Question about Bobcat 773
How do I change the alternator on a 773 Bobcat diesel?
Diesel...do I have to lift the cab?
  • Bobcat Master
  • 2,210 Answers
Steve, read my other answer.
Posted on Nov 15, 2014
Where can I buy a bobcat operation sensing system
Bobcat 773 Service Manual PDF ' Bobcat Service Manual
https://bobcatservicemanual.wordpress.com/.../bobcat-773-service-manu...
Apr 26, 2015 - Download your Bobcat 773 Skid Steer Loader service manual PDF (SN: 509635001-Above, 509616001-509634999). These workshop service ...
Jul 25, 2015 | Bobcat 773
I added diesel to the hydraulic tank in my bobcat and never an it. I drained the tank, refilled it, and now the hydraulic system wont work.
You should use hydraulic oil, not diesel, drain it, refill it and if necessary bleed all the air from the system (some are self bleeding) Dependant on the type of hydraulic system you may have damaged the seals by using diesel oil, that, unfortunately is expensive.
Mar 05, 2015 | Bobcat 773
How do I change the alternator on a Bobcat 773 skidsteer loader
Why do you suspect the alternator? Have you checked the output? Put a meter across the battery terminals when running at fast idle and it should be 14.5volts and no less than 13. Poor cold start is usually the heater plugs/ failed heater plug timer or poor battery strength. Start at the beginning and see if the alternator is working OK, then work through the rest. Test the heater plug supply by putting the meter from the plug supply cable to ground when the switch is in cold start position. Should have 12v at least. Make sure both battery cables have good clean connections at both ends to chassis or starter. Most cold start problems can be fixed by careful maintenance and basic systems checks.
Nov 15, 2014 | Bobcat 773
How hard is it to r & r an alternator on a 773 turbo bobcat skid ?
Forget it! It's a job for a specialist. You'll need electrical test equipment, a lathe and probably specialist winding kit. Cheaper to get a recon.
May 05, 2014 | Bobcat 773
How to replace alternator on 773 turbo bobcat
Not to hard. Unhook battery, remove bolts holding alt. in place, remove wiring on back. You may write location of each wire.
Bobcat 773 hydraulics stops, then when turn hydraulics back on it works
test you seat switch,and the pull down lapbar,and it also may have a seatbelt switch.if your driving on alot of bumps and the machine is throwing you around you may be lifting off the seatswitch.
Mar 15, 2014 | Bobcat 773
Replace rear wheel bearing 773 bobcat
you must unbolt it from inside chainbox. Raise cab, and remove about 8 bolts that hold a plate that is back toward the engine, in line with back axle. Inside you will see 2 large chains and sprockets, and a bolt that holds the sprocket to axle. Use a 1-1/8" wrench to remove bolt, then axle may be removed. Replacing outer bearing and seal is now possible
Sep 23, 2012 | Bobcat 773
Need 773 bobcat auxiliary control wiring diagram, hydraulic diagram
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Bobcat 773
Apr 30, 2012 | Bobcat 773
Garden Logo
234 people viewed this question
Top Bobcat Garden Experts
Daryl Gleaton
Dan Apthorp
Jim flowers
Jim flowers
Are you a Bobcat Garden Expert? Answer questions, earn points and help others
