Question about Air Tools & Compressors
I need a manual for a CH oiless pump Air Compressor 8 gal 2 HP MODEL DK705200AV
  • 2,210 Answers
If the CH is Campbell Hausefeld then manuals are free from www.powertools.manualsonline.com
Posted on Nov 15, 2014
  • 22 Answers
SOURCE: I have a Craftsman model 919.152932 33 gal
Sounds like the reed valves in the head failed. you need to replace the head (usually cheaper to get a new compressor)
Posted on Aug 28, 2011
Testimonial: "I hated to throw away an otherwise perfect condition compressor, but I had a feeling that was going to be the answer.Thanks for your help."
  • 4088 Answers
SOURCE: I have a Craftsman air compressor twin cylinder, 2
Go to: www.searsparts.com
The pressure control switch which the compressor usually pumps into and is mounted on the tank, contains a backflow check valve, the pressure regulator switch, and a compressor pressure release valve. It's probably available only as a complete unit. The pressure switch itself is usually a microswitch that can be obtained locally at a hardware or appliance parts house. Make sure that the pressure switch adjustment hasn't been set higher than the compressor can reach. If you remove the cover, you can watch for mechanical movement at the switch when it is supposed to shut off. Don't poke at anything in there with metal tools--220 volts will give you a lethal shock!
Posted on Oct 30, 2009
  • 5603 Answers
SOURCE: My craftsman air compressor model 919 16737 1.1 hp
Probably the check valve has failed. It apparently is where the pipe goes into the tank from the compressor.
Posted on Aug 24, 2009
  • 583 Answers
SOURCE: Need help with parts for air compressor.
Hi ,Crazy horse. information perfect . with a14.5 inch pully on the compressor and amotor running at 3450 rpm you can get with a 5 inch pully----1189.6 revs per min ---- with a 4 1/2 pully ---1071..6 revs per min so you hve to decide whether you want the max or the min from that compressor... If it was for me I would use the 5in . and set psi. with the cut in ---cut out switch ,this will be a good unit ,,if you need any more help don`t hesitate to call and thanks for the opportunityto help it is great when some one gives you good info .you did well
Posted on Aug 12, 2009
Testimonial: "Thank you so much! I had searched every where and no one could answer that question. I feel comfortable now! Job WELL done!"
  • 89 Answers
SOURCE: My craftsman 3 gal. air compressor, 921.153101 won't compress air
I WOULD TRY DISCONNECTING THE PIPING FROM THE HEAD DOWN TO THE TANK AND SEE IF ITS BLOWING AIR. COULD THE COMPRESSOR BE RUNNING BACKWARDS - YOU WOULD HAVE HAD TO CHANGE THE WIRING IN THE MOTOR.
VALVES IN THE HEAD COULD ALSO BE BROKEN. YOU CAN REMOVE THE INTAKE AND IT SHOULD **** YOUR FINGERS AT THE OPENING. HOPE THIS HELPS.
Posted on Mar 14, 2009
Craftsman Air Comp. 6 hp oil-less, 33 gal horz. tank - sounds really loud
Some of the craftsmen compressors have pistons that are coated on the top of the dome. Once the coating wears off, they have severe loud piston slap. If you continue to run it the way it is, it will snap the connecting rod in half or break the piston and possibly the cylinder.
Sep 21, 2017 | Craftsman 33 gal Air Compressor 6 hp...
How to get more hp out of a honda 5.5hp engine
Your compressor was designed to produce 11.8 acfm at 90 psi turning neer max rpm (depending on pully combination between 800 ~1100 rpm ) with max pressure of 135psi. At 3600rpm the engine is producing max hp of 5 to 5.5. More power would not really produce more air without potentially destroying the compressor pump by over-reving. If your compressor is not functioning properly you will not get good air flow. Check instruction manual for time period to fill tank from empty. Could be 2 ~3 min. It is takes longer then problems. You can tell how your pump is doing by periodocally checking the length of time to fill tank. The next size range of gas compressor is about 8~9 hp with four cylinder pump and will deliver about 17 cfm.
Mar 15, 2011 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
My central Pheumatic air compressor oiless
Sound like the fly wheel is loose or belt is the same
Mar 13, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a craftman oiless air compressor model # 919153210 that I need parts for and sears do not carry the part anymore. thank you for any help., gcmac@netzero.net
Many of Sears oilfree compressors were made by Devilbiss. Try going to this address http://www.devilbissparts.com/ and enter your sears part numbers. (example cac-4281 for valve plate) They will most likely have the parts that you need. Good luck and email if you have other questions about your conpressor.
Feb 23, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
