Question about Garden
I have a Meyer salt spreader and it has new controls and it has power to it but it still won't power on
Meyers plow blade doesn't go right
I had the same problem with my 7'6" with an e47 power unit the plow would angle left not up or right. I had to replace Meyer (B) Solenoid Valve Assembly, Red Wire . If you go to the meyers products website they have a troubleshooting chart that is extremely helpful . I found parts are alot cheaper through amazon.
Feb 03, 2014 | Meyer 6 8" Drive Pro Complete Truck Snow...
True Temper Cyclone CB2000 granular fertiliser spreader settings
Because of the extreme caustic nature of salt, that substance can ruin any machine, regardless of the materials it is made of.
If you should try to spread it, it may work if the granule size matches the product the spreader is designed for, but immediately upon completion of your task, you would need to completely wash the spreader, getting any trace of salt off, and then if there are any metal parts, you would need to completely dry it.
That task could cause you to "forget about it".
God bless your efforts.
Apr 11, 2012 | Garden
Need a temperature control unit pa 8300,for a Meyer Work
Try Meyer Customer Relations
http://www.meyer.com/contact_us.html
In 1998 I lost the cord for my wok (don't know the wok model as I do not have the wok now). Meyer sent me a replacement. The TEL number I called was 800 326 3933.
Jul 18, 2011 | Meyer 48986 Electric Wok
Spreader roteltates on blast mode only
You have a rheostat problem, or you have a motor seizing up. Your in cab control has a dial that controls the speed ( thats the rheostat), If the motor is seizing you need to address that problem first. You can check it with a volt meter. disconnect the motor at the connector at the spreader ( back of truck), then stick the red in the red side and the black.... in the black side. Have someone start the spreader on "blast" ( you should read 12 volts), then back it down to setting 5 and you should read around 6 volts, and 2.5 on the dial should read about 3 volts and so on. If this is working you have a motor problem, If you dont see the different voltage reading you have a problem in you cab controls.
Hope this helps
Nov 11, 2010 | Meyer Tailgate Spreader 240Lb Capacity...
Error code
Yes it can be fixed, just have to fond out if a wire got broken or disconnected. The control may have gone bad , but it doesnt happen very often.
Feb 06, 2010 | RTO Buyers Salt Dogg Suvpro Tailgate...
Eurotech Dishwasher problem
Why did you put salt in your dishwasher?
Jun 09, 2017 | EuroTech EDW242C Dishwasher
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
