Question about Chevrolet breather. air cleaner intake. filter. engine crankcase
When "check gages" light comes on intermittently, what gage should i check? Oil's OK, topped off w. a qt of 10/40; rad is OK, l'll flush tomorrow. dash light gages are all showing true. Couldit b
Hx...got caught in a huge traffic mess on I40 going west. Rather than let my Blazer suck up gas, I turned engine off til we'd move forward. Got home (abq) and check gage lite lit up.
    Master:
  • 969 Answers
Have Autozone, Advance Auto or Orieley's connect an OBD 2 tester to the vehicle to read codes and determine possible fault/faults. It is free!
Posted on Nov 15, 2014
Engine cranks very slow on starting and will not start
refill the battery with electrolyt and charge it fully, then try to start the vehicle
If it cranks/turns over no faster have the starter motor checked.
Ensure that the timing belt is intact before you do anything, and that it is in the correct position.
Ensure that the oil is clear of water and is clean and is topped up to the top mark on the dipstick
Assuming you have checked the above and the belt and oil/coolant is all as they should be, and you have a fully charged battery and the starter is ok .......attempt to start the vehicle. Turn it over/ crank it over a few times if it does not start immediately.
Should it not start perform a compression check to find out the
engine's state of health.
Then come back with the results and we can go feom there.
Add the detail of your work and the make and model of the vehicle, along with the engine option, and repost the query
Jul 18, 2015 | Spectre 2003 Dodge Stratus - 2.4L 4-cyl....
How can i wash the engine from inside?
CRC makes a product available at your local store call "Fast Motor Flush". Just follow the instructions and the product will clean your engine fairly well. Really old and dirty engines may need 2 times.
Sep 24, 2013 | Hyundai Hynda Tiburon 2005othrYrs/Mds...
Where is thermostat located on 2004 suburban
I'm not an expert but I have changed a few thermostats in my time on different cars and most times the stat is located where the top coolent hose come off the radiator and goes into the engine thats where the thermostat should be and dependeing on the location it should only take about 15 min to change depending on your skill, hopefully that helps you.But if it is behaving like you mentioned it might be your water pump going bad , I just went through a simular problem.
Sep 27, 2012 | Chevrolet 2004 Chevrolet Suburban 1500 LT
The Fan on my "Fresh
It could be getting clogged up. The lint screen has GOT to be kept clean or the machines fan will pull dust into the machine and it will cake on everything inside, including the fan(will make more sound while running) and can get into the bearings of the fan causing the problems you mention. It may also be a poor electrical connection. If you have ever OILED the motor...you'll have to clean it. It's not meant to have a lot of oil or grease on it.
Jun 10, 2011 | Ecoquest Fresh Air Air Purifier
I have a F50E electronic filter. The light comes on, but there is no snapping sound when I push the test button. The cells and wires look ok. What could be the problem.
It's possible that the board is at fault. Triple check and make sure all the ionizing wires are in place on both cells and that the thin collector plates are not touching each other. Also, make sure the contact points are clean on both the cells and the cabinet.
The F50 is an obsolete EAC, so parts are becoming difficult to get. If the board is bad, I would recommend unplugging the unit and using a MERV 10 media filter in its place (Honeywell designed that EAC with the same cabinet as the media filter... all they did was add a power pack on top for the EAC. The media filter will slide directly in the cells place.) You will get better filtration with much less maintenance.
Mar 24, 2010 | Honeywell Air Purifiers
My ecoquest breeze is squeaking
Singer sewing machine oil works great. Remove the front grill and carefully remove the fan by sliding it off the shaft. Where the shaft meets th4e motor, place three or four drops of oil. Spin the shaft and wipe off the excess. Place the fan back on the shaft, flush with the end of the shaft. In the rear, remove the lint screen and the ozone plates. Put oil on one end of a Q-tip over a trash can until it drips off. On the rear of the fan motor, push the Q tip against the shaft so that oil oozes out. Again, spin the fan. Repeat this process every time you clean your Breeze and it should never squeak again.
Mar 25, 2009 | Ecoquest Breeze AT Living Air Purifier
Power light not coming staying on...
pull the cells out and run the filter without them. If the light stays solid then you most likely have a simple short in one of the cells. Install one cell at a time, push it all the way back, close the door, turn on the fan. IF the light stays solid, that cell is fine. If the light flickers or goes out, the most common cause is a bent fin.
Look at the cells and see if any cells are touching or are too close, this will cause your problem.. Simply bend the cells to get even spacing and you should be ok.
Jul 15, 2008 | Honeywell Enviracaire Elite F300E-1019 Air...
Water Cooler Problem
you might try a strong solution of vinegar and water and then flush it later till it tastes right
Mar 09, 2008 | Air Purifiers
Unit stopped smelling
Whenever you clean or replace the plate, you must also clean the contacts that touch the plate, and all supports for the contacts. Clean them with 70% or higher isopropyl alcohol and Q tips. You should also clean the ionization point with a Q tip and alcohol, remove and clean the fan and oil the fan motor front and rear with a drop or two of sewing machine oil. Replace the fan so that it is flush with the end of the shaft. Make sure that the contacts are firmly against the ozone plate when you replace it. They sometimes barely make contact and then don't work well. You can bend them enough to make them fit firmly.
Nov 06, 2007 | Ecoquest Breeze AT Living Air Purifier
Chevrolet breather. air cleaner intake. filter. engine crankcase Logo
77 people viewed this question
Top Chevrolet Air Purifiers Experts
Are you a Chevrolet Air Purifier Expert? Answer questions, earn points and help others
