Question about Oster Microwave Ovens
How so you change a lightbulb on the OSter OGT6701 microwave oven
techman
  • 3130 Answers
SOURCE: CHANGING LIGHTBULB ON MICROWAVE
they should be torx # 15 0r # 20 this is not aifficult tool set to get unless the manufacturer put high security type torx and those have a small nipple in the middle of the screw so the tool has a small hole in the middle of the end. Good Luck
Posted on May 21, 2006
SOURCE: Changing oven light
I have a light bulb in my oven that is frozen, won't come out. The whole unit turns when trying to remove it. Any suggestions?
Posted on Sep 17, 2007
  • 184 Answers
SOURCE: Replacing lightbulb in Sharp R953M combi microwave oven
most microwave ovens built in the last 20 years do not have an
access panel to the light bulb. you must remove the screws on the back of the microwave that hold the outer sleeve in place.
Then pull upward and backward on the sleeve to disengage it
from the front lip of the chassis. the light bulb should be close to the front of the microwave behind the control panel. Some lights
are not unscrewable from the socket, but the socket and bulb
come as an assembly.
Posted on Mar 27, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: HOW TO CHANGE VIKING MICROWAVE LIGHTBULB VMOS200
The Viking VMOS200 is essentially a rebranded Sharp R-530E.
One or both of these service manuals should cover disassembly and location of the bulb:
http://www.microwavedisplay.com/r530ekt_r530est_r530ewt_sm.pdf
http://www.microwavedisplay.com/r530es_sm.pdf
Posted on May 30, 2010
thunderz
  • 232 Answers
SOURCE: How do I change the
go to appliance store and ask.
Posted on Mar 13, 2011
Oster microwave starts when door is closed but no buttons pressed
This is usually caused by a door switch that has come loose or out of adjustment.
Jul 19, 2014 | Oster 0.7 Cu. Ft. Countertop Microwave -...
Change lightbulb
most times you have to take the outer case off (the stainless steel part) and then you can see all the wires circuitry etc. thats how you get to the light bulb. make sure you unplug the microwave first and do not touch where it says electric shock hazard it will shock you even if not plugged in
Jul 16, 2012 | GE JES1142SJ Microwave Oven
How to change a fuse in oster microwave oven
Unplug microwave, remove top," several screws" look to the right where the keypad control board is, now look down where the printed circuit board is, fuse should be near by clipped in, pop fuse and replace with same current rating, assemble before testing, "lethal voltages present"
Apr 21, 2012 | Oster OGB61101 Microwave Oven
May 28, 2010 | Viking VMOR205SS Microwave Oven
How do I change the lightbulb?
4359741 You have to remove the outer case and it will be accessible. Eric
Aug 02, 2009 | Whirlpool GT4185SK Microwave Oven
Shorted it while changint lightbulb
some microwaves have an internal fuse.
Mar 23, 2009 | Maytag MMV5207AAS Microwave Oven
Changed lightbulb
simply changing the lightbulb should not cause a problem like that. It sounds like you accidently shorted out two terminals during the process, which probably blew out the power board on the unit. I wouldn't trust it any further unless you were to take the entire unit apart and find the "blown up" component and replace the board that it's on. Believe it or not, it's not that hard a job if you're up to it.
Apr 22, 2008 | Goldstar MV-1526 Microwave Oven
May 21, 2006 | Kenmore Brew 'n Wave 63992/63999 Microwave...
Microwave Ovens Logo
66 people viewed this question
Top Oster Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
ray gallant
Are you an Oster Microwave Oven Expert? Answer questions, earn points and help others
