap repair!)
Please rate my response and help keep this site free!
Jan 03, 2009 | Onkyo HTR500 Receiver
Center quit working on my onkyo htr 500
May 18, 2008 | Onkyo HTR500 Receiver
Onkyo 9555 protection circuit
Make shure your speaker wiring is solid hookup to amp and spekers (NO CROSSED WIRING). Also make shure speakers are not wired in parallel or the speaker impeadance will be to low and amp will kick out.Turn speakers off then hook up headphones and crank up volume then see if amp kicks out.If it does you have an internal overload and needs serviced. If it playes ok then you must have speaker problems or wiring.
GOOD LUCK
BIGREDl
Mar 26, 2008 | Audio Players & Recorders
 Grubhead
Grubhead
