Question about Air Tools & Compressors
Have a nu power gas nail gun fully charged battery full gas cylinder but will not fire nail
    Scholar:
    New Friend:
  • 151 Answers
Did you take the nails out a check the safety , where the nail comes out ? Sounds like a stick or stuck safety switch . Good Luck !!!!!!!!
Posted on Nov 15, 2014
  • 131 Answers
SOURCE: paslode 350 wont fire
Probably needs cleaning. You`ll need two new o`rings.
Posted on Aug 26, 2009
SOURCE: Paslode nail gun 325 black not firing
Any time these guns become intermittent or stop firing but the fan still runs, the first the to check is the expiration date on the gas cartridges. The do expire and this will make the gun work inconsistently or not at all.
Posted on Dec 13, 2009
Testimonial: "Thanks for that, i will look into it! Thanks for your time.... Cheers, Steven. ;-)"
rowdy45176
  • 2176 Answers
SOURCE: my paslode nail gun has gas and full battery but
could be quite a few problems, to start what is it doing exactly, can you hear the fan come on when the safety is depressed or the trigger is squeezed, if not could be a bad fan motor, electrical short in the board a loose connection, the light on the side, what color is it flashing when you try depressing the trigger, if it is red the battery could be a problem, Let me know some more information along with the model number and I will try and help
Posted on Feb 12, 2010
rowdy45176
  • 2176 Answers
SOURCE: impulse gun wont fire and fan doesnt run
could be a bent probe not allowing full travel of the safety , fan motor, loose wire, or circuit assembly. If you are handy with tools, remove the battery and fuel cell. remove the 4 screws holding the cover on top of the cylinder assembly and down where the saety is remove the 2 screws there also. gently pull the cylinder off the tool. when you have apart check toe condition of the Oring on the top plate where the fan motor is. Now reinsert the battery and you will see a rocker switch towards the top, depress it and the fan motor should come on. if not try and depress the trigger switch and again the fan motor should come on. If neither start looking for loose or broken wires, if you find none then I would guess the terminal board would be bad. you can also remove the handle halves and look for a loose connection at the board itself, they sometimes wiggled loose where it plugs in. Good luck and let me know.
Posted on Apr 25, 2010
rowdy45176
  • 2176 Answers
SOURCE: The problem of intermittent firing
what is the expiration date on the bottom of the fuel cell?? Also what were the condition of the o rings and did you relube with a good quallity oil. What I would do is remove the front assembly to expose the fan only and then insert a battery, pull the trigger and the fan should run for a few seconds, next there is a roller lever towards the top, depress it keeping fingers away from fan and again it should run for a few seconds, next depress and hold the lever and then pull the trigger and you should see it fire, repeat this several times, that will narrow it down to the spark unit/electronic assenbly or the cylinder.
Posted on Jan 09, 2011
How do I get my finish nail gun to fire?
don't have any of them but sounds jammed from sitting . too dry. anyplace tto put oil for the driver to move?
Aug 23, 2015 | Air Tools & Compressors
I've got a hitachi 2nd fix nail gun and for some
First thing is , when did You clean it last?
Sep 30, 2014 | Tools & Hardware - Others
Looking for the nearest repair shop for paslode nail gun in Northren Va
Have all the nails been cleared out of the tool where they were jammed? If not take the fuel cell out of the tool, and remove the battery before working on it. If still persists come back to this website for further help.
Sep 19, 2014 | Omega Paslode 901000 Impulse Cordless...
Black and decker 1802 nail gun will not fire with a fully charged battery
The battery may be falsely indicating it is completely charged when, in fact, it should be replaced
Mar 05, 2014 | Black & Decker Black Decker Firestorm...
Dec 08, 2009 | RTO PasLode 900420 Impulse Framing Nailer
My hitachi nailer wont fire
Start with the basics:
First check that the butane (or whatever gas is used) canister is full. If empty, put in a new one.
Second check to make sure your battery is fully charged to be able to fire the spark to work the nail gun. If not get the battery charged and/or replaced as needed.
Third make sure all of the safeties are working properly and that you have them engaged to the piece of wood you are nailing when you try the trigger.
If beyond that it does not work it could be a bad trigger, a bad safety switch, or even a bad connection from the battery to the device.
Nov 01, 2009 | Hitachi NR90GC 3 1/2" Gas Powered Clipped...
Paslode 350 wont fire
Aug 19, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Hitachi Framing Gun Not Firing - Bad Battery?
Does the fan run and the light blink ont he nailer? I have one that I just bought. I put in the wrong type of nails and got one stuck. I had to take the front apart to clear it and now the damm thing wont fire. The green light blinks and the gas cartridge is basically full, even the fan does run after I release the push lever, but no fire???
I wonder if yours is the same as mine did fire for a couple nails first just fine then got jammed...
I will try to charge the battery more.... MAybe like yours it needs a strong charge for the spark...
Russ
Sep 28, 2008 | Hitachi NR90GR Cordless Round Head Gas...
Air Tools & Compressors Logo
130 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
