Question about Sewing Machines
Attach the arms and legs on Raggedy Ann, do I fill them 1st or sew them 1st
    Problem Solver:
  • 7 Answers
You could do it either way but sewing 1st would be my choice. Leave a little opening on the side of the arms and legs to stuff and hand sew it closed.
Posted on Nov 17, 2014
Do you have a motor pulley for a Model R40 Coronado sewing machine?
I you don't want to give up an arm and a leg, see if a nice machinist can make one for you.
Jun 14, 2017 | Sewing Machines
How do I add knit band to pajama pant on McCalls pattern 7975. I have lost the directions.
Usually the cuff ribbing is cut double the required length plus doubled seam allowances (ie 3" x 2 = 6; add two 5/8" for seams = 1.25"'; equals 7.25" long). It is doubled so when it is folded in half and stitched to the leg, there will be no seams showing outside). The width of the ribbing is probably an inch or so shorter than the leg bottom--it should be large enough for the foot to fit through but tight enough that it hugs (not squeezes) the leg.
Sew the cuff together lengthwise to make a circle. Fold it in half with the stitched seam inside. Then fold the circle widthwise with the seamline at one end. Mark the halfway point opposite the seamline. Then fold in half again with the seamline and the first pin matching together. Mark the other two ends. You've divided it into equal fourths. Repeat the same procedure marking the pajama leg in fourths. Then match the seamline of the ribbing to the seamline of the leg (right sides together). Match the other three marks on the cuff to the three marks on the pajama leg bottom. You'll have the stretch the ribbing because it should be a bit smaller in circumference than the leg bottom. Stretch the ribbing to match the leg bottom and stitch the ribbing and leg bottoms together. Turn right side out.
How to Attach Knit Cuffs to Sleeve Shirt Sleeves
sewing with knit fabric how to sew sleeve cuff with knit fabric
Jan 02, 2016 | Sewing Machines
How do I mount model 4830C to cabinet?
If it could be attached to a table so the machine will flip down and be hidden, it would need some sort of metal loops (hinge pin attachment) on the bottom at the back of the machine. You also would have to have the hardware (bolts, nuts, etc) to attach it.
How to Install Sewing Machine into Cabinet
or, frequently, you will have a sewing table with a separate insert that can be lowered or raised and your sewing machine just sets on that adjustable insert. Then you just raise or lower the dropped insert until the sewing machine surface is level with the table's top surface.
example: White Sewing Table with Wheels Jo Ann
Jan 02, 2016 | Singer Sewing Machines
I cant get my needle position to move to the left or the right
The long arm is attached to the needle arm.
1. Move the needle arm right and left with your finger. Is there any resistance? There should be. If not, a spring that is supposed to be attached to the long gray rod has came loose.
2. The spring will be attached so it pulls towards the round cogs (bumpy things).
3. Mechanical sewing machines are very similar. There is a possibility that your adjustment lever has screws came loose.
4. By moving the needle arm back and forth you can monitor what is going on to get a clue of what may be wrong.
Mar 06, 2015 | Sewing Machines
Embroidery hoop
No there should not be a lot of play.
Jan 31, 2014 | Janome Memorycraft 9700 Computerized...
Singer Futura CE-250 error 6 when I am just sewing
This error means that the arm is not getting the electronic information with the main machine.Make sure the arm is "leveled' with the main machine. I found this out moving gently the arm up or down. I use a piece of thick paper folded in half and put it under one side of the machine (usually the front part of the arm) and then the arm moved showing that the connection was successful. Hope it make sense and helps!
Nov 04, 2011 | Singer CE-200 Quantum Futura Computerized...
The lights n the right side all come on and some of them blink when I attach the extended arm.
When you say the extended arm, are you referring to the embroidery bed? You have to add the attachment first and connect it to the computer first before turning it on.
Feb 11, 2010 | Singer CE-100 Futura Computerized Sewing...
Cannot thread bobbin
If I remember correctly this machine has a little arm in the bobbin case area. You will need to open the slide plate, move that arm towards the middle of the bobbin. Thread your machine as normal, take the thread going through the needle eye and wrap it around the thumb screw a couple times, then start "sewing" your bobbin should begin filling, once started, you can release the thread wrapped around the thumbscrew. Once filled, you simply close the slide plate and that moves the arm back into place and start sewing.
Dec 23, 2008 | Brother LS-1217 Mechanical Sewing Machine
ESPIRE SEWING MACHINE - MODEL ESp baby lock
Take it back to where you had it repaired and ask the dealer to make it work under his warranty. Maybe he can tell you exactly what's wrong with your machine. Usually it is a pressure problem or the feed dogs are filled with lint or they don't rise high enough above the needle plate to work. Take off the needle plate and check them.
sewman7
Jul 18, 2008 | Baby Lock Espire
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
