Question about Tablets & eReaders
I have Azpen A720 I been having problems with charging my Tablet I had it on charge for an whole week it charge to 52 percent. I got the android from Babcock. I need your help to fix the problem
    Sergeant:
  • 247 Answers
Failure to charge is due to 1 of 3 problems. The charger, the connector or the battery. Try changing the charger or use your computer's USB port. If that doesn't solve your problem, it can only be a bad connector or the battery. Since both of these are not user replaceable without voiding the warranty, you will need service. Batteries age and wear down. How old is your tablet and is it still under warranty?
Posted on Nov 15, 2014
Gort007
  • 1187 Answers
SOURCE: Gateway M1300 tablet pc will not charge in the
Question 1: Will the tablet operate on the docking station (or power cord) without the battery in place?
If not, the power circuit on the tablet motherboard is broken.
Question 2: If you plug in the power cord into the tablet, is the connection "loose"?
Check the other tablet to see if it is the same loosness at the tablet power connector.
If it is loose, the power receptical in the tablet can be soldered back onto the motherboard.
Recommend taking it into a shop to re-solder.
If under warranty, get it repaired.
If not under warranty, your choice if you want to use it they way it is.
Hope this helps...
Posted on Sep 03, 2009
leighp123
  • 1669 Answers
SOURCE: tablet won't charge
If it's new bring it back on the warantee, if it is out of warantee, check to see if the power supply is putting out the proper voltage at the plug in tip to the Acer. Make sure the tip is put ALL THE WAY into the hole on the acer.
Posted on Jan 02, 2013
SOURCE: kaser Android tablet will not turn on or charge its brand new
Did you drain the battery completely and try to recharge it? A lot of people have problems if they drain the battery and recharge. I went through 3 A300 tablets before I figured out I had to recharge the tablet BEFORE it went dead or it would never start again. I don't know why but many brands have this problem. Also, do not shut it completely off when it is on the charger. Always take it off charge, or turn off before charging. I had another prestige that had to be replaced because I turned it off or on while charging. I have not found out why this happens to many tablets! Good luck!
Posted on Feb 26, 2013
SOURCE: connecting tablet to internet
I have no connection on my android tablet and when I try to connect it keep say authentication problem
Posted on Jul 11, 2013
jasonnashjlu
SOURCE: Both Charger Ports Wont Take Charges
i can suggest you get a Duracell wireless charger which you just place your tablet on and it charges?
Posted on Nov 09, 2013
My tablet is charging backwards. What should I do?
Optimus dying on charger/charging backwards - Android Forums at ...
forums.androidcentral.com > ... > LG Optimus Series > LG Optimus S
Aug 2, 2012 - 11 posts - ‎8 authors
Lately my Opti s hasn't been charging correctly sometimes it won't charge I tried different chargers and i use three batteries two that are brand ... LG G2: Battery and Charging problem- super annoying.
Apr 27, 2014
Samsung Galaxy S3 charging issue - Page 6
Aug 23, 2013
Galaxy S4 won't charge - Page 5
Jul 2, 2013
Says its charging but it isn't?
Feb 5, 2012
More results from forums.androidcentral.com
Why does my battery percent go down when plugged into ...
Dec 05, 2015 | Irulu 9 inch Android Tablet PC, 4.2.2...
Hi I bought azpen tablet last week den it was flat but I have charged it still is not working
Either the charger is no good or the battery is dead and will not take a charge.
Sep 19, 2015 | Tablets & eReaders
My tablet screen is frozen on the screen that reads azpen.when i turn it off and back on it is still frozen.it will not take a charge nor if i leave it on will the battery die.what can i do?
Hard Reset
Press Vol-up&Vol-Down button at same time, Then press the power button.
This starts your devices Recovery Mode.You can do a Wipe/Factory Reset from there. Use the Vol Up&Down buttons to navigate and the power button to select.
Be Careful and DONT MESS with the Other options or you may Brick your phone.
Apr 12, 2015 | Azpen 03038 A9 9.7" 8gb Android tm 4.0 Os...
How do you use a USB cord to charge a azpen 13.3 when the normal charging way is broke
I don't think you can. The USB port is meant to go out of the tablet and the charging port brings the charge in. Unless the Azpen is different from many other tablets.
Mar 19, 2015 | Tablets & eReaders
PRICE FOR BATTERY FOR AZPEN A720
Do a google search for
Mar 06, 2015 | Azpen A720 7 inch Tablet with 8GB Memory
Azpen a720 netflix will go into movie but not show picture, only sound and captions
i had this problem on a freinds phone and it turns out you have to reset the settings or the phone itself (I reccomend the phone reset)
Jan 20, 2014 | Azpen A720 7 inch Tablet with 8GB Memory
How do I get Tablet fix it will not charge?
The mini USB cable that came with my tablet was lame and would only charge if held at a certain angle. Another cable worked fine. This is an ultra cheap tablet, and they cut corners everywhere they could.
Jan 09, 2014 | Azpen A9 Android Tablet
Tablets & eReaders Logo
114 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
