Question about Hypertech 2007 Ford Fusion - 3.0L V6 - Max Energy Programmer
Need help on bolt pattern on 07 fusion - Hypertech 2007 Ford Fusion - 3.0L V6 - Max Energy Programmer
2014 Ford Fusion 2.5L, 2WD Torque Specs for front wheel hub assembly needed Axle nut/bolt, Hub bolts
the four axle nuts, 98 ft lbs, tighten in criss-cross pattern.
The hub nut/wheel bearing, 148 ft lbs, use new nut, don't let vehicle weight sit on the ground while torqueing, it could damage the wheel bearing.
If I left something out, give me a holler.
Jul 26, 2017 | Ford Cars & Trucks
I need valve cover torch pattern and inch pounds to replace gasket on 07 ford fusion front and back
the removing of the bolts to the valve cover isn't that crucial in what order you remove them and the torque is only around 25lbs max , if you mean the cylinder head follow this link and click on TORQUE TABLES
http://www.speedwayautoparts.com/index35.htm
Nov 15, 2014 | Cars & Trucks
Code po491 on my 07 fusion
Code 491 is for insufficient secondary air injection flow bank one.
There is a device that pumps fresh air into the exhaust system to lower emissions. The sensor that measures air flow is telling the computer the air flow is below standard.
The system would need to be tested.
Jan 21, 2013 | 2007 Ford Fusion I4 SEL Sedan
Location for fuel filter 07 ford fusion
Ford Fusion 2007 user manual page 245 under FUEL FILTER" section. It states "Your vehicle is equipped with a lifetime fuel filter that is integrated with the fuel tank. Regular maintenance of replacement is not needed.
Aug 21, 2012 | 2007 Ford Fusion I4 SEL Sedan
Have an 1988 chevy camaro, added 22 inch rims and tires, want to go back with steel rims and tires,bought 15 inch rims and tires today,no fit, bolt pattern wrong, do i need 14 inch stock rims? and tires?...
no they gave you wrong bolt pattern . dont matter 13,14,15,16 long as bolt pattern rigth . measure bolt pattern .on 5 lug measure from one stud to the one across from it . maybe 5 inch or 5 1/4 bolt pattern. trucks wheels are differnt than car pattern.
Dec 22, 2010 | 1988 Chevrolet Camaro
Transmission swap what can i use?
They run in 3 year pairs on almost any vehicle. 2000-2003 or 05-07.
I recommend same model like montana. Otherwise the bolt pattern or balancer may be a tad different. You can always measure the bolt pattern. If you can find a venture with the same motor size, then you may be in luck.
Aug 04, 2009 | 2000 Pontiac Montana
Change oil on 07 Fusion
its on the oil pan
Sep 16, 2008 | 2008 Ford Fusion
Hypertech 2007 Ford Fusion - 3.0L V6 - Max Energy Programmer Logo
283 people viewed this question
Top Hypertech Wine & Spirits Experts
Don Hart
Dave braun
Dave braun
Don A
Don A
Are you a Hypertech Wine and Spirit Expert? Answer questions, earn points and help others
