Take the cover off a KSE 88 HRA commercial split system air conditioner?
I dont know how to take the cover off to give it a clean. will i need another person on the other end?
  • 30 Answers
Near the vents, sideways, you should have a spring plastic pieces that when pressed ahd spread a bit, in each side, should give you access to the filters... you can sash them, or just wash them...
just ut some cleaning spray because of legionella or other bacteria on them!!
Posted on Nov 16, 2014
Mitsubishi split ac indoor light blinking unit not working
The blinking is an indicator that it needs service. Call a technician! Ask if they are experienced in mini split systems. You can check the air filters. Check the outdoor coil to see if its clean or covered up with dirt. And at the breaker or disconnect, turn off power, wait 5 mins, and turn it back on. Then give it 3-5 mins to see if it will reset itself. If this don't work, call a tech/service provider! These units are troublesome to troubleshoot.
Jun 06, 2015 | Mitsubishi Heating & Cooling
The air conditioner is not cooling and its giving an error code of a light blinking 6 times. How can I fix this?
Jun 02, 2015 | Heating & Cooling
I have a Friedrich MW12Y3FM Split System Air Conditioner two units. I am getting a lot of mold build up on the fan blades also when on auto mode it almost never shuts off. I cleaned the mold off i bit with...
i dont believe the fan turns off on auto just the comp as for the the mold i spray it with bleach but the unit should be off when you do this and then turn it on the next day
Sep 07, 2011 | Friedrich MW12Y3FM Split System Air...
Error code is "U0"
According to the operation manual your system is low on refrigerant. You will need a technician show up and charge your unit and find the leak. This is a split system so leaks are very prominent.
"U0" Low pressure drop due to refrigerant shortage or
electronic expansion valve failure
A link to the system manual is below.
Hope this helps you with your issues...Jim...please leave a comment
http://www.daikinac.com/commercial/pdf/service_manual/SkyAir_SiUS25-501.pdf
Feb 13, 2011 | Cfm Daikin R410a Split System Air...
Need to know how to clean filters as it is not cooling very well
dismantle face cover and remove air filter and wash then pressurized water came from faucet.
Feb 05, 2011 | LG LSC091PMA Split System Air Conditioner
ERROR CODE BLINKING,THE AIR CONDITIONER DOESNT WORK
it is happening due to blower motor not giving the signal to pcb pls check their is a return signal wire in blower motor is broken or motor is defective.
Jul 20, 2010 | Sanyo Split System Air Conditioner
Dont know what symbol on remote is for heating for LG split system airconditioner
On mine, it's the symbol on the right-most one of 4; looks like a sun-symbol with several single lines emanating outward from the circle.
May 19, 2009 | LG LSC121PMA Split System Air Conditioner
Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Jan 18, 2009 | Heating & Cooling
I dont know how to turn my split system hot can u send me instructions or help
Go to www.lgusa.com. Check under their Support tab for your models operation manual.
Jun 12, 2007 | LG LS180HE Split System Air Conditioner
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
