Undefined Had a disk suck in it. I took the disk out but every time I powered it up and hit the open button it power off.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
Because you force pulled it and caused it to jam and its stuck on that one process motion were it will do that. you have to open the whole thing apart and get to the CD port and take the screws out and then slide out the tray and slide it back in. Repeat until the System is reset.
Posted on Nov 26, 2014
My 749 Emerson tablet has a pattern lock and I forgot it, my user name and password, what do I do?
You will need to Factory Reset the tablet. Warning: You will loose everything on the tablet and it will be wiped out completely, returning it to the day you took it out of the box.
1. Turn unit off
2. Hold VOL+ and the Power button at the same time for a full 5 seconds then release both. A dead Android bot should show.
3. When the bot shows, again, hold the Power and VOL+ together, then release VOL+ first, then the Power button last.
From here, you should see "Android System Recovery" on the screen.
4. Used the VOL+ and VOL- to scroll through the selections to pick "wipe data/factory reset" and press the Power button.
5. Use the VOL buttons to move to "Yes - delete all user data" and hit Power to select.
6. Use the VOL buttons to select Reboot now and hit Power.
Once complete it's as if you opened the unit for the first time out of the box.
Mar 18, 2016 | Tablets & eReaders
I powered up a RCA RTS202 DVD home theater system then press the open button for DVD and the power keep turning off what's wrong with it and when open it up there was a disk suck but after taken it out the...
try this unplug the system leave it for 30 minutes to an hour with no power that should do a complete reset. Plug it in and see that doesn't fix it.
Nov 15, 2014 | Audio Players & Recorders
Dvd8723uk curtis dvd player wrong region
region code solution as per
http://www.dvdcodes.net/newCodesAZ/codesD/DigixMedia/DigixMediaHT-1056A.php
Power up the player and open the tray. With the tray open, hit the setup button and then 0000 and then the "Up" button.
On the Setup menu, go to Version and hit enter. Go to region code and change the number to 0 for region free and hit setup again to save.
Or
Press the SETUP button. The setup menu appears.
Press ZERO on the remote control four times - 0000
Press the CHAPTER FORWARD button - the one on the bottom right of the remote control unit that looks like a double arrow with a bar.
A new menu item appears, "Version". There is a REGION option you can select, and this can be set to zero "0" for all regions. Once you see its set to region 0, press SETUP to exit, close the tray and power off. When you power up again, its region free. RCE disks work fine in this unit.
To recap - open the tray, press setup, press 0-0-0-0, press Chapter Forward, select Version, choose 0 for region free, press setup again.
Or
1) Turn on the System
2) Open the tray
3) Press "setup" button
4) Press four times the number "8": 8888
5) Press the "Next Chapter" button (>>|)
6) Appear a menu called "Setup Factory"
7) Select with the cursor movement key "Region All"
8) Press "setup" button to save de changes.
Sep 09, 2008 | Digix HT1056A DVD
Fix for DVD Player
Try making DVD player multiregion
Or
Or
2) Open the tray
Aug 31, 2008 | Digix HT1056A DVD
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
Curtis region error
This region code solution as per
Or
Or
2) Open the tray
Aug 17, 2008 | Digix HT1056A DVD
DVD8723UK
this region code solution as per
Or
Or
2) Open the tray
Jul 11, 2008 | Digix HT1056A DVD
Toshiba sd-4205 5-dvd carousel changer declares mecha error during startup, will not eject tray.
This may not work for everyone, but.....
I had the same problem with the Toshiba SD-3205. After unplugging, trying button combos, etc, nothing worked. I could here a slight whine inside the machine, and then again...."MECHA ERROR".
I turned the unit on its side to see if there was a manual tray button on the bottom. Nothing. Then just to try it, I turned the machine off and on again while on its side.
It started up, I heard a clatter, and then the display changed to "INSERT DISC". I placed it the right way up again and pressed "OPEN TRAY" and it worked!
My theroy: There was one DVD in the carousel, and I think last time the tray shut, it got wedged somehow and prevented the carousel from rotating. Turning the machine on its side and pressing "OPEN" is what dislodged the disk.
Jul 09, 2008 | Televison & Video
DVD Tray will not open
Uhm..
Unplug it/turn it on and off
Try to press the eject button and lightly pry the tray open with your fingers.
Call support.
Good luck
Dec 21, 2007 | Jwin JD-VD130 DVD Player
Disk Tray Will Not Open
Hmmmm, I see! Sometimes on my xbox the tray does not open. Maybe if you hit the top of your DVD Player a few times the disc tray may open. You must first click the button to open it then hit it on the top. If that doesn't work then sorry. From Jake @ www.Drama-King-Jake-2.piczo.com!
Oct 12, 2007 | Televison & Video
61 people viewed this question
 Grubhead
Grubhead
