Question about Samsung AQV09JA Classic Wall Mounted Mini Split Heat Pump - 9,000 BTU
What does a three chime signal mean just before shut down on a Samsung mini-split Classic #AQV09JA
The turbo light (bottom) blinks red also
  • 101 Answers
I cant find anything about the 3 dings but it shows you how to check for error codes!
http://www.quietside.com/classic/downloads/Service%20Manual%20AQV09_12.pdf
Posted on Nov 26, 2014
4 Suggested Answers
  • 81 Answers
SOURCE: my samsung split type airconditioner is shutting down.
This is an outdoor unit error. I would have the system serviced.
Mat
Posted on Jul 16, 2009
  • 3247 Answers
SOURCE: I have a SAMSUNG Split
It might help if you can confirm whether the unit is running in heat or cool mode when you observe the problem.
Do you actually hear the compressor in the outdoor unit start before the indoor unit stops blowing air?
Please confirm.
Is your user manual like this?
Posted on Sep 25, 2010
baraquielnar
  • 247 Answers
SOURCE: my samsung mini split comes
replace your thermistor possible damage it is attach on the main pcb board then observe after replacement.
Posted on Mar 05, 2011
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
Mini split Samsung aqv09ja flashing but no turn on
Ive seen and heard of this fault before. Most of the time its a failed outdoor Electronic board but sometimes, it can be the indoor as well. Be safe and change both. The AQV 09 is notorious for this problem.
Oct 18, 2013 | Samsung AQV12VBCN Vivace Mirror Finish...
I have samsung mini split AQV12J I NEED CODE
AQV!2 will run about 30 min then start flashing red on indoor unit and shut down, can wait a few minutes cut temp up and down and it will restart. Possible low Freon level?
Feb 11, 2011 | Heating & Cooling
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Samsung HC
Replace the Power deflection board that should solve your problem. You can get a replacement board for your model at the following link.
http://servicemanuals.vstore.ca/product_info.php/pName/p59a-pwr-def-board/cName/samsung-parts
Apr 27, 2009 | Samsung HC-P4752W 47" Rear Projection...
No picture or sound
Hi, your color wheel needs to be replaced, the bearings fail causing the grinding noise, the new ones use "air bearings" so they are supposed to last much longer, video-tek
Mar 26, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
The samsung monitor ssc21web shows system initialize... the three periods blink
ssc21 web does not work, It was a cameras shut down it says LA and AL why
May 15, 2008 | Samsung 4 Channel Dvr
Samsung AQV09JA Classic Wall Mounted Mini Split Heat Pump - 9,000 BTU Logo
208 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
