Question about Motorola Mobility GOOGLE 8GB MOTO G XT1032 BLACK FACTORY UNLOCKED ANDROID 3G 2G GSM MOBILE PHONE 2G QUAD BAND & 3G 850/900/1900/2100
My motorola 8gb turned of and can't get it back on tried the power button and volume still dnt work
I have no clue whaat happened it charges but wnt light up when I try
  • Official Brand Answer
  • 3,100 Answers
William
Check out
MOTO MOTO 4G LTE
It might help solve your issue.
Mark
Motorola Support
Posted on Nov 15, 2014
  • 1257 Answers
SOURCE: 6600 nokia
There might be a software problem and some programs are not allowing you to start mobile ,so you can format the mobile so that you can have default settings for your mobile..........if that also doesn't solve your problem than go with flashing the phone.both the process are described below
method 1 :
*#7370# master reset (like new phone)
method 2 :1. Make sure you phone is fully charged.
2. Backup your contacts list and personal files to MMC memory card (if possible).
3. Switch-off your 6600 phone.
4. Press and hold these three keys together
-Green dial key,
-Star key (*)
-Three key (3)
then press the power on/off to swtich on the 6600 phone.
DO NOT let go the three keys until you see the “formatting” screen displayed
5. After a few minutes, the format will be complete. Your 6600 will now be at its original factory settings.Disclaimer: I will not be held responsible for anything that happens to your phone as a result of following my guide. Use this guide at your own discretion and risk.
Was this solution helpful? Show your Appreciation by rating it:
Posted on May 14, 2008
kibbs
  • 234 Answers
SOURCE: Motorola V3x won't turn on
ok! battery is problem in your mobile! change the your battery! thats it!
thanking you...........
keep rating meee
Posted on Jul 08, 2008
  • 10 Answers
SOURCE: it wont power on & has a red flashing light
2 things, first bad battery, sometimes bad battery works for few minutes then your phone just dies on you, it says its fully charged but it aint. That red light flashing only means that your phone has LOW BATTERY. 2nd your phone software has problem. If you have another ericsson that uses the same battery you can check it the battery is ok, its the only way you can find out if the battery is good. If the battery is doing ok with another cellphone then your cellphone software has problem.
Posted on Jan 05, 2010
SOURCE: my motorola cliq just turned off and will not turn
my motorola cliq just turned off and will not turn on i tried charging batterey but nothing happens the screen staays blacked out and the key board only lights up when plugged in to charger
Posted on Jul 17, 2010
SOURCE: Nokia 6600 does not open
my nokia mobile modle6600 many problem like when start the mobile 1to 2 minutes display show the white and many time does not start
Posted on May 10, 2011
How can i sign into my visual land connect ?
That is a hard reset. I have no clue why you were told to do so.
Feb 01, 2015 | Visual Land Connect 9" Android Tablet...
My moto G shut itself off and won't come back on. i had it for 1 month. won't charge either.
Make sure it is not dead. Hold the volume down key and power key at the same time till you see the boot screen. It will then boot up and be fully functional.
Oct 26, 2014 | Motorola Mobility GOOGLE 8GB MOTO G XT1032...
Why phone doesn't power on after charging ?
Frozen.
Does it show as charging when plugged in?
Try the next step when plugged in and/or unplugged.
Try: Hold the Volume Down button and the Power key simultaneously for about 15 seconds. After holding them down for about 20 seconds if the phone didn't power cycle then release the keys and try and turn the phone on like you normally would by briefly pressing the power button.
***If this did not work Try it using the VOLUME UP button with the same process*** this activates a "Power cycle"
Sep 19, 2014 | Sony XPERIA M2 LTE D2306 WHITE 4.8IN...
Motorola Atrix 2 doesn't go past the at&t start up screen
Has your Motorola Atrix HD stopped responding? Is your Atrix HD frozen on a lit up black screen as though the screen is getting power but will not turn on? Will the phone not power on? Is it completely dead? Here is a tip that can fix it in less than 25 seconds.
Sometimes the Motorola ATRIX HD (MB886) OS 4.0-4.1 just gets a little confused and doesn't want to work. On most other Android phones you would just pull out the battery count to 10 put it back in and then be good to go.
But guess what... you can't pull the battery out of the Motorola Atrix HD, thankfully Motorola (my 2nd favorite Android manufacture) built in a solution.
Before we start getting into troubleshooting make sure that you have tried to hold the power button down for 15 seconds to see if there is any response.
Also try and charge the phone with the original charger that came with the phone. If the battery of the device has drained to zero percent then it can take a few minutes to a couple of hours for your battery to start charging correctly again.
If you have tried holding the power key and have already tried charging it with its original charger and there is still no response, then proceed to the next part of these instructions.
What you need to do is a Simulated Battery Pull. Here is how you do it
  • Step 1: Make sure that the power is completely off. I know it doesn't want to turn on and that's part of the problem but make sure that the phone is not plugged into a charger either. Note: if the keys on the bottom of the device are lit then the phone is on, if there aren't any lights currently showing or lit up then don't worry about whether your phone is on or off, simply proceed to step 2.
  • Step 2: Hold the Volume Down button and then the power button and continue to hold these 2 keys for 20 sec (count out loud it could take 15-30 sec).
  • Step 3: The phone should power cycle, powering back on to full.
  • Step 4: Enjoy, your phone should now be working 100% and you should be good to go. If it happens again just do the same thing.
  • Step 5: if it didn't go through then try it again. Seriously try it a couple times this should fix the issue, if not proceed to the next step.
If the simulated battery pull doesn't fix the issue and the Atrix HD still doesn't power on or it's still showing a black screen then the problem might be more serious.
Try this instead
  • Step 1: Make sure the power is completely off and that the phone is NOT plugged into a charger, just like we did before.
  • Step 2: This time instead of the Volume Down key use the Volume Up key. Hold the Volume Up and the Power key simultaneously for 20 seconds and see if anything pops up on the screen.
  • Step 3: Release the Volume Up and Power keys if/when you get any response.
  • Step 4: If you get some options then use the volume down key to cycle through your choices. Look for an option to restart or reboot. (don't do the wipe data/factory reset option... yet... that's kind of a last resort)
  • Step 4: Once the option is selected use the power key to make the selection.
  • Step 5: The phone should reboot and you should be good to go.
If it doesn't, which it should, proceed with the second method again but select the wipe data/factory reset option mentioned in Step 4 above. The Reset is going to wipe everything from the phone and if it is a software bug that's causing these issues then it will fix it. It will wipe everything from the phone though (good and bad) so use this as a LAST resort.
If the keys on the bottom of the phone are lighting up and or you seem to be getting messages or calls but you just can't see anything on your screen then chances are high that your display malfunctioned and will need to be replaced.
Apr 24, 2014 | Motorola Mobility At&t Atrix 2 Mb865 - 8gb...
WHY MY SAMSUNG GALAXY BEAM WON'T TURN ON
1st check battery and try to on recovery mode home key+volume down key+power button then reset factory setting thats all
Dec 05, 2013 | Cell Phones
My nexus 7 wont go past multicoloured x.. cant switch on/off. tried hard reset and nothing works
Important:Plug your device into power outlet
Step 1: Power off Nexus 7
Step 2: Power on while holding Volume Down/Up
(enter BootLoader)
Step 3: Press Volume Up to toggle to "Recovery Mode"then press power to select
Step 4: Hold The Power Button and tap Volume Up when you see "No Command"
Step 5: Press & hold Power Button & Volume Up Button Again
Step 6: Toggle with vol down and vol up / power at wipe data (all data) & reboot
Nov 20, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
Motorola Xoom Mz604 does not turn on
If you press down volume and plug into USB cable into computer. What happens?
Mark
Motorola Support
Apr 12, 2013 | Motorola Mobility Xoom Mz604 32gb, Wi-fi,...
My nexus 7 will not turn on
You can try a hard reset. Hold down the power button and the volume buttons at the same time. The device should then power on and you can follow the on-screen prompts.
Hope that helps!
Mar 18, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
Dropped phone and now doesn't work
Try any of the below combination.
  1. Hold Volume Up + Volume Down + Power.
  2. Hold Volume Up + Home + Power.
  3. Hold Home + Power.
  4. Hold Volume Up + Camera
Dec 12, 2017 | Samsung Cell Phones
I have a Sherwood Nottingham R-925RDS receiver. No matter what input I select it does not connect to the amplifier section. Everything else appears to function ok. Unit switches on & off, correct...
Let's work with FM as that is ONboard and can't be connected wrong. Does THAT work?
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
May 06, 2011 | Sherwood Audio Players & Recorders
Motorola Mobility GOOGLE 8GB MOTO G XT1032 BLACK FACTORY UNLOCKED ANDROID 3G 2G GSM MOBILE PHONE 2G QUAD BAND & 3G 850/900/1900/2100 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
