Im trying to hook up my computer to my plasma tv. I have the correct vga to hdmi adaptor, with a sound jack and usb for power. into the adaptor, i have an hdmi cord running to the tv. However on the t
Im trying to hook up my computer to my plasma tv. I have the correct vga to hdmi adaptor, with a sound jack and usb for power. into the adaptor, i have an hdmi cord running to the tv. However on the tv i get the "no signal" box. I tested the set up on an led tv and worked immediately. I also tried turning the tv and computer off and on while it was all hooked up. I do not have an option on the tv to change resolution or anything like that, the closest thing i have is pic size, but i think its only exactly that. Its a large sanyo plasma tv and a desktop pc running windows 7
  • 182 Answers
Make sure the tv is on VGA
Posted on Nov 15, 2014
5 Suggested Answers
  • 4 Answers
SOURCE: ilo 42" plasma tv
Go the the settings on the cable box. look for output resolution, then change it to 1080i and 720p. now turn the box off and back on your tv will now display the input of wither 1080i or 720p depending on the hd channel your watching.
Posted on Jan 12, 2008
SOURCE: No Signal HDMI
Had the problem. Turned out to be a defective hdmi port circuit board.
Posted on Aug 27, 2008
  • 3600 Answers
SOURCE: Hooking Sanyo TV up to a computer
you need a hdtv tuner Hidef is different format than the rca jacks and digital won't worrk sorry.
Posted on May 24, 2009
JulesPCaut
  • 702 Answers
SOURCE: problem using Audio 3 sound inputs for HDMI video
Normally this problem is simply a matter of selecting the correct default audio playback device in the Windows control panel (sound option).
Check the Playback tab and set the default device to either DVI or HDMI.
http://pcaudiohelp.com/fix-hmdi-sound-to-tv
Posted on Dec 03, 2010
I have a 42 in lcd i hooked my computer up to it the computer sound isnt comeing out of the tv how do i get it to come out my suround sound there is a jack like a head phone plug where i hooked the...
Now i assume you have connected the Computer using a VGA cable ( 15 D pin connector )bobhifi_41.jpgbecause if you had used an HDMI cable the sound would have come by default. The VGA cable only carries analogue Video signals. So you will have to get 3.5 mm phono to 2 RCA cable to connect the sound out of the PC to the TV's audio in socket ( next to the VGA socket labeled audio IN )
Apr 22, 2011 | Sanyo 42 in. LCD TV
What cables do I need? I used a vga to vga cable and received a picture on the tv but no sound.
if you are trying to hook your computer to your tv you need an hdmi cable if your tv or computre has no hdmi port than you need to use a 1/4 to 1/4 in cable running from your headphone jack on the computer to a 1/4 input on your tv as the vga cable you are using does not carry audio.
Mar 27, 2011 | Computers & Internet
Connected samsung TV to PC vi VGA cable as suggested by samsung support. Visual working correctly, no sound output. Tried hooking up standard audio jack leads with l-r splitter to TV to get audio. No...
You need a seperate speaker system when your tv is on vga there is no option to recieve a sound input. In fact if you hook your cables for sound back up to the tv you will probably find that there is sound but on a diffrent input channel. The other option is to use a diffrent type of connection like hdmi if your computer and tv support it which DOES support audio and vido throught the TV.
Mar 09, 2011 | Samsung Televison & Video
I have a lg plasma and im trying to connect it to my pc hooked up the vga in the comp and on the backside of my tv, have the audio and hooked it up to the audio, but when i change input i can see the pc on...
It sounds like you are using the wrong audio input jack, by chance are you using the audio cable with RED and WHITE RCA to mini stereo plug ?
If you look at the VGA port on the the TV, you will see a small mini phone jack (PC audio) close by, that will be for the sound input when TV is in PC mode.
Please verify for me.
Dec 31, 2010 | LG 42PX5D 42 in. Plasma HDTV
I wANT TO CONNET MY LAPTOP TO MY CRT TV
What you need:
This is hard to define initially as there are so many ways to achieve this depending on what type of television you have and what video outputs your computer offers. You may also find that you only want to attach the stereo, and leave the TV disconnected, or vice versa.
.HDMI - High Definition Multimedia Interface: Ideally we will all have an HDMI connection on both our television and video card, but most likely don’t have it on either. Many new LCD screen and Plasma displays offer this mother of connections. They are also becoming a little more popular on Video cards. This will give you the highest quality signal. This format can also carry audio. This is very easy to connect from one device to another. It offers the same video quality as a DVI.
here are some tips that will help
Computer has HDMI and TV has HDMI – Use HDMI
Computer has DVI and TV has DVI – Use DVI
Computer has DVI and TV has VGA – Use VGA + Adaptor
Computer has VGA and TV has VGA – Use VGA
Computer has S-Video and TV has S-Video – Use S-Video
Computer has RCA and TV has RCA – Use RCA
Computer has S-Video and TV has RCA – Use RCA with adaptor
Computer has RCA and TV has S-Video – Use RCA with adaptor
Sep 10, 2009 | Gateway CX200S Tablet PC
May 24, 2009 | Televison & Video
Blue ray lap top to hook up to tv with cable
If your laptp has Blue Ray DVD it likely has an HDMI out jack. Connect this to the HDMI input of you tv. If you TV does not have and HDMI jack but had a DTV jack then get an HDMI to DTV adaptor.
Apr 26, 2009 | Televison & Video
Not to computer saavy so please keep it simple. I have a Sony Vaio VGC RA840G desktop with 5.1 surround sound. Also have a Samsung LN46A850 S1F HDTV. Also a home theater system. This is hooked up to cable...
From the looks of the TV manual you have everything right, so it's very odd you're running into this problem.
Have you tried swapping through the sources? I find with one of the TVs we have on display at work that any time I'm having some troubles with it I will change the source from PC to something else, then back to PC.
If that doesn't work then I'd suggest you try reseting the sound settings back to factory default. The instructions are on page 45 of the TV manual. From the TV menu select "Sound", then "Sound Reset", then either "Reset All" or "Reset Sound Mode". I would suggest reseting all.
Last option would be to try using the headphone jack in the side of the TV, though this is a last resort kind of thing since you would have to unplug it every time you wanted to use the cable box.
Hope this helps :)
Apr 16, 2009 | Sony Computers & Internet
Plasma Hook up
listen what you do is go down your local electronics shop and buy a video card or scart card which allows yyou to connect your pc to your television and v v . and the surround system wer you connect your pc speakers you buy a lead whiocih allows your to convert a phono plug to a 9mm phone jack and use that. hope it helps you.
Aug 22, 2007 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
