U might have to hit key 5-6 times before it prints
It doesnt recognize when you depress a letter sometimes takes 5-6 trys before it actually prints anything
  • 453 Answers
Make and model of the typewriter would be helpful. It may need to be cleaned.
Posted on Nov 16, 2014
4 Suggested Answers
Geno111
  • 183 Answers
SOURCE: letters & numbers not printing correctly
The most common reason for this is something interfering with the printwheel. Turn off machine. Take out the ribbon, then pull back on the black lever to the right of the printhammer. This will tilt the printwheel towards you. Look to see if there is anything caught in the printwheel. Also check to see if the corr tape is installed properly. Corr. tape and ribbon should both be between the two metal fingers and the metal cardholder. Push the black lever forward and look to make sure the two metal fingers are not bent into the printwheel. If they are, simply push them forward and bend them so they don't. Re-install the ribbon, making sure it goes on the other side of the fingers. Turn machine back on and test machine. If it still doesn't work, you will need a trained technition to determine the problem.
Posted on Oct 28, 2008
  • 3594 Answers
SOURCE: I Have a EM-630 that when it prints it sometimes
Check the plastic card holder there can be a bild up of goo on it from the ribbon and correction tape.
DickyO
Posted on Sep 21, 2009
Jimsta01
  • 405 Answers
SOURCE: When I use my Brother ML 300 the letter that I
The daisy wheel is deffective and will need to be replaced, this will resolve the issue.
Posted on Jun 27, 2010
My brother mfc-6490cw will not print any magenta colors. I have run it through the regular cleaning process with no success. What else can I do to fix this?
You need to do the Power Purge Option: It works like a charm on my 6490....
Hold down the menu key. While still holding the menu key, unplug the machine and plug it back in. Do not let go of the key until the machine reboots and the screen says "maintenence". Hit the following keys: 7, 6, 4,black start. The machine will then go into "power purge" or deep clean mode for about 5-7 minutes. When complete hit: 99 to get out of maintanence and reboot. Be sure to have extra ink cartidges on hand as it does use up a lot of ink but this process works the best every time when the printer wont print
Mar 30, 2011 | Brother MFC 6490CW InkJet Printer
Takeing about 5 turns on the key before starter
If you hear a "clicking" sound when you hit the key, it is likely the starter solenoid. Sometimes they stick, especially if its cold where you live. Hitting the key numerous times will jar it enough so the car will start, sometimes. You'll likely need to replace the starter if this is the case.
Jan 31, 2010 | 2004 Hyundai Elantra
My car radio doesnt have a remote and i want to unlock it how do i do it
you need a remote for this .
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
Jul 03, 2009 | Kenwood KDC-MP235 CD Player
KDC-716S sometimes plays CD, other times just tray drop
Type 1
Type 2
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Jun 01, 2009 | Kenwood KDC-716S CD Player
Typing delay
I would suspect that you maybe have spyware and malware issue's. you need to get that process list down to an average of 35-40.
spybot is an excellent application to help in a situation like this. Search for it on google.
Apr 16, 2009 | Computers & Internet
Ckeck printer ##343
its a printer reset error press
*AF-Key = Additional Functions key = the black button with the star in a head above it.
1) Enter SERVICE MODE. (Press AF-Key, followed by "scan", "copy", "scan" -Keys)
2) Select TEST MODE (press right arrow button 13 times).
3) Hit -OK-
4) Select [8] PRINTER TEST
5) Hit -OK-
6) It'll now say "- 8-2 +" press the right arrow key once to get "- 8-3 +"
7) Hit -OK-
8) Select 0. [INK COUNT].
9) Hit -OK-
10) It should return to showing the "8: Printer Test - 8-3 +"
11) Press the [Stop/Reset]key - (black key with triangle and circle on it) - (returning to the state of 4), and then press the [ON/OFF] key.
Cleaning the print head:
At any time, DO NOT wipe the actual print head with your fingers. Use ONLY water.
-Remove print head assembly from printer.
-Remove ink tanks.
-Use running warm water, wash away the exess ink that is dried around the print head.
-Take one disposable mug, fill with hot water, drop the print head assembly in there, and let it soak for an hour, or so.
(-IF you have massaging shower head, with spray jet -function, use this to deep clean the actual print head.)
-Dry it up carefully, do not wipe actual print head, just tap gently with soft paper.
-Install ink tanks, install assembly to printer, let it settle for some time (5-30 minutes)
-Run Nozzle check, cleaning, print head alignment
hope this helps if you have further problem do let me know
pls appreciate by rating this solution
Aug 13, 2008 | Canon SmartBase MP360 All-In-One InkJet...
Swintec 2600 Electric Typewriter
MARGINS: Left margin space or tab to where you want margin set and depress the mar L key. Sometimes the key has to be depressed as you hit the code key. If you want to move carrige to the left, go to margin hit margin release and bk space to where you want. Same with the right margin only use th R margin key. Code key usually keys have second message are in green, yellow or red. Use code key with the small print on the key to activate that function.... Good luck
Aug 01, 2008 | Swintec 7040 Typewriter
k24674
