Question about Dryers
Does a kichler model # uc7206t fan remote have reverse?
    New Friend:
Mine does
Posted on Sep 30, 2015
  • 2,210 Answers
Surely the blades are formed to work only one way? To have reverse flow you would need to reverse the blade angle.
Posted on Nov 15, 2014
2 Suggested Answers
  • 3640 Answers
SOURCE: i have a kichler ceiling fan operated by a remote
there should be a switch to reverse it, on the fan itself. have a good day !!
Posted on Jun 05, 2011
Does a kichler ceiling fan remote model # uc7206t have reverse?
www.kichler.com/customer-service.aspx
Almost all ceiling fans have reverse. The switch is usually on the side of the fan so one must get a ladder to get to it. Air flow to be up in winter and down in summer.
Nov 14, 2014 | Dryers
Battery for uc7206t
Most pharmacy stores carry all size batteries.
Oct 20, 2014 | Dryers
Kichler ferron 60" why ceiling fan will only move very slowly remote does not appear to be working
If your Kichler ceiling fan appears to have lost touch with the remote, try the usual routine of removing batteries from the remote, pressing all buttons to eliminate a stuck button as the cause, then reinstalling the old batteries (or new batteries) and testing operation. If no luck, disconnect power at the source, not the fan, pause briefly (to "reset" the fan control) and reconnect power to test operation. If still no luck, the remote receiver in the fan or the remote itself may be defective.
Aug 31, 2014 | Kichler Dryers
Kichler uc7206t
I don't think that's the correct fan number but if you look on the socket, it should have the wattage.
Jan 05, 2014 | Dryers
I need remote control for for kichler fan model # 35005
THIS ITEM NUMBER IS INCORRECT. THERE SHOULD BE ATLEAST 1 MORE NUMBER FOLLOWED BY A COUPLE OF LETTERS. IF YOU CAN POSSIBLY FIND THE CORRECT NUMBER I CAN HELP BY GETTING YOU A PART NUMBER FOR THE CORRECT REMOTE THAT WILL BE NEEDED. PART NUMBERS ON FANS ARE CONSISTENTLY FOUND ON THE CANOPY, THIS IS THE PART WHERE YOUR FAN MOUNTS TO THE CEILING. I CALLED OUR REP AT KICHLER AND SHE SAID THIS WAS AN INCOMPLETE NUMBER. HOW OLD IS THE FAN IN QUESTION? ITS POSSIBLE IT MAY BE DISCONTINUED IS WHY WE CANT COME UP WITH ANYTHING.
Dec 04, 2013 | Kichler Lighting Dryers
Kichler uc7206t
The model # should have 6 digits and 2-3 letters at the end.
Aug 04, 2013 | Dryers
Kichler uc7206t
Check for correct battery installation
Apr 22, 2013 | Dryers
I have a brand new Kichler Ceiling Fan/Light installed in new home. This one for the M-Broom came with Remote UC7206T. The function which controls Fan and Fan speed works fine but I cannot the Light...
Something that may work (based on my experience). Shut off power to the fan (the circuit breaker). Remove the battery from the remote and push all the buttons just in case one is stuck. Reinstall the battery. Turn the CB on. Check operation using the remote.
Dec 29, 2012 | Kichler Lighting 300106OBB Ceiling Fan
How to reverse kichler ceiling fan, UC7206T
Stock Kichler ceiling fan c. 2006, works with replacement remote control 337001WH hand-held unit from Amazon 2013. Started running backwards when two remotes were activated at the same time by accident. Random button pushing on two remotes simultaneously got it to go back to forward. (Apparently original remote hand-held transmitter had forward/reverse setting, but the substitute 337001WH transmitter doesn't. When two transmitters run at the same time, the fwd/rev code may be decoded in the collisions at the receiver. Thank goodness!)
Jun 13, 2012 | Kichler Lighting 300105CTO Ceiling Fan
Dryers Logo
249 people viewed this question
Top Dryers Experts
