Question about Kenmore Refrigerators
Were is the defrost timer in double door Kenmore refrigerator
Every thin check OK need to check the defrost timer
    Sergeant:
  • 251 Answers
What's your model number? Kenmore is just a name Sears slaps on appliances made by many different manufacturers. It's difficult to say exactly where it's at if you don't provide the model number.
But, be that as it may, it's never in the freezer section. If you have an older unit, try looking up top near the thermostats inside the fresh foods side. If you have a really old unit, take off the kicker grill plate on the bottom of the refrigerator and look to the left side for it. And, if you have a newer unit that is digital, it's part of the main control board.
Good luck
Posted on Nov 15, 2014
the dr
  • 447 Answers
SOURCE: Refrigerator not cooling
Maybe the cold control (thermostat)
Posted on Jan 10, 2008
  • 327 Answers
SOURCE: Kenmore 596.73502201 Not cooling. Compressor , fan, seal ok
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Posted on Dec 19, 2008
  • 93 Answers
SOURCE: Need to Replace Defrost Timer
check bottom back left should be a small hole with a small plastic place to turn with a srew driver some are insidethe fride on the left side arond where the lite is if you see a mall plate with a srew open it it should be there thanks from gilles
Posted on Mar 15, 2009
woodchuck789
  • 4059 Answers
SOURCE: how do i replace the defrost timer Kenmore
Part 12 on this diagram is your timer. It's in the fridge side with the controls. http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fM0208106-00003.png
Posted on Dec 15, 2009
heatman101
  • 43501 Answers
SOURCE: Defrost timer starts running when freezer door is opened
The defrost timer motor is weak and the simple vibration of opening the door gets it working again...replace the defrost timer and you'll be good again.
Posted on Feb 04, 2012
Kenmore model 105.79202990 runs continuously
Door seals look OK? Temps in freezer and fresh food compartments are? Double check your model number it does not come up so I cannot find other possibilities like a ice chute door stuck or defrost controls
APPLIANCE 911
Nov 12, 2015 | Kenmore Refrigerators
Feb 04, 2012 | Refrigerators
Temperature in refrigerator compartment is slowily going up. Freezer is OK. Doors are closed properly
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 20, 2010 | Kenmore 24.8 cu. ft. Trio French Door...
It is not cooling as it should like a refrigerator. As if the fan is on.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 15, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Frost free fridge freezing up
Sep 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
How to check defrost timer on Kenmore side by side 596-52673200?
You don't have a defrost timer, you have an adaptive defrost control which determines when to defrost based on how often door is opened etc. If you have a defrost problem check , defrost heater, defrost thermostat
Sep 08, 2009 | Kenmore 57029 Side by Side Refrigerator
Self defrosting not defrosting not cold in bottom of frig has top freezer
How to checkeverything
check defrost timer, defrost heater, defrost thermostat. Inmost newer models the timer has been replaced by an electronic control board.If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicksand everything shuts down. The heater should now come on. If it does, replacethe timer. If it doesn't, check the heater and defrost thermostat. Turn thetimer again till everything starts back up to end the defrost cycle.
Sep 06, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Icemaker is not working, but water dispencer is OK Model Kenmore Elite 106.45422800
Hi...
Try to check this
Good luck !!
Regards
PCmania
Jul 08, 2009 | Kenmore Refrigerators
i think you will find fan has stopped working - take back plate off inside freezer and check fan goes and that pipework is not iced up
Sep 10, 2008 | Kenmore Refrigerators
Refrigerators Logo
46 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
