Question about Vehicle Parts & Accessories
Why is my battery discharging after two days after motor mounts replaced?
I have a 2002 Saturn SL2 and just had the motor mounts replaced by a local repair shop. The battery discharges within two days (did not drive it during those days). I took back to the shop and they stated the bottom ground wire was placed incorrectly and repaired it. It is not keeping a charge again. My battery and alternator were tested, and both in excellent condition and healthy. Any ideas what could be causing this?
  • 59 Answers
If the alternator charging more than14.v and the battery tester reading is GOOD.
Check any leaks from the battery. Disconnect the ground wire from the battery--put the multimeter in the amperage measurement (10A)--connect one probe from multimeter to the ground terminal on the battery--connect the second probe from multimeter to the ground cable.All doors closed Any light , ignition,radio .......OFF. If the amperage reading (leaks) more than 30-50 mA you have to find where by reading amperage and disconnecting the fises one by one to clarify
witch cirqiut have the problem. Better to check this at least 30 minutes after the ignition has been tuned OFF and the doors were closed .
Posted on Nov 15, 2014
  • rtlsn8ke Nov 15, 2014
    Thank you. I will try this tomorrow and follow-up.
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
2002 saturn sl2 1.9 litre 4cylinder alternater brand new but the batery still gets drained quikly battery slso good wat could b the problem
Some circuit is draining the battery after you turn off the ignition. Need an ammeter to measure the drain and start removing fusings until the drain disappears. Then you have localized the line responsible for the drain and you can check all of the items on that circuit.
Nov 09, 2015 | Saturn Cars & Trucks
I have a 2000 Saturn sl2 and The right front motor mount was broke right down the middle and I replaced with oem part and it seemed to help quit a bit but still shifting hard what is wrong you think .
There are 4 motor mounts on the engine. You found the top mount. The bottom mount on that side is a dog bone and is right under the crankshaft pulley. The bottom mount is on the other side in about the same place. The drivers side top mount is another dog bone and is under the battery box. For best results, change all four of them at once, and make sure to buy a GM original mount for the top one. The knockoff mounts just aren't as smooth and durable as the real thing. Believe me on this one, the huge difference is well worth the few extra bucks. 25315433-zejmo41uy3tce5x43qikgza0-5-0.jpg
Dec 09, 2014 | 2000 Saturn SL2
Saturn sl2 2000
While the hood is open. Rn the engine with a helper operating the gas pedal and e-brake locked. Place the car in D and then R while you are watching the engine from the side. Have the helper step on the gas in each of the gears and watch what happens to the engine. If the engine jumps around,, then you have other mounts that are broken and need replacing.
Cant remove my starter from 1997 fordareostar
CAR STARTER REMOVAL? TESTING
One Wire From Starter Motor Goes To Solenoid And Other Goes To BATTERY. Starter GETS 12 VOLT SUPPLY FROM BATTERY AND WITH THESE VOLTAGE IT TURNS THE MOTOR AND THIS TRIGGERS THE STARTER SOLENOID AND YOUR VEHICLE RUNS.============
For your help there are few relatively help links showing how to remove and install starter with proper instructions:-----
These help links will help.
Click the link below:-----
How to test starter solenoid? http://schematicsdiagram.blogspot.com/2011/06/how-to-test-starter-solenoid.html -------------------- How to test cars starter? http://schematicsdiagram.blogspot.com/2011/06/how-to-test-cars-starter.html ----------- How to replace starter in car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-starter-in-car.html
How to replace Starter on Infiniti Q45? http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-starter-on-infiniti-q45.html
2006 GM Montana: How to replace Starter Solenoid?
http://repairhelpcenter.blogspot.in/2012/06/2006-gm-montana-how-to-replace-starter.html
Saturn SL2: How to replace Starter Motor?
http://howtobyme.blogspot.in/2012/06/saturn-sl2-how-to-replace-starter-motor.html
Saturn SL2 Starter Wiring Diagram?
http://schematicsdiagram.blogspot.in/2012/06/saturn-sl2-starter-wiring-diagram.html
Oldsmobile starter solenoid replacement procedure?...
How to replace Oldsmobile starter moor?
Oldsmobile starter motor testing?
Oldsmobile STARTER MOTOR NOISE DIAGNOSIS?
These details will help.
Thanks.
Nov 26, 2012 | Cars & Trucks
How 2 wire a stater on a 2000 chevy cavalier
How to test starter solenoid? http://schematicsdiagram.blogspot.com/2011/06/how-to-test-starter-solenoid.html -------------------- How to test cars starter? http://schematicsdiagram.blogspot.com/2011/06/how-to-test-cars-starter.html----------- How to replace starter in car? http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-starter-in-car.html
-----------How to replace Starter on Infiniti Q45? http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-starter-on-infiniti-q45.html
---------- 2006 GM Montana: How to replace Starter Solenoid? http://repairhelpcenter.blogspot.in/2012/06/2006-gm-montana-how-to-replace-starter.html
-----Saturn SL2: How to replace Starter Motor?
------------These details will help.Thanks.
Nov 23, 2012 | Cars & Trucks
I put a new battery in my 2002 Saturn SL2. The radio simplys says Lock mode. Please advise me how to get my codes thanks phil
Nov 23, 2010 | 2002 Saturn S-Series
Just bought 2002 Saturn SL2. Immediately manual
sounds like someone might have "rolled" the mileage back and srewed all that up taking the instrument panel out. Possible seen it before.
Nov 08, 2009 | 2002 Saturn Sl
2002 saturn sl2 will not start for no apparant reason then 1 to 3 days later starts, while trying it 2-3 times a day. Towed to a garage both times and they could find nothing wrong.
Why couldn't they find anything wrong? The main componants should be tested first. (the starter,srarter relay,any related wiring, ignition switch, and all connections at battery, relay, fuse, starter, and eng. block). Good luck.
May 03, 2009 | 2002 Saturn Sl
Sub frame interchange
yes a subframe from 91-94 will work.
Jan 09, 2009 | 1991 Saturn SL2
Overheating on stop and go traffic
I had the same problem on my SL1 2002 and my wifes SL2 2001. In both cases, the electric radiator fan motor needed replacing. It was not difficult but took me a full day of trying to figure out how to pull the plastic housing it is mounted in. Someone who knows what they are doing could have changed it in a half hour. Works great now.
Dec 27, 2008 | 2002 Saturn Sl
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
