Question about Konica Minolta bizhub Office Equipment & Supplies
How do i remove error c03ff from my bizhub 162, by the way way i did the following helping procedures but did not work...first i pressed and held * together with # then turn on switch in order to by p
How do i remove error c03ff from my bizhub 162, by the way way i did the following helping procedures but did not work...first i pressed and held * together with # then turn on switch in order to by pass the error when booting...then i entered service mode by pressing utility key ,stop, 0, 0 ,stop, 0 ,1..when i got to service mode, went to 2. Adjust,model setting, 20ppm, 18ppm,16ppm..the thing is you need to select the right ppm for your match, but i tried all of them but did not work. after reboot the error still re-Appeared. so what do you think might be the solution. to some off you having the same issue please try the above and hopefully it will solve your problem..thank you
    Habit-Forming:
    New Friend:
  • 166 Answers
You forgot to press [Yes] button after you select the "16ppm". [Yes] is like [Enter] from the computer.
Posted on Nov 18, 2014
  • 10 Answers
SOURCE: service manual for KONICA MINOLTA Bizhub 210/162
Swithc off the machine Press stop button and hold switch on the machine. problem will go.
Good Luck
Posted on Jan 07, 2009
rodco1
  • 6 Answers
SOURCE: how to enter service mode in ricoh aficio 3800
Hold down the two arrow keys and count to 5, hit the enter key, the machine should be in serrvice mode if nor repeat. use arrow ke and scroll to machine press enter scroll to data log press enter scroll to pm counter reset presss enter, scroll to fuser oil press enter and exicute this mod Please. DO NOT GO INTO ANY THING ELSE or you could do serious damage to your machine!! If your machine has a Copy feature expander yopt must press Clear mode, Press 1-0-7 and then hold down the stop cancel key 4sec. go into copy sp mode press 7-804-809 press exicute button again Please DO NOT GO ANY WHERE ELSE as damag can be done to your machine. Hope this helps!!
Posted on Jun 17, 2009
  • 1297 Answers
SOURCE: Ricoh Aficio showing error code SC555
Press the total reset(yellow) key - 1 -0 - 7 and press and hold down he stop ((red) key for more 3 sec.Enter in the SP mode(activate to press on the touch pane) open the front door turn OFF the power main switch,unplugged the machine amd wait 10 sec.Plugged the machine,closed the front door and turn ON the power switch.The copier is worked.If neccessary to check and measurement the continuity of the fusing unit parts:heater lamps,thermofuses,thermoswitch and if cleaning used the izopropilalkohol.
Posted on Oct 01, 2009
  • 158 Answers
SOURCE: konica minolta bizhub 162 have error C0000(main
could be master board (pwb-a) or power supply unit (pu-1) or something that the motor turns is locked up try to you turn the motor by hand whil it is installed in the machine if you cant turn it by hand something is locked up
Posted on Nov 30, 2009
Testimonial: "yes this is right ! i figer out the problem - it was in development unit! tNx"
pineworks
  • 4041 Answers
SOURCE: Can't get past step 2 of the Canon i550 waste tank counter reset.
Hello you can try
Problem for Canon BubbleJet i560 InkJet
The waste ink is in the inside of your printer you need to get at it to clean out,
It may be all screwed down so you need to open all up or get a shop to do it for you.
It not an easy job but maybe you are handy with a screwdriver, it can be messy job.
But after this, you will have to reset the waist ink counter or it will still not work,
But but but but you can always try this to reset it first and clean it out again some time.
Canon Reset waste ink counter
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
C03ff code coming in bizhub-211 ,which bottom should i press to remove it
Wrong model settings. this happens, when we clear all from service mode.
PRESS.....
UTILITY
STOP00STOP01
ADJUST
MODEL SETTING
CHOOSE CORRECT MODEL HERE.
Nov 12, 2016 | Konica Minolta Office Equipment & Supplies
C03ff code coming in bizhub-211 which code should i press
MODEL SETTING ERROR
IN SERVICE MODE-ADJUST-MODEL SETTING
Now choose right model (Like if 211 means 21 PPM so choose 21PPM)
Nov 12, 2016 | Konica Minolta bizhub Office Equipment &...
How to solve the error c03ff for konica 215
Model setting is incorrect the machine thinks ita KonicaMinolta Bizhub when its really set to be a Bizhub 219, 21 or 23 page per minute machine. Get tech out to go into service mode change it to what it really is.
Jul 30, 2015 | Konica Office Equipment & Supplies
Konica Minolta bizhub 215 Printer error C3451& C03FF
For the C3451 Code replace the Fuser
For the C03FF there machine thinks it one model type the circuit board are set to a different model Change setting in Service mode under adjust to proper model.
Apr 01, 2013 | Konica Minolta bizhub Office Equipment &...
What is code c03ff for konica minolts bizhub 215
Model Setting - go to service mode press ( utility stop 00 stop 01 and go to adjust select model press off and on
Jan 24, 2013 | Konica Minolta Office Equipment & Supplies
Error c03ff bizhub 211 konica minolta no se resetea no guarda los cambios
model setting error :)
never change this setting.
if it changed,the Technical Rep.call (C03FF) will appear.
,default setting depend on the marketing area setting.
ex: 20ppm,18ppm,16ppm....
Jul 22, 2011 | Konica Minolta Office Equipment & Supplies
When i am start my hp pavilion this shows Bootmgr is missing alt+cntr+del to restart again it same cycle
1. Error: BOOTMGR is missing:
The following error opens when attempting to start the PC:
??¢ If you recently installed an additional hard drive, turn off the computer and remove the drive before using the following steps:
??¢ Open HP System Recovery:
??¢ CAUTION: Do not perform a system recovery! Stop at the first recovery screen.
- Press the F11 key repeatedly while the computer is starting.
- If you have a recovery disc, turn on the PC and insert the first recovery disc into the drive. Use the disc to enter the system recovery.
??¢ Select Microsoft Startup Repair tool and wait for repair to find and fix errors. When finished, restart the computer; even if the startup repair tool finds errors but cannot fix them.
??¢ If the error message persists, open the recovery manager screen as was done in step 1.
??¢ At the recovery manager screen, press ALT + D.
??¢ Enter the following text at the command prompt: bootrec /rebuildbcd
??¢ If bootrec displays "Add installation to boot list?", press y .
??¢ After bootrec completes successfully, the computer displays "The operation completed successfully".
??¢ To close the command prompt, enter the following text: exit
??¢ At the Recovery Manager screen, select Microsoft Startup Repair tool (again) and wait for startup repair to find and fix errors. When finished, restart the computer.
??¢ The error should no longer open. If it does, perform a system recovery, making sure to backup important files.
??¢ If you removed a hard drive before using these steps, replace the drive. If the error occurs again, make sure the additional hard drive is not set as an active drive. Only the main bootable drive should be set as active.
Dec 12, 2010 | HP Pavilion Ze4900 Notebook
Minolta bizhub 162 error code 32
In Konica Minolta bizhub 210,162,211,163,182, error code "cof32" means "Automatic toner density control abnormality.
To remove this code or you want to get rid of this problem, simply call your technical service representative to solve this problem.
If you want to remove this code by yourself then please perform these actions attentively.
1-Turn the machine ON.
2-Press "Utility" button on front panel.
3-Now press these buttons "stop+0+0+stop+0+1" it means press stop button, then press 0,again 0, then again press stop button, then press 0, and 1.
4-service mode will appear on LCD screen.
5-Now with the help of arrow keys go to the 2nd option which is "ADJUST"
6-Now press "YES" button.
7-Again by pressing the down side arrow key go the option which is "ATDC ADJUST".
8-Press YES button.
9-Now increase the value, for example if the value is 145, you have to enter 155 or 160.enter the value with numerical key pad buttons.
10-After entering the new value press "YES" button.
11-Restart the machine.
Oct 04, 2010 | Konica Minolta bizhub C351 All-In-One...
C03FF Minolta bizhub 210
C03FF, is the improper or unmatched model setting code. go to "service mode" In service mode please select "ADJUST"
in "ADJUST" please select "Model Setting" in "Model Setting" select the cpm, (Copy speed) of your machine, for example if you have bizhub 210, then select "21" from the list. if you have bizhub 163 then select "16" from the list and press "yes" button. code will remove.
Jan 29, 2009 | Konica Minolta DiALTA Di183F Copier
126 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
