Question about Garden
My homelite 3316c chainsaw it seems the idle is off when i start it it runs full throtle
  • 1,169 Answers
I would think that either throttle is hung open where the choke mechanism didn't release it or the throttle butterfly is missing.
Posted on Nov 15, 2014
  • Eugene Rounds Nov 15, 2014
    or unless it a will run at full throttle but you go idle it just dies then you have carburetor problems and adjusting the idle speed screw may not be of any help.
blueextc3221
  • 15935 Answers
SOURCE: chainsaw dies out when gas is pressed to full throtle
Carb needs teardown and cleaning. May be a stuck float or clogged jet.
Spraycleaner just wont cut it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Apr 05, 2010
SOURCE: chainsaw carburetion
Had a similar sounding problem with my stihl MS 250. After two years of heavy and frequent use (with minimal maintenance) it ran perfectly but after three years of little use with no maintenance it began to die if the revs were allowed to drop, ie it wouldn't idle. I hadn't been draining the tank when not in use so assumed a carb gunk problem. Can also be caused by an oily mix or old fuel.
Today I removed the old fuel and fuel filter and sprayed the tank and up the fuel line with carb cleaner. Then I removed the spark plug and filled the chamber with carb cleaner (use a straw to direct), I removed the air filter and sprayed carb cleaner in here too. I gently pulled the starter cord a few times to spread the carb cleaner. I left it for 1/2 hour while I had lunch.
I then rinsed out the fuel tank with fresh fuel, renewed the air filter, spark plug, fuel filter and fuel. I checked the H and L screws were in the right place (they were), before pulling on the starter a few times to prime / flood the chamber. I then removed the spark plug for 5 mins and had a cup of tea while the flooded chamber resolved / evaporated, then fired her up. It worked well all afternoon.
No need for any tricky or delicate stuff if you give this a go first is my advice. Cost only of spark plug, air and fuel filters, fresh 2" mix and a can of carb cleaner. Took less than an hour excluding interruptions. Saved a potentially expensive trip to the shop where I'd have been billed for these parts as a routine matter.
Posted on Jan 02, 2009
SOURCE: homelite runs wide open all the time
intake boot under carb is probably bad, mine did the same thing and this was the problem. about a 6 or 7 dollar fix
Posted on Apr 11, 2009
dontbother10
  • 2220 Answers
SOURCE: homelite xl chainsaw revved up & quit and won't start now
I suspect you have a fuel delivery problem or a dirty carburetor. As a chain saw runs out of fuel they often revv slightly (running lean). HTH
Lou
Posted on Oct 07, 2009
Jim1969pa3
  • 152 Answers
SOURCE: Not running at full throttle
close to the carb you will find two tiny screws. They are labeled H and L. L sets the idle speed. H sets the max RPM. Hold the throttle wide open and turn the H screw. When you find the very top end, back it down some or it will be running too lean. That would make it run hot, and provides less lubrication. Could result in engine failure if you run it too lean.
Posted on Dec 23, 2009
When my homelite 3316C gets hot it stops running. What part do I need to fix this problem?
First make sure cylinder fins are free of debris; otherwords, good air flow around the cylinder.
Second try another known good plug. Plugs can fail when hot.
Third check for spark when it dies, If none present at this time then the ignition coil is failing.
Dec 15, 2014 | Homelite Garden
I have a homelite 3316c when it starts up it goes full throtle it doesnt idle right is there a idle screw
There's a low speed screw and a high speed screw. There is also a tickover/idle screw. Its possible this is just screwed in too far. The high and low screws may have tamper proof covers on for emissions regs. Remove the top cover and you should see the screws on the side of the carb. H&L are side by side, idle is on the linkage to throttle trigger.
Nov 15, 2014 | Garden
I have a homelite chainsaw it starts up but goes full throtle it wont idle right
Make sure all the cables and moving carburator parts are clean and move freely.
Homelite chain saw 3316c
ok check the magneto if rusty clean with fine grit paper then try it if not then may be time to change the coil and magneto..
Jul 13, 2014 | Garden
Idles wide open
Sounds like the inner cable is too short, what you can do is gently snip off a peice
of the outer cable where it anchors, this will make the inner longer.
Oct 24, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
Homelite gas chain saw 3316C How do I tighten the chain?
Lossen the bar and pull it out to adjust the chain tension
Jun 16, 2011 | Homelite Garden
Chainsaw runs full speed, will not idle.
Expose the carburetor so that you can observe the action of the throttle lever on the carburetor. The trigger should move the lever from the idle adjust screw to full throttle stop. If no movement observed, remove the trigger assembly from the front handle (make notes as you remove the pieces) and clean the area of sawdust/dirt accumulation. Recheck the action after everything is re-assembled before starting the engine. If the idle speed is still excessive, then turn the idle speed screw several turns CCW until the chain stops turning. Try wiggling the carburetor body to see if it has come loose from the engine. Hope some of this helps!
May 13, 2010 | Garden
Will not idle, run away high rives
check the flapper valve at the rear of carb.possile it is loose letting in too much fuel.
Jan 04, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Have a 18" power chain saw.
Fuel restriction could be dirty in tank filter, or high idle screw needs to be adjusted. Do this by turning it counter clock wise 1/8 turn at a time start and check for improvement after each adjustment.
Jan 04, 2009 | Homelite Garden
Garden Logo
118 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
