Question about Lands Phones
How do I mount your SN6147 telephone on the wall
The corded handset will not stay on the telephone base
  • 57 Answers
On the base unit where the ear part of the handset sits, there should be a movable tab, you should be able to slide this up/forward to hold the phone more securely when wall mounted.
Posted on Nov 19, 2014
Testimonial: "A friend found the solution - on back of telephone there's a movable plate which changes the angle of the phone elevating the bottom of the telephone instead of the top and this angle the handset sits and holds better. But I still find that the hand held part when you hand up the phone does not always hold well and falls (risk of craking the hand set part of the telephone. You mention this movable tab which slides up but this does not hold the hand held device better when slid up ...the "forward" part of your message is intriguing ...if I slide this tab up to hold the hand held piece more securely, it comes right off...where is the "forward" motion in there?"
SOURCE: Cordless Handsets don't work
in manual it states that you need to give permission on corded base for handset to link to cordless phone.
Posted on Nov 17, 2007
  • 84 Answers
SOURCE: no electrical outlet available for the base station (wall mounted)
AFAIK there is no answering machine that will work without being connected to an electrical outlet, neither will the caller ID. The corded handset on the base unit will work, but that is it. The base uses the AC power to transmit and receive to/from the cordless so you won't be able to use the cordless handset with out the base being connected to AC.
Posted on Feb 27, 2009
SOURCE: GE Model 27911 DECT 6.0 Additional Cordless Handset not working
Please note that if you have a wireless router for you computer in you house, it will definitly interfier with the 27911's registration process. Make sure you shut you wireless router first, before you try to register to the base (27909) unit. That worked for me.
Posted on Jul 12, 2009
SOURCE: BT Studio 3500, Base station,
bt studio 3500 says memory full do not have 1571 how do I clear answer machine
Posted on Aug 21, 2009
  • 279 Answers
SOURCE: I have just purchased a
It is a tab on the base that the receiver "hooks" onto. You should be able to push it up twoard the top of the phone.
Posted on Sep 20, 2009
Want to be clear about the handset and telephone base set because base set is not responding to handset.
The base needs to be plugged into the wall for power and have a working phone line.
Oct 16, 2014 | Lands Phones
Phone ring tone in house cannot hear it do not know house to fix as instructions are in greek
must be sure handset ringer volume is NOT set TO off
2) THE Telephone line cord and power adapter are plugged in properly.
3)the handset may be too far from the telephone base. Move it close to the telephone base.
4) many extension phone on the telephone line to allow all of them to ring simultaneously.
5) if other telephones in your home are having the same problem , the problem will e in service provider
6) other electronic products such as HAM radio detect the phones cause interferences.
7)test a working phone at the wall jack.
8)remove and install the battery again and place the handset in the telephone base
9) wait for the handset to synchronize.
God bless you
Sep 27, 2012 | Lands Phones
Lost phone manual, uniden d2997
I have a standard trouble-shooting routine for cordless phones. 1) Remove the battery from the handset (from all handsets for a multi-handset version). Then unplug the power cord from the base and wall outlet and also remove the telephone cord. Wait a few minutes and then reconnect the power and phone line cords. Reconnect the battery (ies) for the handsets. Make sure this connection is tight. Then make sure that the battery is fully charged (15 hours before first use) and register the handsets if needed. This is done by putting each handset onto the base in order for the D2997. Wait about 30 seconds for each one until you see the Handset Registered message. Make sure that you are within range of the base.
Next try a different telephone (RJ-11) phone cord between the base and the wall jack. Also check if the power adapter for the base is warm. For the next set of tests, I like to use an old corded telephone. Using a different phone, check if you get dial tone at the jack. If there is a dial tone, then the problem is with the Uniden phone. If the above trouble-shooting didn't help, then contact Uniden. These phones aren't meant to be user serviced.
If you do not have a normal dial tone, try another jack on the same telephone line. If there is dial tone at another jack, then you have a problem with the first jack. Otherwise find where your telephone service comes in. If you have a fairly new service, you'll find an RJ-11 jack. Plug your test phone into the jack and test for dial tone. If you have no dial tone or can't test your line, call your phone company. They will fix any outside problem for free. If it is an inside wiring problem, look at the visible wiring and determine if the wires are damaged. Open the jack (if only one is bad) and check for loose wires. There are two types of jacks. One secures the terminal wires with screws and the other uses a punch-down jack. For the screw type, strip additional insulation from the conductors, if needed, and then reconnect them. For the punch-down type, you will need the punch-down tool. It is available at many hardware stores in the wiring section. Use this diagram to check your jack wiring: http://www.lanshack.com/wire_phone_jack.aspx . If you can't see an obvious problem with the wiring, you may want a professional to deal with the wiring in the wall. Your telephone company will do this for a fee.
Uniden has the manuals for their DECT phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The manual for the D2997 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D2997om.pdf .
I hope this helps.
Nov 26, 2011 | Uniden Lands Phones
Dont know how to hook it up to phone...have S10A and S11 model plantronics corded headsets
Turn over the S11 base and insert the headset slot. This is at the top of the base. Remove the handset cord from your telephone base and plug into the handset jack (there will be a picture). Using the short cord that came with the S11, plug into the line jack on the back of your base and the other end into the slot on your telephone where you removed the handset cord. Plug the headset cord into the headset jack that is on your S11 base. Connect the the A/C power adapter to the S11 A/C jack and a wall outlet. Put on the headset. Press the handset/headset switch and pick up the handset off your telephone, set it aside to make calls. Slide the configuration switch (on the side of the S11 base) until you hear a clear dial tone.
Good luck from Headsets Direct!
Aug 24, 2010 | Plantronics (45647-04) for S10, T10, T20...
My tru9480 handset is saying connecting but won't connect and won't get a dialtone
Reset Procedure for Cordless Phones
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
Jun 13, 2009 | Uniden TRU9480 Cordless Telephone
Have 2 t7316e nortel phones...i can hear the other person, but they can't hear me...tried swapping handset, but that didn't resolve the issue...any answers?
Look at the bottom of the set that is giving you troubles, check to see if the handset is plugged into the correct spot.
It should be plugged into the Handset jack not the headset jack.
This is a common mistake.
Feb 23, 2009 | NorStar T7316E Telephone
Fax replacement parts
The jacks generally used for handsets on fax machines are a smaller (fewer contact positions) version of the one that are used for the wall-mounted outlets.
Unless the Brother handset jack looks totally different than the one in which the fax machine is currently plugged at the wall, then the handset jack should look pretty much the same but smaller.
A friend or relative may have a retired corded phone that they haven't tossed out yet so check with them before poking around to look for a replacement as described below.
If you are in the US, check the dollar stores and chain drugstores for corded telephones. Coming from China, they shouldn't cost more than $10 US and may have the exact same connector attaching the handset to the base of the phone. Check them if possible before hitting the cash-register since it is becoming more common to have the handsets on these cheap phones permanently wired to the base which, of course, makes them useless for your needs. Most stores though will let you return the item for a refund.
Checking a couple of stores, you may even find it possible to match the color of the fax machine with your substitute handset.
Nov 13, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Model 25922 5.8 GHZ Cordless phone with one main phone and two extras
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ge Telephone Solutions
Handset can not link.
• If any handsets become inoperable, place it on the main base cradle for 20 seconds to re-register.
No dial tone
• Check or repeat installation steps
• Make sure the base power cord is connected to a working electrical outlet.
• Make sure the telephone line cord is connected to the base unit and the modular phone jack?
• Disconnect the base from the wall phone jack and connect another phone to the same jack. If there is no dial tone on the second phone, the problem might be your wiring or local service.
• The handset might be out of range of the base. Move closer to the base.
• Make sure the battery is properly charged (for 16 hours).
• Ensure the battery pack is installed correctly.
• Did the handset beep when you pressed the TALK/CALL BACK button? Did the in use indicator come on? The battery may need to be charged.
http://www.home-electronics.net/ge/pc/IB/25922GE2_IB.pdf
Sep 02, 2008 | GE 26998GE1 Cordless Phone
No electrical outlet available for the base station (wall mounted)
most cordless phones need some access to 120 volt power to recharge the internal NiCad batteries. It wouldn't be cost effective to have on hand a bunch of charged batteries that you'd replace on a daily basis. they got to be charged up eventually.
Aug 23, 2007 | Uniden CEZAI998 Phone
Lands Phones Logo
48 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
