Question about Elite Sl 3000 Ul Sliding Gate Operator
I have an elite 3000 gate opener that does not open when cars drive over presurre pad
    Scholar:
  • 99 Answers
Hi Steve, it is not a pressure pad, it is a ground loop, which is just a wire going a few times in a loop that can pick up the magnetic mass of your vehicle. This 'change' in field is then fed to the control box when the car enters the field and the control box need to react on this. So it can be the ground loop wire or connections that are not working anymore, since it can be damaged by heavy vehicles, or the control box is not handling the information correctly. I would get a specialist to check this for you. Good luck.
Posted on Nov 15, 2014
  • 116 Answers
SOURCE: Sliding gate will not close
Check track for obsticles, Does it slide smoothly or does it hand have way and get more difficult, Clean any sensors you can see with a clean rag. Let me know what you find.
Posted on Dec 11, 2008
  • 52 Answers
SOURCE: when should I replace battery for Elite Robo-slide gate opener.
Sounds like its time to replace now!
Posted on Jul 02, 2009
  • 68 Answers
SOURCE: The outgoing gate has a positive stop on it, but
Well it seems that their could be a limit switch problem. also if someone has replaced the limit switch they could have not connected the wires back up correctly. if your wiring and switch are correct than you have a bad circuit board. my opinion is to not even fix it and replace the whole opener with a gto-pto gp sl50 They are the most reliable opener out so far and come with all the features that elite charges extra for like a battery backup for instance.
Posted on Oct 24, 2009
  • 366 Answers
SOURCE: my sl 3000 ul gate wont open unless I help it out
if the motor cant rotate the shaft by itself, its likely a burned coil in the motor, but if the motor is running but not moving the gate then its a broken gear
Posted on Jan 24, 2010
  • 14 Answers
SOURCE: i have an elite robo swing r900 gate opener. gate
first check you battery and make sure it is putting out 12v dc then if you have a solar power system check the red and black wire comming from the panel and make sure it is putting out 24volts. if you panel is not putting out the volts it caused your battery to die so replace your panel and battery and all should work fine. if your using a trickel charger do the same check power its putting out and make sure its correct and also check the 120v ac comming in to the charger. Follow the steps it deffinatly sounds like a power issue.
Posted on Mar 13, 2010
Gate will open pushing open button but cant use remote
General answers only, sorry. Look for loose or corroded connections, especially where wire nuts were used. Reprogram the remote receiver. Disconnect power to the receiver for a short time. Reconnect and reprogram. I hopes that any of this helps. I have operators to the much like witch craft, a black science!
May 10, 2016 | Elite Gate Opener Sl3000 Slide Gate...
Gate stays open and does not close unless timer switch is turned off
I have a brand new Ramset 300 electric gate opener. My problem is in the early morning when the loop opens the gate it will not close unless deactivated manually. It does not happen later in the day with my GMC truck but happens early in the am with my husbands Toyota Prius. Please help. What can be the problem?
Jun 19, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
1. I have an elite slide gate opener it will open all the way and after a few sec will close. 2. With the remote the gate will not stop and stay in the open position.
the auto close has been set or the motor has been set up in reverse and it is auto reverseing,make sure the gate is opening up all the way, if it is not just help it along and see what happens.
Apr 13, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
My sl 3000 ul gate wont open unless I help it out after i press button on board I have to turn motor shaft and push on gate and then it will catch and opne/close. Is it my motor or my worm gear?
Jan 24, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
Oct 24, 2009 | Elite Sl 3000 Ul Sliding Gate Operator
Holiday Programming
the elite does not have that function, your are going to need to look for a time clock that holds open your gate...... the outside phone system or a programmable time clock that has been added to your gate...... oh this is an old post sorry. :)
Dec 19, 2008 | Elite Sl 3000 Ul Sliding Gate Operator
The photo eye sensor is defective of is out of its correct posistion!
Hope this was of help!
Dec 11, 2008 | Elite Sl 3000 Ul Sliding Gate Operator
Elite Sl 3000 Ul Sliding Gate Operator Logo
108 people viewed this question
Top Elite Home Security Experts
ray gallant
Pierre Legault
Tom Chichester
Are you an Elite Home Security Expert? Answer questions, earn points and help others
