Question about Lands Phones
How do I turn off caller announce ? I have gone through my menu and nothing is listed, also I have no buttons on the back... I have a Uniden XDect 8155 I would appreciate your help ASAP as every time
How do I turn off caller announce ? I have gone through my menu and nothing is listed, also I have no buttons on the back... I have a Uniden XDect 8155 I would appreciate your help ASAP as every time the phone ring it announces the number verbally and I have had a lot of calls Lol thanks
  • 537 Answers
SOURCE: Changing MAIN voicemail announcement
I am not a phone installer and we have another vendors' phone system here at our work.
It can be *extremely* difficult setting up these phone systems, even with a manual.
Here is one such link that might help:
http://www.alphatelecom.ca/meridian_norstar_manuals.htm
Here is another forum that has lots of friendly folks that might be able to help
http://www.sundance-communications.com/forum/ultimatebb.php?/ubb/forum/f/8.html
You will get an answer much sooner on there than here probably.
Mike
Posted on Nov 09, 2007
SOURCE: I can not get my phone to pick up on the answering system when a caller is trying to leave a message
Did that too! Thanks. I think I need to call the phone company to deactivatge the generic meesage system that keeps picking up before the answering machine for the new phone we just bought.
Posted on Dec 27, 2007
SOURCE: Changing announcement on Avaya Partner ACS phone
Selector code 3 is playing an announcement. You have to go into programming, press selector code 3. depending on the voiceail yu have....you may be able to modify it right there.. Other wise you willl have to find the annuoncements.
If you repost with what voicemail model it is, i can tell you exactly.
Posted on Feb 19, 2008
SOURCE: Avaya Partner-18D phone
Has this been solved?
Posted on Jun 03, 2008
ginko
  • 19396 Answers
SOURCE: Panasonic KX-TG5673PK 5.8ghz phones.This post
Check that you are using your local answering machine on phone, and not a message recorded in phone provider company service. For example if you are using AT&T check that you are not using the message recorded on At&t, in tht case you need to set up service by phone.
Posted on Jul 25, 2008
We have just purchased a Uniden Xdect 8355 series telephone. When the phone rings we get a message telling us who the call is from, how do we get rid of it?
Do you want to delete entries from the Caller ID list? This records the numbers of the last 50 incoming calls. You can't delete the entire list at once. However, you can delete one entry at a time. Press CID on one handset or base with the entire system in standby (no active calls). The CID button is to the right of the Menu/Select button. Press the Up/Down arrows (above and below Menu/Select) to select one call. Press Menu/Select to get the details of that call. If you don't see list with Delete Entry, Add to PB, and Add Call Block, press Menu/Select again. Select the Delete Entry line and press Menu/Select. Select Yes and then Menu/Select again if prompted to confirm the deletion.
When you are done, press End/Clear to exit the menu system. You'll find these directions on page 30 (page 31 of the pdf) of the manual. Uniden has the manual here: https://www.uniden.com.au/RESOURCES_MAIN/pdfs/XDECT_8355_OM.pdf .
I hope this helps.
May 18, 2017 | Uniden Lands Phones
How do I setup a Uniden Dect 5.8Ghz 8155+2 phone
Uniden XDECT 8155 + 2 Questions & Answers ...
www.productreview.com.au > ... > Uniden > Uniden XDECT 81xx Series
Uniden XDECT 8155 + 2: 25 questions and 38 answers on Australia's largest opinion ...and select Handset Setup or Base Setup. ... If you have a 2.4 ghz or 5.8 ghz modelphone use web address below. .... Uniden Premium DECT 31xx Series.
Nov 23, 2015 | Uniden Lands Phones
My uniden xdect sse25 cordless doesn't ring for long enough before diverting to the answer machine I have mobility problems how can i extend the length of the ring
From the handset, press Select/Menu and then press the down arrow to get to Ans Setup. Press Select again. Go down to Ring Time. Then select the number of rings (6, 9, 12 or Toll Saver (TS)). Press Select then press Flash/Exit to exit the menu system. Toll Saver picks up after 2 rings if you have new messages or 4 rings if you don't. This lets you hang up before the answering system picks up if you are using the remote phone access feature.
Note: if you have Voice Mail from your telephone provider, you need to set that to a longer number of rings separately. Consult with your phone company on that option.
The manual for the XDECT SSE25 is available from Uniden here: http://www.uniden.com.au/RESOURCES_MAIN/pdfs/XDECT_SSE25_OM.pdf . See page 19 (23 of the PDF). You will need Adobe Reader to access the manual.
I hope this helps.
Jan 25, 2013 | Uniden Cordless Phone
How do i delete previous calls from my call display
To open the caller ID list, press CALLER-ID/RIGHT (cursor-right on the circular cursor pad).
To open the redial list, press REDIAL/PAUSE.
Use cursor-up/down to select the desired entry and press MENU/SELECT. Select "DELETE ENTRY and press MENU/SELECT. In addition, in the caller ID list you will have the "DELETE ALL" option.
The above are from the "Using the Caller ID and Redial Lists" section of the manual (page 11 in my copy). If you need a manual, you can download one at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1480-2om.pdf
Sep 19, 2011 | Uniden DECT14803 Phone
I have a corded uniden DECT 6.0--with handsets--how do I set it to record incoming messages? It only announces my message, but callers can not leave a message-
Your phone is in "Announce" mode and you want to switch it to "Answer" mode. Since you didn't specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Sep 01, 2011 | Uniden DECT 6.0 Cordless Telephone...
Have Uniden EX14560 and do not know how to turn ringer back on..can you help me?
Do you mean the Uniden EXI4560 2.4 GHz phone? With the handset in standby, press the volume up button (above End and just below the LCD screen). Then you will be able to toggle between the 5 available ring tones and volume levels. (I'm assuming the unit is set to Ringer Off which is another choice in the list.) Press End to confirm and save your ring volume setting.
Most Uniden manuals are available from Uniden on the product page or the support page. The product page is http://www.uniden.com/cordless-phones/24-ghz-extended-range-cordless-technology/invt/exi4560g/ . Then go to the Manuals tab. The direct link to the EXI4560 manual is http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/EXI4560om.pdf .
All of the Uniden manuals are here: http://www.uniden.com/scat/cordlessphones_mnl . Use the drop down menu to select the type of phone and then find it in the list by numerical and alphabetical order. The EXI4560 is on page 4 under cordless phones.
I hope this helps.
Aug 25, 2011 | Panasonic UnidenEXI3226 : Two-Line 2.4GHz...
How do I change my original message on the answer machine?
Which Uniden DECT 6.0 phone do you have? Uniden makes several models.
For one Uniden phone that I know (DECT-1080), first make sure that the answering system is on. If needed, at the base press Ans On/Off. From a handset, press Menu/OK and use the redial and Phone Book keys to navigate through the menu to AM Operation. Press Menu/OK and navigate to Ans Settings. Press Menu/OK and navigate to Answer On/off. Press Menu/OK and then choose On and then Menu/OK again.
To set the Out-Going Message, again go to the Ans Settings submenu at the handset, and navigate to Record OGM and press Menu OK. Select OGM 1 or OGM 2 and press Menu/OK. Record your message after the tone. To select the OGM message to be heard by incoming callers, navigate to Select OGM, press Menu/OK, select the message and press Menu/OK.
Please note that you also need to make sure that the system isn't set to Announce Only in the Message length section. Enter this submenu from the Answer Settings as above. The choices are 1 minute, 4 minutes and Announce Only.
You can also do set the OGM from a touch tone phone remotely. Press * as the OGM plays and then enter your PIN. Press 06 and then 1 or 2 to select the OGM to edit. Then press 9 to return to the main menu.
However, on the DECT-1480, you set the OGM from the handset but in a different combination. Press Messages/Mute then 5 (or wait for the announcements to end). Press 8 or press the Caller ID/right arrow to navigate through the menu to 8: Record New Greeting. Press Menu/Select. Wait until you hear "Record greeting" then speak your message normally. Press 8 to end and listen to the playback of the greeting. Press End to save the message. (Select the desired greeting by pressing 6 instead of 8.)
Most Uniden DECT phone manuals are available from the product page or this list: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl .
If you provide your model number in a comment, I'll be glad to give you the specific directions for setting the OGM on your phone.
I hope this helps.
Aug 08, 2011 | Uniden DECT 6.0 Cordless Phone ID
My phone is in the announce mode. callers cannot leave an answer,
What is the specific model of your phone. Typically there is a setting in your machine to set the "Recording Time". Uniden typically you can set to 1 minute, 4 minutes, or "Anounce only". This last one is probably what your is set to.
Typically pressing the "Menu" key will go to each setting for each time you press the button. Press menu until it announces "Recording Time" Then select 1 minute or 4 minute using the "Select" Button.
You can get most of the manuals for your uniden phones at :
http://www.uniden.com/products/index.cfm?cat=Cordless%20Phones%202.4%20GHz%20Digital
Select your paticular phone and see if they have the phone listed.
elijam1
Dec 16, 2008 | Uniden BC72XLT Handheld Scanner
Lands Phones Logo
46 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
