Where does the power cable come into the back of the wall mounted 6.3Kw cooling /heating aircon so I can put hole in wall to line up?
  • 2,210 Answers
Where is your handbook? See if you can find one online?
Posted on Nov 15, 2014
jerryg50
  • 1667 Answers
SOURCE: wall mounting emerson lc320em9 television
I don't know the model in particular, but most of these sets can be wall mounted if you have the screw holes for the mounting plate in the back of the set.
What I believe the tech was telling you would be that it is best to not wall mount the set. The reason is that we found that we have been seeing a higher failure rate from sets being wall mounted. This is because the surface of the wall reflects some heat back in the set, and thus causes it to internaly run warmer. This is also the same from running a set inside of a cabinet. The complete surface area behind the set being very close to the wall surface blocks cooler air circulation. It is best to run these sets on a stand that is out in the opened at least 1 foot away from any wall surface.
Jerry G.
Posted on Jun 28, 2008
SOURCE: Looking for a wall mount that fits the ProScan 26LB30QD
http://store.videomountstore.com/ has a tool at the top of the page that gives custom mount recommendations based on the mounting holes for your specific TV. Just choose PROSCAN and 26LB30Q from the list and it will show you the mounts they have that will work for that TV.
Posted on Apr 20, 2009
  • 3 Answers
SOURCE: Tv didnt come with screws....
The size is #8-40 X 3/4". This is a specialty screw, so you're screwed
Posted on Dec 13, 2009
budmrtn
  • 11361 Answers
SOURCE: I have an Olevia 332 b11 LCD tv. I want to mount
There should be at least 4 mounting holes (VESA mount), and they should be used.
Posted on Dec 17, 2009
Select TRNX
  • 4 Answers
SOURCE: wall mounting the LG 42LC2D TV there are holes in
There will be 4 big holes used to install a mounting bracket on the back of the TV.
Posted on Jan 10, 2010
This thermostat is mounted mid-wall on a brick wall and consistently reads 4 degrees warmer than 2 other thermometers in the room. Can the thermostat be recalibrated? How?
A manual for the thermostat is needed to recalibrating if doable, thermostat model number and brand needed to get the right manual.
A thermostat mount location should be planned. Any holes leading into the wall should be sealed, in other words, the thermostat needs to be insulated and isolated from fake temperature readings, no back drafts or not heat or cooling sources near by.
Jun 23, 2015 | Heating & Cooling
Mounting amp to car
make sure you mount where you can get a good ground and where it can get enough air to keep cool. underneath the car seat is where a lot of installer put the amp, and if you are going power up a lot i would think about mounting a fan to blow air on it to keep it cool. i have fans connected to my laptop power supply transformer to keep the unit cool, here other ideas you will never be told, putting little holes around power supple, fan area, any where there a lot of heat is generated the air flow helps it stay cooler while powering up the amp.
good luck and be safe rod
Mar 01, 2014 | Volfenhag Car Audio & Video
We have 2.0 HP inverter wall mounted LG aircon, when we turn on the ac, the indoor unit only is running and shut down after 3 mins. What is the solution?
Hi Marie, does the green indicator light on the front panel flash after it shuts down? If it does...count how many times it flashes this will refer to a fault code diagnostic.
Keith.
Jan 02, 2014 | LG LS-K2430HL Heat Cool Mini Split Air...
I had the aircon thermostat on cold then my friend just transfered it to warm without turning the aircon off because it was too cold. in the afternoon when i tried to use the aircon theremostat to...
Problem is the thermostat.The heat/cool selector switch might not be making try back and fourth from heat/cool to make a good contact.In heat mode make sure the temp is set LOWER than your cooling temp.If it is too cold in the future just RAISE the cooling temp up and not the heat/cool switch.
Jun 04, 2011 | Heating & Cooling
Unit will heat only will not cool and how to repair
we have a split type gree aircon, with one (1) horsepower. it was just newly installed, around 6 months ago. we are just surprised that one when my wife turned it on, thru the use of its remote control, the indicator box on the aircon reads or flashes "F2". I detached the batteries of the remote control for severa hours and I also detached the power cord from the wall socket, but it was to no avail. it did not work. with "F2" on the indicator box, the aircon won't give cool air, it is just working like an ordinary fan. please help us.
May 17, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Need instructions
Flat Panel TV WallMounting Instructions
Currenttrends Flat Panel LCD and Plasma HDTV's are making TV's thinner, lighter andmore powerful. Superior high definition viewing, affordable pricing with addedspace and energy savings are only just a few practical reasons for purchasing anew HDTV. With newer thinner designs, LCD and Plasma HDTV's are ideal for wallmounting. Wall mounting your television frees up space and adds a new elementof aesthetic appeal to your home theater. Positioning Before getting into any hardware mounting,find the best possible position to mount your television. Because wall mountingan HDTV is more of a permanent solution, careful planning is needed whenintegrating the television into your home design.
Furniture placement, overall themes, viewing angles, and the best audiopositioning are all factors that will help determine the placement of the LCDor Plasma TV.
Once you have decided the general positioning of the wall mount installation,cut out a piece of cardboard or wrapping paper in proportion the of theflat panel television. Next, approximate the placement by taping the piece ofcardboard or wrapping paper to the wall where the TV will be placed and mark itwith a pencil.
Preparing the TV Removethe stand from the television and lay the TV on its face. Locate the fourmounting holes on the back of the television and remove the bolts. Next, removethe mounting arms or mounting plate from the wall mount packaging.
To attach mounting arms, line up the arms vertically and parallel to each otherusing the mounting holes on the back of the television. Make sure that they arein perfect alignment and bolt the arms using the bolts and washer supplied withthe wall mount.
If you are using a mounting plate, simply line up the holes with the mountingholes on the television. Secure the mounting plate with the bolts and washersincluded with your wall mount.
Preparing the Wall Locatethe studs closest to the desired position using a stud finder and mark themwith a pencil. Remove the wall mount from the package. Line up the wall mountup to the studs within the center of the marked position you determinedearlier. If it is not perfectly centered, wall mounts can be adjustedhorizontally at a later time.
Using a level, line up the wall mount and mark the positioning of where hebolts will go. Drill holes into the stud about 1" deep, drill bit depends on the of bolts supplied with the wall mount. Bolt the wall mountto the wall with bolts and washers, but don't tighten down the boltscompletely. Adjust the position of the wall mount left or right to center it toyour desired position. When you are done, tighten the bolts the rest of theway. Mounting the Television Attachingthe television to the wall mount takes two people. Simply lift the televisionand hook it to the wall mount. At this point you can further adjust thepositioning horizontally to center it perfectly. Once the desired position isacquired, tighten down the screws that attach the mounting arms or plate to thewall mount.
mike_alozie.jpgWallMounted LCD
Apr 21, 2011 | Televison & Video
2002 jeep grand cherokee larado is over heating. The cooling fanonly runs if I hotwire it. I changed th thermostat. Temp gauge is reading . Could it be the cooling fan relay if so where is it located. The...
Fan relay is located under pass headlight. Remove light assembly, use 2 1/2 " hole saw to drill hole in plastic housing ,3"from back wall, 3'' from left side.This will put you right over relay. Unscrew two bolts,replace. Relay was $40.... dealer wanted$350 to remove front bumper to replace it.
Sep 02, 2010 | 2002 Jeep Grand Cherokee
We just moved into a rental. It has the Fugitsu wall-mounted Air-conditioner model: ar-jw2 but, there was no manual left behind and we are trying to use the heat, however, it just blows cool air, we're not...
Look, if you select a temperature above ambient temperature, it will switch from cooling to heating.(assuming that the aircon has a heat pump. most do these days.) Just dont rush the aircon because every time you make a setting change, it takes a while to regulate.
Aug 12, 2010 | Heating & Cooling
Wall mount for 52in tv ?
Here is a mount rated for your size TV http://www.bhphotovideo.com/c/product/518312-REG/Bentley_PLAW_6000FB_PLAW_6000FB_32_60_Flat_Panel.html
Also, be VERY careful mounting ANY plasma above a fireplace. Plasma sets are typically convection cooled to avoid the noise of fans. The heat from a fireplace will GREATLY reduce the life of the set. When people I know insist on putting a set above a fireplace I usually insist they install a cooling fan with ducting that will vent fresh air to the set. If you are concerned about the temp of your set simply consult the owners manual for operating temperature and measure the air above the fireplace yourself. BHphotovideo.com typically has good prices on mounts along with amazon. most other places like bestbuy or circuitcity will stick you on the price of the mount because they make their money from accessories. Also, why did your last set die? plasmas are typically rateed for 10+ years, did yours over heat and start to change colors?
May 17, 2008 | Televison & Video
Air conditioner constantly shuts off
Are you saying that you have plugged the aircon into an extension lead then into a socket in the wall and that the smoke was coming from the extension lead part. If so I would suggest checking all your plug in connections and chenge the extension lead. A quick way to check the compressor is a cause is to put the aircon to fan only and see if it fails to trip out the circuit breaker, then put it back onto cooling and see if it trips (if it does on cooling then its a good possibility). Most aircons have a three to five minute time delay for starting the compressor to protect against power fluctuations (ie power cuts). Hope this s of some help.
Sep 11, 2007 | Frigidaire FAC107P1A Wall/Window Air...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
