<!-- from fixya rte -->How do i take the cover off to clean - Heating & Cooling
Clean What ?
90% of the people that come here, only
make a statement & show no product or
question with details
Posted on Nov 15, 2014
Testimonial: "Sorry Teddy B its a KSE 88 HRA commercial split system air conditioner"
I have not used my power roller 990 in a few years. I got it out today, turned it on, worked for one second. now nothing
Pump did not get cleaned out right the last time you used it-
Also this time when you clean it take the cover off the frame if its got dried paint on it throw it away, every time you use this roller cover take the cover off and clean it well these types of covers have lots of small little holes in them thats how the paint gets onto the roller cover in a 5 gal bucket fill it with warm water and start to work the paint off it and use a "brush spinner" made by Shur Line it also cleans out roller covers to by throwing the wet paint or dirty water out be sure to "spin the cover or brush" out in a empty 5 gal bucket as it is messy. not-used-power-roller-990-in-few-years-4z2gdaa2roisjyazpqzwiojf-3-0.jpg
Nov 01, 2014 | Wagner Spray Tech 0514001 Pro 990 Power...
Replace valve cover gaskets
Remove bolts for valve covers. Remove cand clean covers. Remove and clean old gasket from heads. Use gasket shelack to place new gaskets into place(easier to place on the covers) Reinstall valve covers with gaskets in place. Reinstall bolts. Done.
Jun 12, 2014 | Vehicle Parts & Accessories
How do I clean my futon cover?
In order to properly clean your futon cover I suggest reading the directions sewn into the label by the manufacturer. Most covers can be cleaned by using one of the following methods: spot cleaning, washing machine and dry cleaning.
Aug 01, 2012 | Furniture
Message 'Clean Sensor' has appeared. Followed advise to open Cover D and close it again but to no avail. Has anyone got any other suggestions, please?
Follow the steps below to clear the "Clean Sensor" error message.
  2. Slowly close the cover again. c2600_close_cover_d.jpg This action will move the lever shown below and clean the sensor.
  3. Open and close the cover several times. Once the front cover is left closed the printer will start to calibrate.
Once complete, the error should no longer appear and the printer should resume normal operation.
Note: If the error message is still apparent after following the steps above, contact Epson for further advice.
Nov 16, 2010 | Epson AcuLaser C2600N Printer
While printing, red turned to pink on printed sheets. All cartridges have ink.
Try
Clean the Scanning Area sikaku.gif Cleaning the Platen Glass and Document Cover i_expl.gif Caution
Be sure to turn off the power and disconnect the power cord before cleaning the machine.
i_important.gif Important
bullet_s2.gif The inner side of the Document Cover (white sheet) (C) is easily damaged, so wipe it gently.
bullet_s2.gif If the glass of the ADF (A) is stained with ink, correction fluid, or the like, black streaks may appear on the printed paper when the document is loaded in the ADF. With a clean, soft, lint-free cloth, wipe the glass of the ADF.
With a clean, soft, lint-free cloth, wipe the Platen Glass (D), the inner side of the Document Cover (white sheet) (C), the glass of the ADF (A), and the inner side of the ADF (white area) (B) gently. Make sure not to leave any residue, especially on the Platen Glass.
sikaku.gif Cleaning the ADF i_expl.gif Caution
1. Open the Document Tray.
2. Open the Feeder Cover.
3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Feeder Cover (A).
4. After wiping, close the Feeder Cover by pushing it until it clicks into place.
5. Close the Document Tray.
6. Reconnect the power cord then turn on the machine.
Oct 27, 2010 | Canon PIXMA MX850 Multifunction Printer
How do I remove the screen to access and clean the picture tubes and mirror? Pioneer SD533hd5
Before starting, it is a good idea to disconnect the power cord for your TV from the AC wall socket or power bar. Remove the back cover from the TV. Unscrew and remove all the wood screws holding the back cover on. Grasp the bottom portion of the back cover and pull straight back approximately 4 inches. You may require assistance from another person if you are of small stature. There are two plastic tubular portions at the bottom of the back cover that insert into the particle board enclosure and if you don't pull straight back, you risk damaging the back cover and or the enclosure. The mirror is fastened inside the back cover and will come out at the same time. You will then have access to the CRT lenses and the mirror for cleaning. I would not recommend removing the mirror from the back cover for cleaning. It can be done while in place using a clean, soft, lint free cloth and a very mild soap and water solution. Just be certain not to leave any streaks. The lenses can be cleaned with a lint free cloth and alcohol or a camera lens cleaning tool. Take care not to touch the lenses with your fingers. See web link for lens cleaning tool http://www.opticsplanet.net/carson-lenspen-cleaning-tool.html .
Jan 12, 2010 | Pioneer SD-533HD5 53" Rear Projection HDTV
Good morning, I need to clean inside of my Toshiba 50A60 model tv screen, I do you remove screen?
Yes I Had The Same problem , if your handy with fixing things this will
work.
Step 1- unplug the TV from wall socket
Step 2- disconnect all devices like VCR's DVD Players from the TV
Step 3- remove the speaker covers from the TV
Step 4 - There are 14 screws on front cover, remove these with a
Philips driver, set cover aside
clean with soft brush and wash with water
Step 5- Gently raise the cover straight up to release it from its supports
Once cleared from supports , remove the cover.
Tips- Make sure you don't scratch any of the screens or CRTs
You can clean the mirror with any glass cleaner, make sure to wipe it
clean , water and vinegar does a good job to eliminate streaks.
Use a soft duster to clean the dust from the circut boards
Tip - Remember take it easy when cleaning
When your finished cleaning, just reverse the steps
It Worked for Me
Sep 30, 2009 | Toshiba 50A60 50" Rear Projection...
Cleaning tv screen protector cover
MAKE SURE YOU USE A LINT FREE CLOTH AND NO ALCOHOL OR OTHER CLEANING PRODUCTS,IF ITS A LCD I WOULD'NT RECAMEND TAKING THE COVER OFF
Mar 07, 2009 | Televison & Video
Cleaning the screen cover on my sony big screen
To clean its front screen, you should not open front cover as its complicated procedure. just take off its back cover as its shown in picture and use air-blower to clean dust. Then use soft cotton cloth to clean its screen from internal and 3 bulbs / lenses (CRTs) and job is done.
Need further help, let me know.
Bye.
Sep 13, 2008 | Sony KP-57WV600 57" Rear Projection...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
