Yes i need help with dell laptop key board back light off
  • 345 Answers
If you are shure you have backlit keyboard usually you can use fn key and on thw arrows should have plus and a minus with little light above arrow in blue or orange. If uoj have tried this it can be turned off in bios. To get to bios restart machine and srart to tap f2 key. You will find the backlit keyboard settings. Hope this helps.
Posted on Nov 16, 2014
How can i tell if my keyboard is backlit in inspiron 15r?
If you press any key on the keyboard, the back light should come on automatically. If not, hold down (Fn) function key and press "right arrow" with a blue florescent symbol until the back light is lit. Pressing the "right arrow" key while holding down the (Fn) key lits the back light and can also reduce, increase the light.
Hope this helps
May 31, 2014 | Dell Inspiron 15R Laptop
Dell motherboard not coming on
For latitude there's not much to do. check the power adaptor/connecting pin --- if any problem. If not than u need to replace the board.
May 02, 2014 | Dell Latitude D800 Notebook
My Vostro 1000 dell Laptop monitor keeps on having a blackscreen, It is on but I cannot see it on my screen
First connect to an external monitor, is there a picture?
If yes, Us the Fn keys to switch to the on board display. Have you got your display back.?
If no to both, your graphics chip/card has probably failed. If no to just the laptop display, then possibly the inverter has failed or the connection has been broken.
FIrst, Its easier to check the connections to *********** board, unclip the plate between the keyboard and screen, carefully. Then remove the keyboard retaining screws. Make sure all ribbon connections are good. If already good, then its down to checking at the screen end of the cables.
You should find some help here:-
http://support.ap.dell.com/support/edocs/systems/vos1000/en/sm_en/display.htm#wp1022270
Nov 15, 2011 | Dell Vostro 1000 Notebook
My charger broke like six months ago and I never bought a new one. When I charged it my computer didnt want to turn on. all it does when I push the power button it turns green along with the power symbol...
  • Turn on laptop.
  • Laptop will be start booting. Red/yellow light will be blinking. If yes then check your monitor light will be fixing and Show *********** Board.
  • If shows and your OS will be Booting and fail to start.
  • If yes you can repair it.
  • Insert OS disk into the DVD driver.
  • Turn off PC.
  • Turn on
  • "Press any key........" when comes this message you press any key.
  • After that you can see two option
?? Fresh copy Installation OR
?? Repair Option
  • For Repair Press "R"
  • It will be start repairing
May 16, 2011 | Dell Inspiron 6000 Notebook
I have dell vostro 1000 labtop an the screen is just black wen i turn it on there is no light but i can here the sound so i no it is on i just can see anything can anyone help. pleasurezone74@yahoo.com
It sounds like the laptop is set to use an external monitor.
Check the function keys for an icon that looks somewhat like a monitor
turn the unit on and wait until it is started
then press and hold the function (fn) key
While holding the fn key press the function key with the icon (it is a stepping control)
this should, after one or two presses bring up your on-board screen.
Good luck, I hope this helps
Apr 04, 2011 | Dell Computers & Internet
Hi my dell vostro key board has locked ,right hand side of keyboard blue light with a lock and 9 inside it .tried everything can you help
The 9 lock key means that your Number lock key is on. The blue light usually means that your blue tooth is on. Try connecting an external USB keyboard to see if it functions normally. If so then you need to have your keyboard replaced.
Jan 09, 2011 | Dell Vostro 1500 Notebook
I have Dell latitude d630, It is switching on but no display, when I switch on my laptop, its num lock light is on. capslock light works when i use caps button. Power light is on but hard drive light...
Attach an external monitor. Does the external come on? May have to use the FN key + F8 to toggle it between the LCD and the attached monitor.
When you say that the laptop LCD glows a little bit, this makes me think the back light of the LCD has gone bad. If it displays fine on the external, then it is a pretty good chance the LCD back light has failed. If you can attach an external monitor and see something on it, run the built hardware test. This is done from a powered down state. Then press the FN key + Power, this places it into the diagnostic. Follow the on screen instructions. If it comes back with an error code, write this down and compare it to this list at Dell website. http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&docid=14B3819735D6B40EE0401E0A55177ED2
Occasionally, reseating the LCD video cable to the mother board will have a positive effect. Here is a link to the online service manual that explains how to reset it. In the diagram it is labeled #5 It is located under the keyboard.
Aug 10, 2010 | Dell Latitude D630 Notebook
Dell latitude d360 has aproblem on screen,wen i start it it brings alot of lines on screen.
Try these steps :
  • turn off the laptop and unplug all the peripherals.
  • take out the battery
  • press and hold the power button for 30 seconds without the battery and the adaptor.
  • after that put the battery back and press and hold the Fn key and then press the power button to turn on the computer it will take you to dell diagnostics.
  • If you see colour bars on the screen press y for yes from the key board it will then do a small diagnostics and restart your computer.
  • If in this process u still see the lines on the screen that indicates the lcd screen failure and will need a replacement.
Mar 23, 2010 | Dell Latitude Cpi D366XT PII Notebook
Non functioning keys
Have you tried to run the Dell Diagnostics? If YES, what were the results? If NO, please run the DELL Diagnostics and tell me the results. thanks
Mar 14, 2007 | Dell Latitude D800 Notebook
Computers & Internet Logo
164 people viewed this question
David Payne
David Payne
