Hey there, I'm a noob with an Acer D257 13473 netbook, and my SD Card slot isn't recognized...I can't even find it. How can I fix this?
    Sergeant:
  • 243 Answers
You can purchase an external card reader for less that 10.00, that would be the easy solution. on your computer go to acer and download the oporators manual for your model, it can tell you where the slot is and most likely the drivers for it can be found there too.
Posted on Nov 16, 2014
SOURCE: 2GB SD card no recognized
Thanks.
I have only one card reader. Will see if I can find a way to connect my GPS with the SD card in it to the PC.
Otherwise I guess I need to .. buy a new card.
What do you mean by formatting the SD card. I copy a file on it from Windows explorer (copy/paste) without doing anything to the card? If I buy a new card, should I format it first? How?
Since the system does not recognize the card I cannot do anything to it.
Thanks!
Posted on Mar 13, 2008
e-Guru
  • 3917 Answers
SOURCE: SD card reader not recognizing card
the original file (apparently version 2.0) is here:
http://64.233.161.104/search?q=cache:2288as3q0skJ:www.asus.it/support/download/selectftp.aspx%3Fl1_id%3D3%26l2_id%3D45%26l3_id%3D0%26m_id%3D1%26f_name%3DCardReader_050118.zip~zaqwedc+CardReader_050118.zip&hl=en
the updated driver (version 2.3) is located here:
http://support.asus.com/download/download.aspx?modelname=V6V&SLanguage=de-de
scroll down to where you see RICOH card reader driver
or more specifically this link here:
http://dlsvr03.asus.com/pub/ASUS/nb/V6V/CardReader_XP_2K_050808.zip
even though the site is primarily in german, all the component names are in english, go figure. So it would seem that the asus comp manufacturer are a little more forthcoming than dell in this particular instance. for example, nowhere on my component sheet does it say that RICOH is the manufacturer for the card reader, that's something i got from you guys on the forums
anyway, after installing this driver and rebooting my comp, card reader immediately recognized both MMC and SD media. unfortunately, it was only able to access the mmc card, and i'll be shipping my comp off to dell for whatever motherboard replacement they're willing to give me (which i don't mind, so long as it works when it comes back to me) but i thought these links might be helpful for others who are having the same problem.
Posted on Mar 19, 2009
  • 94 Answers
SOURCE: SD Slot doesn't work
If the SD card is a high capacity card (SDHC) the SD slot may not be capable of recognizing it. Suggest to try another SD card. If that still doesn't work find the drivers on your laptop manufacturers website.
Posted on May 11, 2009
shynysaxena
  • 166 Answers
SOURCE: How to insert SD memory card into card rader in laptop computer
I would like to inform you that Acer's laptop doesn't support all kinds SD memory cards available in local market. Its not compatible with all physical dimensions of various memory card companies. So in that case you need to use EXTERNAL Memory card reader which is attachable to USB ports.
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
Posted on Jun 29, 2009
Geekman
  • 32281 Answers
SOURCE: SD card does not seem to fit in the SD card slot
Is the SD card a mini type or a standard SD card?
The standard SD card is 24mm wide X 32mm long.
If it is a mini SD card you need to purchase a mini SD to standard SD adapter, then you will be able to insert it in your Compaq.
Posted on Aug 14, 2009
Acer aspire 5552-7819 laptop does not
Not sure what you mean, but if your sd card is not being recognized by your laptop it could mean you need to reinstall your drivers.
Before doing this try using a different sd card incase there is a problem with the one you are using.
Jul 17, 2014 | Acer Aspire Computers & Internet
Micro SD slot in my Kyocera Hydro isn't reading Micro SD card
test the sd card on your pc first to see if it works before you put it into your cell.
Apr 16, 2013 | Kyocera X-tc Cell Phone
Need to plug in large sd card into smaller slots on acer computer what do I need
You will need an adapter "Yes" You have a Micro vs a Mini I believe here is a good link for the type of adapter you may need. They are found at Bestbuy and Walmart as well I just bought one. Also amazon.com has really great pricing and fast shipping I use them all the time for these sort of items for sure. I just checked the price at amazon and it was $7.00 instead of $19.00
http://www.accessorygeeks.com/micro-mini-sd-memory-card.html
John
Apr 16, 2012 | Acer Aspire One D255 Netbook
Sd card not reading
* check the slot might some pin is dislocated due to wrong insert of SD card
* try to use a multi media card reader if will work.when if works.
* then your laptop SD card slot has the problem.
Jun 06, 2011 | Acer Computers & Internet
My acer 9410z won't recognize my sd card-how do I fix?
First install your usb driver and then try it. otherwise i think it can be operating system problem. the better for you of Windows XP or Vista.
Finally, everything is okay then the problem is in your sd card slot. please consult with a professional technician near about you. thanks.
Apr 10, 2011 | Acer Aspire 9410 Notebook
For Acer Aspire One Net Book Check cable connection..! PXE-MOF: Exiting Intel PXE ROM No bootable devise-- insert boot disk and press any key
Your netbook is trying to boot from your Lan/Ethernet connection since It can find no working hard drive to boot from. This usually means that your hard drive has failed.
Also remember that your netbook will try to boot from other drive types including your SD card, USB Memory Stick and even a Magic Jack if you have one inserted in the flash memory slot or USB slot while rebooting the PC.
Many people have mistakenly assumed that their Netbook is messed up because they forget to remove all flash and memory sticks before rebooting.
Oct 31, 2010 | Acer Aspire One PC Notebook
On my acer aspire 3680 laptop, It does not recognize sd cards, even though it has a slot for them, please help.
there may be a conflict in the SD card drivers that can be updated from www.support.acer.com
Oct 23, 2010 | Acer Aspire 3680 PC Notebook
I-mate JASJAM won't recognize micro sd card
format it and then try.else soft reset.or there mite b dust in ur sd card slot!
Mar 01, 2010 | i-mate K-jam Smartphone
It does not recognize an 8gb sd card in storage expansion.
Your netbook should read SDHC(over 2 GB capacity) memory cards. The problem might be either the card slot driver, Which you should download if a newer one is available. Or in case you format the SD as DOS then it will only have around 2GB of space, You should format it as DOS32 or NTFS so you get the full capacity for the SD card. Some pirated rather cheaper memory cards have a lower actual capacity. With some compression technique the capacity presented is higher than it actually is. If you format it then it will show the real capacity. hope that is not the case!
Good Luck!
Nov 24, 2009 | Acer Aspire One Netbook 8.9" Notebook
My acer will not pull up my 1gb sd card
check if the card is detected under my computer.
Format the card.
Jul 13, 2009 | Acer Aspire One Netbook 8.9" Notebook
Computers & Internet Logo
David Payne
David Payne
